04-01-2017, 04:42 PM | #1 |
Rep 709
Dinan Exhaust Owners: Happy? Would you still buy?
Hi All:
I'm trying to decide on an aftermarket exhaust, and I'm wondering how happy folks are with their Dinan setup. I want a throaty exhaust, not a raspy exhaust. Dinan seems to be the way to go, but I'm curious if there is any buyer's remorse? Thanks in advance! All recommendations are appreciated. |
04-01-2017, 11:06 PM | #2 |
Rep 8,815
I had Dinan and now Eisenmann Race.
For me Dinan was too similar to stock. Id say its maybe 10-15% louder to my ears. I got an exhaust for this car for sound not for power so to me i wanted something significantly louder than stock. The Eisemann race is a much louder system but doesn't drone on the highway either. Deep bassy tone. Sounds perfect to me. Alan
TonySCV510.00 |
04-02-2017, 07:56 PM | #3 |
156
Rep 346
I didn't notice enough difference over stock with my Dinan. If I had to do it over again I'd get a different exhaust or leave it stock.
TonySCV510.00 iconoclast7265.50 |
04-04-2017, 11:39 AM | #4 |
Rep 12,654
Dinan is a pretty solid choice if you are not looking to go really loud. Eisenmann race is a significant change in volume. I have a slightly used Eisenmann Race if anyone is interested.
04-09-2017, 12:34 PM | #6 |
Rep 25
I wanted something louder than stock, but not obnoxious. The Dinan was a good compromise. It was relatively cheap, dealer-installed and no drone. I don't know that something 4 times more expensive would be that much better.
iconoclast7265.50 |
05-18-2017, 09:41 PM | #9 |
Rep 176
Drives: 17' X5M/91' 325i
Garage List 2017 X5M [0.00]
2014 X5 50i MSport [0.00] 2011 X5 35i SA [0.00] 2007 X3 3.0si [0.00] 2007 335i [0.00] 2003 330Ci [0.00] 1991 325ic [0.00] |
Just adding to this thread...as it helped me make my decision on a new exhaust.
Thanks to Ryan@IND for bringing the Eisenmann over to Fall-Line for the install this morning. I went with the Race w/4x102mm black chrome tips (thanks Alan L for the pics of that white beauty you have, really helped make my decision). Couldn't be happier with this exhaust - in my opinion this is the exhaust this car should have come with from the factory. It's an M and you should be able to hear it. Admittedly, the stock exhaust sounds fine in sport plus mode and is actually pretty tame in efficient mode on the highway, but I didn't buy this car to feel like I was back in the 50i MSport I just sold. Side note - the 50i MSport is not a bad car and I was very happy with it during the 3+ years I owned it before the M. There is a little bit of drone on the highway, but in my opinion it is manageable. I'd trade that in any day for the sound this thing makes off the line. Shockingly, warm idle is pretty quiet... Now I can't wait until after the break-in to get the Dinan Stage II installed to see how that changes the sound...leaves me just enough time to black everything else out
17' X5M LBB
91' 325ic - Bril Red, Full Dinan Spec (past) 14' X5 50i MSport - Min White (past) 11' X5 35i SA - Black Saph (past) 07' X3 3.0si MSport |
05-19-2017, 09:26 AM | #11 |
Rep 280
I just installed the Eisenmann Race Exhaust and it sounds amazing, just like this car should, but it is significantly louder than stock (specially compare to "efficiency" mode). It will be amazing if they made this exhaust and it had the options to have valves for a quitter ride. You will get some droning on the highway, I disconnected the induced sound, and it is slightly better, but the cabin is definitely louder than it used to be. If you like the quite cabin as it is stock, I would not go with this exhaust, but if you are willing to compromise slightly to have this car sounds as is should it is probably the best option!!
You might want to consider a valve exhaust (like the Eisenmann Sport, Akrapovic or Dinan) with catless downpipes. Assuming budget is not an issue. |
05-21-2017, 10:38 AM | #12 |
Rep 736
What's the difference with x pipe? I heard it's a waste
www.mgruppe.org
05-24-2017, 12:39 PM | #13 |
Rep 944
exhaust
the stock exhaust actually sounds pretty good but no options to switch tips
main reason why i went with Manhart. very pricey but only option at the time. the note was tame but a little louder than stock. the exhaust tips alone made it worth it. I added HFC downpipes and that opened up everything. love the sound now. regarding the question about needing x-pipe, its needed but you prob dont need MSR. there are cheaper options if you dont care about cutting your stock exhaust and what it looks like. DME tuning that has the first set of MSR intake prototypes has an ebay special x-pipe, talked to him and said its the perfect size to replace the oem resonators. he has videos on IG, sounds so much better. the car should of came with a x pipe |
iconoclast7265.50 |
05-24-2017, 02:45 PM | #14 | |
Rep 736
www.mgruppe.org
05-25-2017, 10:12 PM | #15 |
Rep 201
I had the Dinan tune, drop and exhaust on my 2012 X6///M which worked really well and never regretted it for a moment. I got the Akrapovic exhaust a couple of weeks ago for my F86 and LOVE it - amazing (perfect) look and sound.
TonySCV510.00 |
06-03-2017, 01:24 PM | #16 |
Rep 234
06-05-2017, 08:20 PM | #17 |
Rep 736
My buddy has that setup, and you will be surprised dinan sounds louder then akra even with xpipe installed
www.mgruppe.org
06-06-2017, 10:24 AM | #18 |
Rep 234
01-17-2018, 05:53 PM | #19 |
Rep 1,328
Bumping this as it seems to have the most comprehensive discussion on various exhaust options for the X5M.
From what I understand, Eisenmann Race - Great sound, very loud (loudest), no valves, some drone Eisenmann Sport - Close to stock sound, louder than stock, valved, no drone Akrapovic - Best sound, louder than stock (not loud enough), valved, no drone FI - Great sound, louder than stock, valved, no drone Is this correct? Happy for anyone to chime in any add to this or correct me.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 |
iconoclast7265.50 |
01-17-2018, 06:15 PM | #20 |
Rep 4,532
Akra gets louder with miles. Other than crazy expensive, it’s perfect if you want a 15% increase in sound with the valves open and zero drone with the valves closed. If you want LOUD with the valves open, it’s not for you.
01-17-2018, 06:44 PM | #21 |
Rep 1,328
Thanks.
It seems as though there is no real valved option which is particularly loud with valves open and more sedate with them closed. I'm not sure I could justify the Akra cost when it's so little difference over stock, and that goes for Eisenmann Sport also. Guess i'll just have to stick with the Eisenmann Race and destroy my neighbors ears. They cop it already with the MPE I have on the M3.
01-20-2018, 06:28 PM | #22 | |
Rep 944
Valved Exhaust with high flow Downpipe’s is the best of both worlds.
Dinan is really too quiet and sounds almost stock. But there are plenty options I am running Manhart which sounds great with my DP but if the FI System was out earlier that would be my choice. Slightly louder in efficient but much louder in sport. Has a very unique tone Quote:
