05-24-2017, 09:22 PM | #1 |
Rep 275
Skeptical of tune/piggyback numbers
Been on here awhile and read lots of threads on Berger, Dinan, RaceChip, etc and remain skeptical about real world numbers. I have a 50i and would love to increase the power but for those of you who have pulled the trigger on a tune/piggback, what kind did you get and can you REALLY notice a difference worth the $$?
05-25-2017, 07:25 AM | #2 |
Self-Deprecating Narcissist
7258
Rep 6,561
i have not seen any dyno plots from any member who installed a tune. unless someone can post before and after factual data it is all "butt-dyno" and in some cases some individuals lost power going with some jb products.
05-25-2017, 08:15 AM | #3 |
Rep 525
it was here , the guy with RACECHIP on his 35d shows pics and graphs with dyno measurements , after chip he got 299HP on the wheels , before it was 258 on crank .
05-25-2017, 08:32 AM | #4 |
7258
Rep 6,561
i have not followed diesel tune posts and threads... i was referring to 50i.
05-25-2017, 09:16 AM | #5 |
Rep 5,058
Here is a thread on the X5M which is tuned by Racechip piggyback and results are shown on the Vbox readings
http://f15.bimmerpost.com/forums/sho...highlight=dyno As far as the tune itself (racechip)for a 35i ( which I have ) is significant. So significant that I have re-installed it after installing MPPK.
05-25-2017, 09:58 AM | #6 |
7258
Rep 6,561
Does anyone have any before/after dyno plots for 50i?
05-25-2017, 10:00 AM | #7 | |||
Rep 648
Drives: 2016 F15, 2015 F83
For example, here is my post, including dyno numbers. About 50hp and 50ft/lb with a RaceChip Ultimate. And yes, I definitely noticed a difference.
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 05-25-2017 at 10:31 AM.. |
iconoclast7257.50 |
05-25-2017, 10:20 AM | #8 |
113
Rep 346
My MPPK install got delayed due to the time required for install - my X5 was an out of the area purchase.
So, could someone give a layman's explanation of the "piggy back" or stacking concept for the chips? My limited understanding is that BMW (MPPK) or Dinan examine the hardware components and remap the ECU and / or other software components to increase HP / torque. I assume this involves boost timing, boost pressure / tricking the MAF / injector timing / on and on. Those software adjustments are based on the stock engine. How do the stacked units know how to accommodate another chip's software impact? A crystal clear question |
05-25-2017, 10:27 AM | #9 |
Rep 5,058
My understanding is that it is hard to find a dyno machine that can handle AWD so a dyno is not as common as other RWD cars.
05-25-2017, 10:55 AM | #10 |
7258
Rep 6,561
I can refer people to a few in the NJ/NY/CT area.
05-25-2017, 12:01 PM | #11 |
Rep 648
And I know a shop in the RI / Southeastern MA area.
2015 F83 M4 |
05-30-2017, 07:56 AM | #12 |
7258
Rep 6,561
05-30-2017, 08:43 AM | #13 | |
Rep 8,774
MPPK is a flash tune by BMW that updates a ton of parameters giving you more power and sportier driving feel as well as more exhaust noise. Nobody really knows exactly what they alter (only bmw knows that) but i'm willing to bet things like boost, timing, fuel trims, transmission shift points all get altered. It is the right way to gain power so to speak. The complete package. Dinan, Racechip, Burger are all piggyback units that intercept one or two signals and report back to the ecu a lower value than it actually is making so the stock ecu readjust its settings to bump up the boost to make more power. Lets say the car's ecu is looking to see 14psi at this sensor. What the piggyback unit does is say its only making 12 psi so the ecu bumps the boost up another 2 psi so it can see 14 but in reality its making 16psi now. The problem with this is that all of the other parameters are set for 14psi not 16 so some say its risky while others believes the ecu is smart enough to make adjustments based on other sensors to still be safe. I would agree on the later because mildly tuned cars on piggybacks stills shows AFR's being in check and you don't have massive amounts of cars with blown engines considering how many are running these tunes now for years. Same concept applies when one has MPPK and stacked with another piggyback. The only difference now is your starting point is higher and you are just adding from there. Alan
4
05-31-2017, 02:20 PM | #14 |
113
Rep 346
Alan - thanks for your response. The explanation is consistent with my very limited understanding and the "stacking" concept is better understood by me.
Dinan advertises that they control all relevant parameters so as to avoid fault codes. Some considerable increases in HP/Torque are generated for around $2k. OTOH, the BMW MPPK sounds more in line for my wants - reasonable HP/Torque improvements at mid to higher range RPM. If my wants are much greater than the MPPK I probably should have gone with another V8 - which they aren't and I did not :-) Thanks again. |
05-31-2017, 02:27 PM | #15 | |
Rep 648
I would do what you already did: start with the MPPK. You can always add a piggyback if you want even more power.
2015 F83 M4 |
05-31-2017, 03:12 PM | #16 |
Rep 8,774
ah yes. Dinan's kit basically T's off right at the main ecu so in theory they can alter whatever they want. From my years of being on this forum Dinan's approach is a double edge sword. It can be the better way to extract power but it also be a lot more complicated to track down issues related to the tune. Typical piggies just alter one or two signals and leave it up to the ecu to alter the rest. Dinan alters more signals and that can sometimes cause a condition that will trigger a fault/CEL because some other sensor doesn't like what its seeing.
MPPK is the way to go on the 35i. If you want more just stack it with the Racechip ultimate to give you all the benefits of the MPPK but with a little extra kick. Alan
06-01-2017, 01:46 PM | #17 |
113
Rep 346
Well, after much deliberation I finally paid our dealer for the software - will take a few days to arrive - should be installed by next week.
I know there is a "decal / sticker" they place under the hood somewhere to alert the techs to a flashed ecu and possibly an emission control requirement. Somewhere I saw some type of MPPK emblem / sticker that goes on behind the front wheels. Not certain I want to add any additional badging but what do they look like and what quality (decal or sticker or emblem) are they - if they really come with the kit? Thanks |
06-01-2017, 05:30 PM | #18 | ||
Rep 5,058
I have a diy instructions on it.
06-01-2017, 07:07 PM | #19 |
113
Rep 346
Kzang - found it - what are your thoughts about the durability of the stickers given their location?
Also - thanks for your various responses to my questions. As I approached 900 miles I am pushing the X5 a bit harder ( I do a careful break-in) and am finding it quite powerful - but with a few very minor torque shortages that will disappear as the engine loosens up a bit and the MPPK does its magic. Remain very impressed so far..... Last edited by Apple Corps; 06-01-2017 at 08:28 PM.. |
06-02-2017, 07:05 AM | #20 | |
Rep 5,058
Originally, I was just curious as to how it would look... then I was going to remove it as it is reversible. but I like how it adds a nice subtle touch. My X5 isn't your average 300hp/300tq SUV... it has all the Mperformance appearance mods and Engine tune... so I figured why not Here is one iphone pic
06-02-2017, 08:35 AM | #21 |
113
Rep 346
Kzang,
Your comment - "My X5 isn't your average 300hp/300tq SUV..." is quite accurate as I searched through your posts Subtle I like - most likely will give em a go next week. |
