10-01-2020, 07:33 AM | #1 |
Rep 893
ISTA+ Ethernet cable setup
I followed the directions that came with my ISTA download from Bimmer Diagnostics and for some reason I keep getting the Check vehicle interface and 'PAD active' error.
I searched and found this thread and followed everything he did to fix it to no avail: https://mhhauto.com/Thread-ISTA-D-connection-problem Ive seen a couple threads that mention checking the Ediabas.ini which is fine. I also checked the registry files and turned the online mode to true and I still get the same error. Any idea what could be causing my connectivity issues? |
10-01-2020, 10:51 AM | #2 |
Rep 2,516
Assuming you are trying to connect it to your E90 not F15, check here
https://www.bimmerfest.com/threads/i...ating.1375799/ |
10-01-2020, 11:21 AM | #3 | |
Rep 893
10-01-2020, 12:10 PM | #4 |
Rep 2,516
Which cable are you using? E-net or ICOM?
Check the installation guide here https://f15.bimmerpost.com/forums/sh....php?t=1568962 |
10-05-2020, 08:11 AM | #5 |
Rep 893
I'm using an ENET cable.
I figured out my issue. I had to go into the OBD.ini and change the COM port from 9 to 1. Thanks for pointing me in the right direction @RED_Y_ |
Maverik2594144.50 |
10-11-2020, 08:50 PM | #6 |
Rep 7,162
i like that they package it all as a single download. and for $20 i decided to delete my current version and get there set up. Curious though, do they send you an email with the download or how does it work. how long did it take to receive the download. need to replace my transfer case fluid before a trip later this week and need ISTA to reset the parameters.
10-11-2020, 09:39 PM | #7 | ||
Rep 1,025
Maverik2594144.50 |
10-12-2020, 02:39 PM | #8 | ||
Rep 7,162
10-12-2020, 03:06 PM | #9 | ||||
Rep 1,025
Maverik2594144.50 |
10-12-2020, 06:16 PM | #10 | ||||
Rep 7,162
10-13-2020, 02:02 PM | #11 |
Rep 893
yeah, my download took hours.
Also, its not 100% set up, there are a few things you need to do on the back end after you install it for it to see your car and the cable. The link above walks you through it...except for the 1 issue I had. I changed my transfer case fluid this past weekend and got everything all sorted in ISTA. |
