05-02-2024, 02:49 PM | #1 |
Rep 3,560
POR15, Rust Bullet, Rust Converter Ultra - Anyone used these rust treatments?
Wondering if anyone used these products to coat rusted areas and how they hold up over time?
They all hold pretty good reviews, however i was hoping to get some of our e90post veterans' opinions. Last edited by Wolf 335; 05-02-2024 at 03:02 PM.. |
05-02-2024, 04:48 PM | #2 |
Get off my lawn
938
Rep 1,162
I used PERMATEX® Rust Treatment on a few small areas of rust on a Miata door a few years ago. Worked well for me
After sanding, cleaning, and initial application After a few coats of paint Sold the car a year or two later so cannot report long term, goal here was just to stop migration. |
Wolf 3352367.00 |
05-03-2024, 08:37 AM | #5 |
the me
355
Rep 322
I used POR-15 on the buggy chassis. So far so good.
I think they all work well though. It's all in the prep. Not sure the total use case you have. My latest was not a totally rusty surface. I used a eastwood product on the frame of the truck a few years ago. It's holding up good as well. Again, quite a bit of prep work on the surface.
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else 21 M2c Coupe ,DCT, SOM, not much else |
05-07-2024, 09:14 AM | #6 |
Rep 3,560
Ended up getting a bottle of Phosporic Acid 85% as it is main active ingredient in all of rust converting products that actualy work as per reviews.
Going to dilute that to about 45-50% Phosphoric acid and apply to rust to stop it and conver it to iron oxde. Then i will follow it with a rust coating such as POR15 or Rust bullet. |
05-13-2024, 08:24 PM | #8 |
Rep 38
I've used Por 15 and RB. I prefer P15, it's thicker. Both work well. Both have similar quality prep products. I've used P15 on just about every brake rotor I've had / installed over the last 15 years, barrel and edges. Looks great. I've also done a couple trailers and other projects with both products. Anything regularly exposed to sunlight will need a top coat. Prep is key. Whatever it gets on it stays on. That's about it, P15 for the win.
05-13-2024, 10:51 PM | #9 |
222
Rep 317
por15. Used it many years ago and worked really well. Painted the frames of a few of my trucks. Wire brush and pressure washed. Then went back with por15 a little later. Good product.
