02-16-2015, 02:22 AM | #1 |
Rep 67
Fog Light Issue When Switched to Auto
When the headlight switch is in auto mode (all the way to the left) and it's dark out (thus triggering hull headlights) I noticed that the headlights come on (good), but so does one of the fog lights (always one, not none or both). If I push the fog light button (still in auto mode) the other fog light comes on (both on), and when pressed again it goes back to one fog light illuminated. When switch is set manually to parking or Headlights on, this issue does not occur (fogs stay off). Wondering if this is a software issue. Has anyone else experienced this? I can't imagine it would be designed such that headlights + one fog light illuminated would ever be an option.
02-16-2015, 02:40 AM | #2 | |
Rep 1,368
Maybe its a wiring fault with your car? |
02-16-2015, 02:56 AM | #3 |
Rep 1,377
Is your steering wheel centered when this happens? The cornering light feature illuminates one of the fog lights in the direction you're turning at low speeds. The same also happens when you engage the turn signal.
02-17-2015, 06:59 AM | #4 |
Rep 450
Ah, yes, the fog lights are turning lights on US spec vehicles aren't they.
02-17-2015, 07:02 AM | #5 |
Rep 11,839
Drives: MY24 G01 AW Msport
moving steering wheel to either direction will have one of the fogs go on. try it.
also when you shift reverse both fog lights go on (fog light switch off) |
02-17-2015, 07:05 AM | #6 |
Rep 450
I can understand the turning lights but not both front fogs on then going in reverse, what's the point of that?
02-17-2015, 10:47 AM | #7 |
Rep 11,839
03-25-2015, 04:39 PM | #8 |
Rep 67
wdimagineer, you Sir, are correct, thanks! I straightened the wheel completely while stopped (with the car on) and both fogs were out. I find it a little weird, but glad I know now that it's "by design."
03-25-2015, 09:59 PM | #9 |
Rep 3,990
Yep, this is an old BMW feature that's been implemented for some time. We had this on our 2011 X3 as well when turning. Not sure how far back this feature dates.
