      02-11-2018, 09:22 PM   #1
03redtypes
Drives: 2011 535i Msport
Best vendor for lowering kit w/air suspension
I’ve looked a couple pages back in the classifieds and just found one and they had the Megan coil overs. That being said I’ve got air suspension, and looking probably at the eibach seeing most prefer those. For a 16 x5. Can someone refer me? Thanks!
      02-11-2018, 09:34 PM   #2
sandwi54
sandwi54's Avatar
Drives: G07, F90
The best aftermarket suspension for air suspension is the KW V3 coilover. I have it on my X5 and it's very very good. Don't do just springs as the stock shocks are really soft and cannot keep up with the increased spring rate. Your ride will be so bouncy that you'll eventually want to replace the shocks too, causing you to spend twice the amount of labor and alignment.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD)
      02-11-2018, 10:03 PM   #3
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
I agree, without doubt KW3 is the best option at the moment, not only you can adjust height, but rebound, dampening etc. It is overall a best package that indeed improves handling and reduces body roll and so on
However, I can't stop wondering why is it then that BMW officially offers AC Schintzer lowering springs? Even Dinan offers their set of lowering springs. I mean clearly BMW would not offer such option if it were to deteriorate ride by making it way too bouncy. I know H&R has a bit too much spring rates - hence bumpy ride, but afaik Eibach is pretty much close to stock ride wise
Would be good to have spring rates to compare, as numbers will speak for themselves unlike our subjective opinions, but I can't find spring rates anywhere
Megan Racing lists 14/12 kg/mm front/rear for their coilovers - but I suspect that's way too high and hence ride may be rough even with matching springs. I would like to know stock f15 spring rates to compare, my guess is they are about 9 or 10 kg/mm so if Eibach has similar or close to that rates - then it should be good imho
      02-11-2018, 10:33 PM   #4
03redtypes
What’s everyone’s thoughts on the kw? I’ve never been a big coil over guy, but with my cars I’ve had never would I actually use them for the price. I usually just did lowering springs. With the rear air, potentially I’m just getting two front coil overs and shocks for the rear right? Well with the edc sensors too.
      02-12-2018, 04:46 AM   #5
redline9001
redline9001's Avatar
223
Drives: E92 M3, F15 X5, G14 F150
Kw makes very good stuff, I have had their springs to full coil-overs. They are worth every penny you pay for them.
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts
      02-17-2018, 10:57 PM   #6
Holy Bimmer
Drives: 2014 BMW xdrive50i
I purchased some H&R lowering springs for my 2014 BMW X5 xdrive50i with standard suspension. However, I am afraid to install them after reading so many adverse discussions. Should I attempt to dump them on eBay and buy some coilovers. Just curious. I really like the look of H&R lowering springs. What should I do? Thanks.
      02-17-2018, 11:20 PM   #7
03redtypes
I read the same. That’s why i went with the kw. I may part with them but I’ve got rear air and won’t work with your setup
      02-18-2018, 09:40 AM   #8
surfcali
surfcali's Avatar
Drives: 2016 M3 Mineral White
Just put the H&R Springs on if you are dumping the car in a few years, if it's a keeper get the kws.
That being said i have kw v3s - they also ride harsher than stock ...
2014 X5 35i X-Drive M-Sport | MPPK | MPE | KW V3 | 22" AG M615
2011 e92 335i M-Sport | Cobb V3 | Alpina Flash | Injen Intake | PE Mod | Mishimoto FMIC | ER Chargepipe | ST Coilovers | 19" BBS CH-R | Arkym Front Lip | MP Style Trunk Spoiler
      02-18-2018, 10:26 AM   #9
03redtypes
I’ve read where they are far more superior than stock. That being said harsher isn’t what I wanted to hear! Pmed.
      02-18-2018, 11:17 AM   #10
surfcali
surfcali's Avatar
They are far superior but don't expect to be riding on pillows when ur dropped on 22s
      10-01-2019, 12:46 PM   #11
M3-Mike
M3-Mike's Avatar
Drives: 2020 M2 Competition
I just installed the KW V3 kit on my 2016 X5 with rear air and WOW, the truck drives like an M car now. Ride is tight and well controlled, yet swallows up the bumps very nicely. Set to KW default settings. I'm on factory 20" staggered rims but have replaced the runflat tires with Continental DWS-06.
      10-01-2019, 12:58 PM   #12
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Cool
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      10-01-2019, 09:45 PM   #13
Road Carnage
Road Carnage's Avatar
Drives: 96 328is, 15 X5 50i
Agreed, I have mine set two clicks firmer on compression, one click firmer on rebound- whole new vehicle. I’m on 21” rims/MPSS.
That’ll buff out
      10-03-2019, 02:08 AM   #14
cbarden
Drives: M5
You will notice great ride improvement with KW V3. Worth the cost.
