04-12-2024, 04:01 PM | #67 |
Rep 3,043
5-7K for a manual? I think it's more chief. Each to his own but I cannot speak highly enough of the cab, it feels more spacious, on the right road the air in your hair adds a lot to the experience and changing down a gear or two is a great noise.
04-12-2024, 05:27 PM | #68 |
Rep 1,550
Just saying from what I've been seeing and trying to reconcile car mileage and options. USD, btw. Cannuck bucks would be more.
- Jeff
bosstones' flickr |
04-17-2024, 03:31 PM | #69 | |
Rep 227
jesm207.50 |
04-17-2024, 05:03 PM | #70 | |
sportscars only
3295
Rep 3,217
jesm207.50 |
04-18-2024, 04:21 AM | #71 |
Rep 564
They are the only company that still appreciates engineering and is driver-focused. I think for what they are, it's pretty fair. I would have thought platform sharing and VW would have at least kept costs in check, but they never really strayed too far from that 3000-pound weight even with all the emission and safety regulations, where an m3 is now close to 4000-pounds. Unsprung and total weight loss mods are a lot more expensive than just adding power..
jesm207.50 |
04-18-2024, 08:44 AM | #72 | |
Rep 227
Llarry16728.00 |
04-18-2024, 10:03 AM | #73 |
Rep 564
Manufacturing the car together is the ez part. If you have ever spent time trying to lighten your car, you will understand how insanely costly it can be. Engineering the car to be light, with airflow, flat under floors, brake ducting, lightweight materials, a oiling system for track, high QDR, and the ability to truly option your car to the extreme. Imo likes Ap vs. Brembo
04-18-2024, 06:03 PM | #74 | |
Rep 227
04-19-2024, 11:13 AM | #76 | |
Rep 5,389
I test drove a 2023 Miata RF for an hour when looking at cars a couple of years ago. It is a light car, but much smaller than the 987/981/718 in terms of interior and storage space and it doesn't feel remotely has well put together. While on paper, my 265hp Cayman and the ND2 Miata have similar power to weights, but when driven, the Cayman feels way faster. Handling wise, stock to stock, it's not the same ball game and the Cayman is 11+ years older. The ND Miata is freaking awesome, especially the 2025 model, but Porsche 911s and Cayman/Boxsters are on a different level. You can get a new lower optioned Cayman Base for mid $70s. That's only twice the price of a 2024 Miata RF and is twice the car in terms of performance, quality, comfort, and usability, IMO. Point being, 911s and Cayman/Boxsters could be a few hundred pounds lighter if Porsche wasn't so hell bent on making such solid cars. It's surprising to me that my fully loaded Cayman still is under 3000lbs with a full tank per the local truck scales.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
slilley51.50 |
04-20-2024, 09:10 AM | #77 |
Rep 54
Former 997.2 911 C2S owner, current 718 Cayman GTS4.0 owner, and former Miata NC owner. I track and autocross my cars, and these three cars couldn't be more different! Each is designed for a different purpose, and has a completely different feel - although the 911 and Cayman are similar except when driven at their limits. The Miata is a blast on back roads, but in it's OE-form it's a frustrating track vehicle with that suspension that's designed to be so much fun on the street. But for not a lot of money, it can be converted into a car that's much more fun at track and autoX with simple suspension upgrades. The Porsches - all Porsches - can be driven straight from the dealership to the track and they perform exceptionally well right out of the box. They are almost boring on the street, because they are so composed that they really have to be pushed for the same level of fun. Dollar for dollar though, nothing beats the fun of a Miata. I just wish they'd offer a more performance-oriented suspension from the factory.
04-21-2024, 03:36 PM | #78 | |
Rep 227
It's a small 2WD two-seater, made mostly out of aluminium, with a small 4 cylinder engine. 3000 lbs isn't all that impressive for that kind of car IMO. Last edited by / / / M3; 04-21-2024 at 03:41 PM.. |
04-22-2024, 11:26 AM | #79 | |
Rep 5,389
I can't tell any difference in build quality/material thickness on the 981/718. They seem just as "heavy" and robust as my 987. A Miata RF weighs around 2500lbs. A 987 Cayman weighs around 2950lbs. The current gen Miata is substantially shorter (18") and narrower (3.5") than the 987-718 Porsches. That certainly accounts for some of the weight differences. Put a Miata and 987-718 on a lift and look at how much more substantial the parts are on the Porsche and you'll see why they feel so much more solid. The Miata uses lots of stamped parts whereas many of the parts on the Porsches are not. The interior carpet on a Porsche is thick and of high quality especially when compared to the super thin and lightweight stuff used on a Miata. The carpeted 3" thick foam panels that cover the front and upper engine covers on my 987 weigh a whopping 41lbs total. The Miata and 987-718 take different approaches to performance and quality. I'm not saying a brand new Porsche is worth the price for what you get, but I'd have to say an entry price of ~$39K for a commonly equipped Miata RF is pretty crazy too.
slilley51.50 |
04-22-2024, 01:44 PM | #80 | |
Rep 227
As for weight, if you don't like the Miata comparison, how about the Supra? It's a couple of inches longer and wider than the Cayman but only 100 lbs heavier (if you compare 4 cylinder version of each car). Then you have the Toyota 86/Subaru BRZ, which is about the same width as the 718 Cayman but a few inches shorter. And about 200 lbs lighter. Like I said, there is nothing particularly impressive about Porsche's weight. It's pretty average considering the size of the car. |
05-06-2024, 09:33 PM | #81 |
Not willing to take advice
4106
Rep 1,534
Well, as posted in the OT thread, for what it's worth...found 981 Boxster S manual with 19K miles. Sport exhaust, premium pkg, and 14 way power seats. Picked it up last Saturday. Let a couple 911s slip away...but I'm happy with this.
Proud owner of 4 Turbos and 1 Supercharger
5
05-09-2024, 09:29 AM | #82 |
Rep 5,389
Congrats! Nice ride and spec. I hate to say it though.....the M4 will likely sit a lot. I bought my 2011 Cayman 6MT back in October 2022 and the plan was for it to be my "fun" car and I'd drive my modded M235 6MT most of the time. I drive the Cayman 90% of the time and the M235 barely gets any miles. Even though the Cayman is slower, everything else about it so much more enjoyable and fun. It does break my heart to see my M235 sit, but when given the choice, it's the Cayman every time unless it's raining, snowing, or I need the space.
05-12-2024, 03:33 PM | #83 |
Rep 1,550
Well...I failed. "You should get the one you want," says the wife. "I like the vents," says the wife. 3.8L of naturally aspirated, aural bliss is now in the garage.
No cats.
- Jeff
bosstones' flickr |
05-17-2024, 11:11 AM | #84 |
OPN DIFF
479
Rep 1,911
Drives: 10' E90 M3 6MT LB
While they share lots of similarities, the driving experience is way different especially when driven hard.
'10 LB E90 slicktop/speed cloth/6MT ex. '06 330i 6MT & '10 n54 6MT Msport Autocross vids https://www.youtube.com/user/tigermack https://www.instagram.com/tigermack |
05-17-2024, 12:32 PM | #85 | |
4106
Rep 1,534
I've never had an experience like this Boxster. Eggs you on to go in to turns fast and keep accelerating, instils confidence and flat out like nothing I've ever driven before. This has glue for tires. While the acceleration is nothing like the M4 - don't think I mind. Don't know if a 911 is better than this or not...but damn, this is a fun ride for sure. Sadly though, wife insulted me and said it drove like a small sedan. So that hurt.
