03-25-2019, 02:57 PM | #1 | |
N00B
94
Rep 210
3/25/2019 - Work In Progress
So I finally decided to upgrade the bass in ye old X5. I want to do it in the most Plug and Play way possible. This is a work in progress and as things are shipped to me, I'll post updates/step by step with links and Q/A (that I can answer). Here is just a list for now, I do have some pictures queued up with the box fitted/cutting and bending some metal just a pinch and sanding some of the box down. Please dont go buying the stuff I bought till I learn for you guys . If any of you have advice or suggestions, let me know. Current Options X5 (F15) with S4UBA 3rd seat row / S2VMA ADAPTIVES FAHRWERKSPAKET COMFORT / S2VPA ADAPTIVES FAHRWERKSPAKET DYNAMIC / S6F2A BangOlufsen High End Surround Sound Quote:
Electrical Stuff (Work In Progress) Fuses! Fuse Tap #159 from rear fuse panel (5amp) -> Battery Isolator Relay. This should allow the isolator to flow 12v power to secondary battery when the head unit/B&O amp turns on. 100 amp in line fuse between Main -> Secondary Battery 100 amp in line fuse between Secondary Battery -> Aftermarket Amp 1 amp in line fuse between Secondary Battery -> LC2i LOC VSD Diagram (Work In Progress)
The owls are not what they seem!
03-25-2019, 08:48 PM | #2 |
<3 Flat Four
217
Rep 754
i was toying with the idea of adding a sub as well, but since u have 3rd row seating i assume u dont have the empty space (spare tire well) in the trunk? it has abt 9in of depth to it so fitting an 8in sub with box shouldnt be an issue. im planning to add an 11" sub. good choice on the audiocontrol n nice find on the harness.
2011 335is Le Mans Blue
03-25-2019, 09:05 PM | #3 | ||
Rep 413
I am sorry to point it out, but 1 - you made a mistake by going with 8" sub/subs. Are you adding 1 or 2 of them? 2 - don't think those subs will fit in the custom box you ordered, which is a shallow mount box... |
03-26-2019, 01:24 AM | #5 |
<3 Flat Four
217
Rep 754
the sub mounting depth is 5.04in according to the manual. the subbox allows 130mm depth subs which means 5.11in, just barely fits.
03-26-2019, 08:14 AM | #6 | ||||
N00B
94
Rep 210
1. No mistake on the sub 500ish watts rms is enough for me and literally pushing the limits of this enclosure/space available, just 1. 2. Hence me asking for an extension ring to be added when they manufactured it. Even the cu ft is off by a bit but the polyfill will offset it. Fits perfectly, 1/4 inch "ish" of space under the magnet. 3. Relay; You may be right... but my f15 has every option except m sport. I would rather not have a ghost in my electrical or any extra "draw". I've followed the forums long enough now to know that electrical can be a game of cat and mouse hence completely separating it.
bmwx1sq145.00 |
03-26-2019, 08:27 AM | #7 |
Rep 29
Thanks for the info here. I have a similar X5 with the third row so it's interesting to see should I ever get motivated to do the same.
Very interested to see your thoughts on the overall improvement. |
Twin Peaks94.00 |
03-26-2019, 01:28 PM | #8 |
Rep 277
Nice setup!
Still working on mine. Still need to make the cover panels. |
Twin Peaks94.00 |
03-26-2019, 04:51 PM | #9 | |||||
Rep 413
[QUOTE=Twin Peaks;24568849]
I've installed 2 10" JLs and the bass is barely deep enough for me lol |
bmwx1sq145.00 |
03-26-2019, 06:33 PM | #10 | ||||||
Rep 413
[QUOTE=duercos;24571393]
Ordered 3 different sub boxes, had to get shallow mount subs instead of regular ones (which I sell in the classifieds ) then I had to make cutouts bugger in these current boxes as they claimed to be 10" holes, but they were too narrow for my JL TW3s.. |
03-26-2019, 09:22 PM | #11 |
<3 Flat Four
217
Rep 754
what model r these subs? trying to get an idea of the box i need to build. and if u could, dimensions of the box? much appreciated.
03-26-2019, 10:48 PM | #12 | |
Rep 413
Like I said, I had to manually make the cutouts larger by cutting them with a knife first and then sanding them down |
03-28-2019, 11:56 AM | #13 | |
N00B
94
Rep 210
Bass isn't just the "lows/boom", its more so the frequency of the sound and your picture shows me that your speakers are concealed... let them breath! Can you share a video of them with a bass heavy song on and all opened up? I would love to see the excursion of them both. Can you also show a video from the driver seat with them turned up and everything closed/normal?
03-28-2019, 12:56 PM | #14 | ||
Rep 413
[QUOTE=Twin Peaks;24579976]
Twin Peaks94.00 |
03-28-2019, 06:30 PM | #15 | |||
N00B
94
Rep 210
[QUOTE=duercos;24580277]
Also, I have the same stuff going on with family/space requirements hence the tiny box near the fuse panel.
03-28-2019, 06:38 PM | #16 | ||||
Rep 413
[QUOTE=Twin Peaks;24581835]
Twin Peaks94.00 |
03-31-2019, 07:50 PM | #17 |
N00B
94
Rep 210
90% install done (video up top), I still need to put matching carpet on the box, tune the amp, and figure out why my lc2i isn't powering on when the amp turns on like I wired it to (the battery isolator turns on via 12v on the b&o amp on signal). There is a major difference and when the weather gets better I am going to show more of it.
bmwx1sq145.00 |
04-01-2019, 12:44 AM | #18 |
<3 Flat Four
217
Rep 754
can u show a picture of how the harness plugs in between the oem amp and oem wiring?
04-30-2019, 04:21 PM | #20 |
Rep 2
Thanks for posting! I am really underwhelmed by the mid-lows and lower in the F15 HK system, and this really looks like the easiest plug and play solution.
04-30-2019, 11:12 PM | #21 |
Rep 277
06-17-2021, 06:24 AM | #22 | ||||
Rep 18
Tags |
audio, bass, stereo, subwoofer, technicpnp |
