05-20-2017, 02:49 AM | #1 |
Rep 123
Filling up tank quirkiness
When filling up any car, I typically pump until it clicks. On most cars, it clicks when the tank is full. Additional pumping just leads to quick follow-up of clicks from the pump.
However, on my X5, if I stop at the first click, the fuel gauge doesn't reach full. Instead after the 1st click, if I keep pumping, I can get another ~1gallon or so before the 2nd click. At this point, then the fuel gauge will read full. On other cars, this type of behavior can happen if I run the tank really low; however, on my X5, it seems to happen all the time, even if I refill on a 1/2 tank. Anyone notice this? |
05-20-2017, 10:50 AM | #3 |
USAF Retired
207
Rep 216
Drives: F15.50i
LOL!
I try to fill up when my tank is half full (or half empty for those who think this way) to help cut down on fuel costs. OP, I haven't had mine long enough to notice any discrepancies, but when I topped her off the other day, it was one click and a full tank read on the gauge. |
05-20-2017, 10:53 AM | #4 |
<3 Flat Four
215
Rep 754
it all depends on the fuel gun/pump ur using. some dispenses fuel at a faster rate and some slower. the faster ones will cause back splash or the tank to "burp" triggering the gun to stop.
2011 335is Le Mans Blue
05-20-2017, 10:15 PM | #5 |
Rep 8,808
My 2015 X5 35i didn't do this but my 2016 X5M does. It's annoying that after it clicks I can get atleast another gallon in. If I don't my fuel gauge is just a hair below full. Considering how much gas the M chugs I need every gallon I can get lol.
Alan |
05-21-2017, 02:21 PM | #7 | |
Rep 214
having said that, I generally try to not get too far below half-full....that's the way I was taught. I find that filling until the pump clicks off, then bumping to the next nearest $0.05 usually results in the fuel gauge landing on "F".
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota |
pokerface429.50 |
05-22-2017, 08:55 AM | #8 | |
Rep 865
But who really cares right? We don't really drive these cars for the gas mileage.
2003 BMW 330i
2016 BMW M4 - ED May 2016, PCD Aug 2016 2017 X5 xDrive35i - PCD Jan2017 |
Kzang3238.50 |
05-22-2017, 09:19 AM | #9 | |
Rep 214
now, back to the topic at hand
05-22-2017, 01:27 PM | #11 |
Rep 472
05-22-2017, 03:15 PM | #12 | |
USAF Retired
207
Rep 216
Drives: F15.50i
05-22-2017, 10:48 PM | #13 |
114
Rep 346
You guys that do this top off thing are filling the evaporative recovery system with gasoline and often make it difficult for the next person to get the pump to start filling. Many times I have had to pull the rubber sleeve on the pump backwards with the nozzle pointed down and watch the gasoline pour out because of this topping off obsession.
Not good. |
05-22-2017, 10:56 PM | #14 | |
Rep 211
05-22-2017, 10:59 PM | #15 |
114
Rep 346
Have had it happen many times. Have you ever seen the sign on the tank to NOT TOP OFF?
http://clark.com/cars/why-you-should...your-gas-tank/ |
MN2///M521.00 |
05-23-2017, 03:35 AM | #18 |
Rep 123
Sounds like I am not the only one seeing this. Kind of annoying at first, but now, I just know to pump again after the first click. Wonder what is causing this...
05-23-2017, 08:57 AM | #19 |
85
Rep 331
This happens to my car once in a blue moon. Not sure what triggers it, but the pump will stop before the gauge reads full. Most of the time it works fine though.
A half tank is really conservative - you still have a good 150 miles in your tank at that point....I thought I was bad with not letting my tank get below a quarter. |
05-23-2017, 08:59 AM | #20 | |
85
Rep 331
05-23-2017, 09:06 AM | #21 |
Rep 8,808
Correct.
I've never had the issue apple corps described at any gas pump either. If i let the gas attendant fill up the gas he would usually stop right at the first click. As a result i leave the gas station with my fuel gauge a hair below the full mark. If i do it i usually get another half gallon in and my fuel gauge is right at the full mark.
05-23-2017, 09:55 AM | #22 | |
114
Rep 346
The symptom the next customer experiences is a pump that triggers off as soon as they try to pump - squeeze the handle again and it triggers off. Pull the nozzle out of the filler tube - pull the rubber vapor shield back and watch liquid gasoline dribble or flow out onto the concrete - the pump recovery has been over loaded. Reinsert and squeeze the handle and all is well. I guess my perspective was when the gas pump stops the tank is as full as it will get with the vapor recovery requirements in place. I have also experienced on older Bimms that the fuel gauge would show slightly less than full and after a few minutes of driving the gauge would show a full tank. |
