11-03-2022, 07:12 AM | #1 |
Rep 41
Leaking Windscreen Water Canister
So my Water Canister for the wiper cleaning system seems to have a rather bad leak.
i fill it, and in slowly pours back out over the course of a few days until it' dry. is this an easy fix? |
11-03-2022, 08:41 AM | #2 |
Rep 2,912
Depends on what you mean by easy. Too me it's easy. But I don't know what tools you own or what capabilities you have. If you mean easy for a mechanic to do, then yes.
11-03-2022, 08:45 AM | #3 |
Rep 2,912
But you first need to assess the issue. You may have a cracked reservoir, or a bad hose connection. If your car is like all recent BMWs, you have to remove the front wheel on whichever side it's on and remove the plastic wheel liner to see the reservoir.
11-03-2022, 09:23 AM | #4 | |
Rep 662
Anyways, there's no other way around because the reservoir has a good amount of bulging cavity that extends well between the fender and the body framing. So if you dare removing the fender, you can easily replace the reservoir. I'm quite mechanically inclined to which I'm able to cherry-pick the engine out and rebuild it. And the reservoir job took me 3.5 hours total.
