11-22-2019, 07:32 AM | #200 |
Rep 5,066
Figured I'd bump this with the influx of all the used X5 buyers.. they'd be happy to see a freebie in their secret storage compartment.
Jars914658.00 |
01-29-2021, 11:03 AM | #203 |
Rep 7,489
When I picked up my F15 X5 last year (July/2020)...I knew that it had the option that should include the cargo net. When I went to take it for a test drive...I took a peek after opening the left cargo panel...and sure enough...there was the brand new net still in its little plastic bag...never opened, never used.
I also got another surprise...the box in the pic below was still in the cargo area...and brand new floor liners were installed (front/rear)...and a quick peek into the box revealed a set of 4 oe rubber floor mats...used but still in good shape. Then when I got home and pulled the rubber floor mats out to give them a good cleaning since I prefer them over the floor liners...the original carpeted mats were also inside the box still in their original plastic bag...never used.
Jessethebody117.00 |
02-11-2021, 11:46 AM | #204 |
Rep 5,066
02-13-2021, 05:14 AM | #205 |
Rep 30
Found this net the day after getting the car!
However I never unwrapped it, still in the cubby with the plastic around it. What I have been missing is a net to put up behind the front seats, for when the rear seats are down. If you have nothing to hold the luggage in the rear it is bound to hit you very hard in case of an emergency braking or some accident. On the E39 wagons the rear "rollo" (the one with the luggage compartment cover and the net that goes up into the roof) served a double purpose - it could be moved forward and mounted to hooks in the roof and serve as safety for the front whenever the rear was loaded with stuff.. Now.. would this X5 mount in a similar manner? I´ve got to unwrap it and check! |
02-13-2021, 10:09 AM | #206 | |
Rep 7,489
{part nbr 51 47 7 332 111} If need be, you probably could use it horizontally to secure something laying on the cargo floor since it comes with the S493A storage pkg which provides the two “lashing rails” (#1 in diagram above) and four movable/lockable “lashing eye” tie-downs (#4 in diagram above). The rear cargo net used to separate the rear cargo area or the expanded cargo area that would connect to the roof liner down to the cargo floor is another item that can be purchased as an accessory: part nbr 51 47 2 286 421 In my opinion, the e39 was the pinnacle of cargo cover/cargo net design and implication. Not only were the two covers combined into the same “cassette”...but BMW also included a “holder” for the cassette when not in use to cover the rear cargo area. Let’s say you were out and purchased or picked up something you weren’t expecting to bring home but needed to remove the cargo cover due to the items height. In the e39, you simply removed it from its regular area and can mount it to the holders built into the riser of the rear bottom seat cushions. This could even allow you to carry a rear seat passenger if you only needed to lower one seat back to expand the rear cargo area...and the rear seat passenger wouldn’t have to worry about stepping on the cargo cover. This was also the location to put the cargo cover if you needed to use the separation net as well as using the expanded rear cargo area after folding down both rear seats to divide the rear from the front. Again, not sure why BMW abandoned this set-up after the e39...I found it to be the best in form and function. Again, this “flexnet” is only about 12”-15” high and is an “envelope” design that can be stretched across the rear. I use it everyday for my briefcase and lunch and is mounted across the rear at the tailgate. I open the gate and slip both down inside the net to prevent both from sliding/spilling on my commute from home to work and vice versa. I also use it if a go to the grocery store and purchase something that needs to remain upright (milk/juice/etc...or something that can easily roll...like a melon...or bruise/crush/crack like fruit/bread/chips/eggs. There’s also a larger net that is square that can be used to secure cargo horizontally in the cargo area. part nbr 51 47 9 410 838
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-13-2021 at 03:13 PM.. |
02-13-2021, 04:03 PM | #207 |
Rep 30
Qsilver7 That's very informative! I think I once searched for that part number, only to find it not available anywhere, discontinued I think. Do you know of a place that sells it? We often drive around with cargo and would want to bring more, but don't due to the safety aspects of not having such a net installed.. Talking about the 51 47 2 286 421
02-14-2021, 11:26 AM | #208 | |
Rep 7,489
Grobian61.50 |
02-16-2021, 08:26 PM | #209 |
Rep 48
Drives: '18 F15 xDrive35i
New F15 owner. I found the brand new net in the left side panel. However no sign of the 4 movable/lockable tie-downs. Can someone confirm the part number, I have 51477146024 from realoem but I'm not sure it is specific to 2018 F15.
"better the devil you know than the devil you don't"
2003-03-04 E53 X5 4.4i M62 [SOLD] 2006-03-16 E53 X5 4.8iS N62s [SOLD] 2006-03-28 E90 325i N52 [TOTALED] 2012-09-06 F30 328i N20 2018-01-18 F15 xDrive35i N55 |
02-16-2021, 09:29 PM | #210 | |
Rep 7,489
If you can access Realoem.com, then the answers to your questions could be right at your fingertips. If you see blue text on realoem’s site, it means that its a clickable link...which means there’s additional information. PS...did you look below the cargo floor? Perhaps the previous owner removed them and stored them in the place designed for them to be stored when not being used or not wanting them locked into the rails.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-16-2021 at 10:11 PM.. |
02-18-2021, 09:44 PM | #211 |
Rep 48
I looked before but will try again for good measure. Thanks
08-02-2021, 07:25 PM | #212 |
Rep 123
Drives: 2021 BMW M2 Competition
Garage List 2018 BMW X5 35d [0.00]
1970 BMW 2002 [0.00] 1991 BMW M5 [0.00] 2005 BMW 330 ZHP [0.00] 2021 BMW M2 Competi ... [0.00] |
Found it !!!
Just bought my 2018 CPO X5 35d and was skeptical when I read this post. What do you know.....went to the garage, pulled the panel and there it was!!! I love little Easter eggs like this.
08-02-2021, 09:42 PM | #213 |
Rep 74
Sad, mine doesn't have it. Previous owner added a tow hitch and that compartment gets opened up to add the harness.
Any recommendations on aftermarket nets? |
08-04-2021, 05:55 AM | #214 | |
Rep 7,489
You can order one from your local BMW dealerships parts department…or shop online. Just use the 11 digit BMW part number for the net which is #5 in the diagram below. This is the same info that was posted above in post #206.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-04-2021 at 09:18 AM.. |
tokyodrift192.50 |
10-04-2021, 10:38 AM | #218 |
Rep 7,489
This is an "envelope" cargo net that can be stretched across the rear of the vehicle so that you don't have to reach up into the vehicle to get items that could normally end up further up into the vehicle when driving around town. You put things inside the envelope that you don't want rolling around in the cargo area. I put my briefcase in the net daily. When I go to the store and have just a single bag or just a couple of bags...I put them in the envelope net. If I purchase something delicate like eggs or a container of milk/juice/etc...they go in the net. If I have something round like a melon or a basket ball...I put them in the net.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-09-2023 at 03:21 PM.. |
10-04-2021, 02:24 PM | #219 |
Rep 518
Drives: G82 M4, F15 X5, F30 328d, E30
Mine still in the bag, not many uses for it.
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black MSport Pro and Prof. |
06-09-2023, 04:16 AM | #220 |
Rep 8
I bought myself an approved low mileage 2018 F15 from a BMW main dealer a few weeks ago and was pleasantly surprised to find an unused/sealed cargo net in the side pocket after I got it home.
I had been planning to buy a cargo net anyway, so this was a bit of a result. Then I wondered if all X5s come with this and if everyone knows about it, so I Googled and found this thread. |
Kzang3240.00 |
