10-01-2017, 01:11 PM | #3719 |
Rep 131
I'm trying to code my f15, but when I open up: eg. bdc_body module...after edit fdl. when I open up the folder..let say 3000 all the folders under funktionen are "." does anyone know what happened? on the right side it said found 0 code for current ecu |
10-01-2017, 02:24 PM | #3720 | |
Rep 40,894
10-01-2017, 06:07 PM | #3721 | |
Rep 8,364
10-02-2017, 08:29 PM | #3722 |
Rep 570
Just got my F15 back from the dealer after 6k repairs ....can somebody send me the updated software by a chance, so I can code my items back into this baby...? Thanks!
shawnsheridan Almaretto ? |
10-02-2017, 08:39 PM | #3723 |
Rep 40,894
PM sent.
10-04-2017, 05:58 PM | #3725 |
Rep 60
Having issues connecting to my car after following all the ESYS guides. Got a token, extracted psdzdata into the Data folder and cant get any targets to load when trying to connect to my car.
Any ideas or help?! At this point, im willing to just pay someone locally or remotely to code the few things I have picked out already. |
10-04-2017, 06:00 PM | #3726 | |
Rep 40,894
If the "Open Connection" window under "Target" is empty (no targets), verify the following:
10-04-2017, 06:48 PM | #3727 |
Rep 23
Quick question, I am sorry but I've tried to find among the 170 pages.. I got my adapter, Bimmerlink and Bimmercode. I've been able to successfully connect to the vehicle and make the necessary changes. However when I hit "code" it tries to open Bimmerlink I think but because I don't have an internet connection (I am connected via the adapter) How do I successfully send the codes to the car? Is there a connection sequence I am missing? Thank you in advance for the help!
10-04-2017, 07:46 PM | #3728 | |
Rep 60
Thanks! Got it working after the WinRAR recommendation |
10-04-2017, 07:46 PM | #3729 |
Rep 40,894
10-05-2017, 12:48 AM | #3730 | |
Rep 8,364
For your needs, check out Coding your X5 the easy way |
10-05-2017, 04:44 PM | #3731 |
Rep 2,513
So got E-SYS installed,did some basic coding and got my navi updated,but I'm looking into the No Glare High Beams coding and it seems to be a little bit unclear which way should i go. I see this guide here: http://f15.bimmerpost.com/forums/sho...&postcount=107
And this post here: http://f80.bimmerpost.com/forums/sho...2&postcount=60 Second one does look easier to me,will this still work on my 2014 F15?Or i have to do everything manually? |
10-05-2017, 08:50 PM | #3732 | |
Rep 8,364
10-08-2017, 01:41 PM | #3737 |
Rep 17
2016 X5 xDrive 40e question.
Does engine need to be running to code or is plugged in charging ok. Since it’s the plug in starting doesn’t actually start the motor and just turns on using battery. Is this enough to prevent the 12 volt system from draining? If there is a full battery charge will that be enough and be the same as say a 35i with the engine running? Last edited by candm; 10-08-2017 at 01:54 PM.. |
10-08-2017, 03:20 PM | #3738 | |
Rep 8,364
candm18.00 |
10-08-2017, 04:16 PM | #3740 |
Rep 40,894
