06-20-2022, 07:09 PM | #1 |
Rep 1,701
Drives: 2014 428i and 2018 X5
Center tread wear but not tires not over inflated
Hey guys...
My rear tires that I got last July are already down to the wear bars after only 17000 miles and 11 months. Luckily TireRack is giving me 2 new ones at 50% off, but wanted to pick your brains about the center tread wear. This is obviously caused by over inflation of the tires, but I always keep the rears at 38psi, even though BMW recommends 41 per the sticker on the door. So if they're not over inflated, then what could have caused this? These are the Continental DWS06 tires. Thanks!
06-21-2022, 11:32 AM | #3 |
Rep 1,701
I check pressure 3 ways…iDrive, old fashioned pressure gauge and an an inflator that has digital display of the pressure. They all said the same…38psi.
06-21-2022, 11:42 AM | #5 |
Rep 1,701
06-21-2022, 12:18 PM | #7 |
Rep 662
Assume you are checking them cold, i.e., first thing in morning before you drive? Is your car garaged or outside when you check?
Other assumptions or items to check:
Some variable with your setup is causing over inflation of the rear tires. My iDrive reads differently than manual handheld gauges tested at each wheel. I don't trust iDrive, so I set it according to the handheld unit then use iDrive to keep an eye on them between the seasons and for rapid lost of pressure. Last edited by Clifton; 06-22-2022 at 09:28 AM.. |
06-22-2022, 12:36 PM | #8 |
Rep 21
I have the same issue with my X5 running 20" runflat tires; I don't believe it's related to tire pressure, since I tried different tire pressures and still end up with the same results.
My guess is that the suspension geometry is causing this. |
06-22-2022, 12:52 PM | #9 | |
Rep 1,701
The depth on the sides are equal and much better than the center. I guess I'll see how my new tires work out and keep an eye on them better.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport Last edited by ooshnoo; 06-22-2022 at 01:07 PM.. |
06-22-2022, 01:22 PM | #10 |
Rep 11,144
How are your other tires doing? When is the last time your car saw an alignment? If you want to do it right, an alignment is not a bad idea when fitting new tires.
I had excessive wear on outer edge of my front tires. An alignment result showed what the issue was. |
06-22-2022, 02:01 PM | #11 | |
Rep 1,532
OP these tires are rated for 50k miles, but half of that if staggered as yours are. So you have gotten 17k out of the expected 25k mile life from the tire. Considering the weight, power, and performance-orientation of your vehicle I think that should be in line with expectations here. It's nice that TR is replacing them for 50% off.
ooshnoo886.50 |
06-22-2022, 02:02 PM | #12 | |
Rep 662
ooshnoo886.50 |
