      04-02-2016, 11:00 PM   #1
Pastor Passum
Drives: 2016 X5xdrive
Headlight Adjustment on startup
Please excuse me if this is a stupid question but...every time I start my X5 at night the headlights seem to go through an adjustment cycle. They pan from level to high, back down to low and back to level. Not like switching from low to high beam but rather smoothly like there is a movable reflector in the unit. I'm guessing there is a auto leveling system for the lights and it cycles through the extremes on startup. Anyone?
      04-02-2016, 11:14 PM   #2
pragueX5
pragueX5's Avatar
Czech_Republic
156
Drives: 2021 X5 M 40d mildhybrid
all is fine.
Every Xenon headlights do this regardless the car make/brand.
Imagine the lights do swivell like this while you drive as well. that is so they do not blind the cars coming towards you.
there are kind of "gyroscope" control units on the front axle that do this. to ensure the light hight level illumination is constantly at the same level/angle towards the road
fo example if you are coming up a hill top /horizont it lowers the light patter down the road sonyou dont shine way too up blinding the car coming towards
you should see Volkswagen xenons, they put up bigger show on startup
      04-02-2016, 11:16 PM   #3
Neuera09
It's normal. Nothing to worry about. Wait til you remove the 8S4 from your FA.
      04-03-2016, 03:11 AM   #4
leasehackr
Drives: X5, 530e
What removing 8S4 does to the light?
      04-03-2016, 08:03 AM   #5
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Yep, the lights swivel at start up to show that everything is working fine.. Once they stop swiveling at startup thats when you should worry.
      04-03-2016, 11:41 AM   #6
Neuera09
You activate the Variable Light Distribution. Lay man's term, your headlamps move with your steering wheel.
      04-03-2016, 01:03 PM   #7
Doanster
Doanster's Avatar
627
Not true. VLD changes the light spread depending on city vs rural conditions, etc.
Adaptive lighting, i.e. lights move when turning, etc., is standard.
The master coding thread has the clear description of VLD.
      04-03-2016, 04:15 PM   #8
Pastor Passum
Thanks for all the replies. My first time with xenon headlights and my search turned up nothing. Here's hoping they continue working as intended. Much appreciated.
      04-04-2016, 03:58 PM   #9
ano0oj
Drives: '22 M3 AWD, '23 Macan S
Originally Posted by pragueX5 View Post
all is fine.
Indeed! My touareg's startup procedure for the xenons was kind of cool. They'd go from down to up, then side to side.
      04-04-2016, 08:04 PM   #10
alphaod
alphaod's Avatar
I think all the VWs do that.
      04-04-2016, 08:10 PM   #11
Kzang
Kzang's Avatar
3240
My 2007 & 2013 E60 also went up/down and side to side at start up.
      02-10-2018, 09:22 PM   #12
Dmitry777
Drives: Bmw X5 35d F15
Headlight adjustment
Hello community. this is my very first time ever creating a post. So please excuse if I am doing something incorrectly. In my case I had perfectly working and bright low beam.......until I took car to dealer for alignment.....after they done alignment, they forgot to reconnect leveling sensors by rear wheels....so they connected them back and now lights do level themselves, however low beam seem not being as fas as it used to be. Before I didn't even have to turn high beam, except when on very dark highways....I also remember, that before, when I turn lights on, they would level until certain point, and then go 2 more steps up. Now they just level to certain point (I couldn't see them doing those 2 steps up). Please advice, if there is any way I could raise them manually, or adjust that zero point (Idk how it is called)....Thanks everybody in advance....and I look forward for your reply people....
      02-12-2018, 12:11 PM   #13
tntp
Drives: 2015 X5S35i
You can manually raise the beam, but please do it carefully so that you don't blind people driving at night. A good reference point is to raise the beam so that you still cannot see the heads of people sitting in another sedan (not SUV) about 100-200 feet from your car on a leveled surface. There is a white plastic screw hidden on top of the headlight on each side for manual adjustments. Just google it for the picture if the screw location.
