      05-28-2014, 04:30 AM   #1
robydg63
Drives: Lexus RX 450h
Active Steering
I have not yet decided if it's worth taking the active steering. I read your thoughts, almost all negative, on the adoption of electric power steering compared to the old hydraulic on E70 model. I drove my E70 for 4 years without Active Steering, and, in the parking lot and at low speeds, Active Steering, would have been useful. Do you think the new electric steering is sufficient in terms of maneuverability and lightness or Active steering is necessary? Has anyone had the opportunity to personally experience both configurations on the F15 model?
Thanks,
Roberto
      05-28-2014, 07:15 AM   #2
MtgMaster
Drives: 2024 X5 M60i
I can tell you I have the option and love it. Much more direct and less turning of the wheel at lower speed.
Also don't forget it enhances safety besides less effort.
If the vehicle is threatened with instability, such as by oversteering or braking on a changeable surface, DSC identifies the problem and can use Active Steering to help overcome it. For example, in order to reduce unsafe yaw, Active Steering can increase the angle of steering wheels faster than even the most expert driver.
      05-28-2014, 07:34 AM   #3
robydg63
MtgMaster, the security considerations add an important reason for choosing AS option, honestly is something that I hadn't considered.
Thanks a lot,
Roberto
      05-28-2014, 07:54 AM   #4
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Thanks a lot,
Roberto
With Msport it is great, test drove with professional suspension (no M sport) and it was not as good as with Msport especially at speed 60-80km. You are also much quicker with parking. Great option well done, had replacement without AS once (I appreciate it even more since).
      05-28-2014, 10:09 AM   #5
robydg63
Thanks 1230vani, ease of parking was one of the considerations, glad to hear that pairs well with the M package
Looks like I will order A/S, this will (probably) be my final build:
F15 3.0d
Carbonschwarz
MSport
Nappa Mocha Leather with CS
Piano Black Trim
Vision Packet (HUD, Speed Limit Info, Adaptive Led)
Drive Comfort Packet (Rear Camera, Surround View, Extended Bluetooth)
Connected Drive Services
DAB
Harman&Kardon
Tinted Rear Glass
Active Steering
      05-28-2014, 10:54 AM   #6
gorun
gorun's Avatar
46
Drives: W166 ML63 PP
Definitely get it, I did not go for AS and now I regret it. Standard steering is very dull, slow geared, it is on the heavy side and the car is not very maneuverable at all. AS will help remedy some of that.
      05-28-2014, 04:12 PM   #7
robydg63
Thanks Gorun, I'm back to my original opinion, that in fact I changed partially because of the forum. Now the same forum suggests to me otherwise.
This site is priceless
      05-29-2014, 05:54 PM   #8
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
I had it in both my 545 and 550 and would never get it again. Personally I don't feel it helps. Yes in a parking lot but in std driving. I actually did not like it and there were times when you could feel the ratio change in a turn if taken a certain way which was unsettling.
I can say this, AS does add to the steering complexity and with that comes repairs and replacement. The AS failed in my 545 and they had to replace every single component down to the steering column. I also had to deal with AS errors in both cars.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      05-30-2014, 02:47 AM   #9
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
Sorry to hear about your experience, I had zero AS issues on my X6 (3 years, 55,000km). Did not like AS on the 5 series for some reason also. Basically anything can go wrong on a BMW but I am no longer objective (for a very long time).
