09-26-2017, 02:33 PM | #1 |
Rep 87
Using AUTO on the climate control.. and AC on constantly..
i kind of cringe when i read about guys using the Auto feature on climate control.. and basically set-it-and-forget it..
Dont you guys think that having the AC "on" so much, regardless of temperature being blown out, is not efficient way to run the car? Running the AC is a drag on performance/fuel. Why would you ever want the green light AC running unless you absolutely needed cool air? Matter of fact.. i never really adjust my thermostat.. i either run the AC on or off.. there is no "turn the temp up" if its too cold. why would i ever want to drive with AC engaged if i thought it was "too cold". |
09-26-2017, 02:42 PM | #2 |
Rep 402
AC isn’t just for cold air. It’s also for de-humidification.
Jenya B144.00 charlietangobravo50.00 |
09-26-2017, 03:27 PM | #3 | |
164
Rep 317
When I rent economy cars I still come across those that have a switch for either ac on or off. Kind of barbaric and uncivilized to actually have to manually switch it on and off . . . One hand holding my martini and the other on the wheel leaves no more hands for switches and buttons I remember back in the days when my Dad used to have one of those cars that did not have climate control
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White |
09-26-2017, 09:44 PM | #5 | |
Rep 87
If yiu guys don't care about using more fuel or drag on performance with AC on then so be it. But me, I care about fuel economy and don't want that green light in unless I want cool air blowing when needed. A BMW tech confirmed this with me. The AC is either on or off. It's dragging fuel or not dragging fuel. There is no "turn on only when more cool air needed" when in auto mode. Put more simply. If the green light is on and yiu have the temp set for 75 degrees your AC i still running even with warm air coming out the vents |
09-26-2017, 10:32 PM | #6 |
Rep 7,164
Lol he?s messing with you dude cuz your question is moot. First it doesn?t drag all that much on your engine (tell the actual mpg difference please) and second who cares. When it?s too cold I?m sure people don?t just sit there and freeze. They turn it off and if they don?t. This shouldn?t make you ?cringe?
expidia164.00 |
09-27-2017, 01:07 AM | #8 |
Rep 1,887
The compressors on these modern cars aren't like the old ones that were either on or off. These are controlled with variable compression based on how much is actually needed at the time, so just because it is "on" doesn't mean it is fully engaged if it's not needed.
If you were worried about 1 tenth of a mile per gallon, why would you have bought a luxury suv? You could have bought a lot cheaper vehicle and got one that got a lot better mileage. But you bought this one, so there must be some things that are worth it to you to spend a little more money and get a little less mileage. Like comfort. I keep mine on all the time simply because I don't like being one of those idiots driving around with their windows all fogged up when it's humid or rainy. I keep mine on all the time in the summer because it needs to be on all the time. I keep it on all the time in the winter to keep the windows from fogging up. I keep it on all the time in the spring and fall because it might be raining, it might be snowing, it might be hot and humid, it might be cool and humid. So, my question would be, why would anyone not have it on all the time?
09-27-2017, 06:37 AM | #9 |
Rep 87
Well some guys add a special air filter for 1/10th more horse power or one tenth better gas mileage so different strokes for different folks. But at least maybe some people can learn from this thread if they thought with green light on that sometimes their AC is not engaged because they have heat blowing out of their vent
09-27-2017, 06:39 AM | #10 | |
Rep 87
09-27-2017, 06:44 AM | #11 |
Rep 87
Cringe is a figure of speech guys. Cmon. It's a dialogue. "Hey why is your AC on?"
"It's not on" "Yes it is... the green light is on" "No it's not its blowing hot air" "It's on" "Not it's not it switches between hot and cold" "The AC motor is on if the green light is on" |
09-27-2017, 06:44 AM | #12 | |
164
Rep 317
If any loss of power is going to be due to that AC light being on and you are at a stop light ready to show that 16 year old kid in a Camaro next to you . . . who is Da Man then just turn the AC light off before you floor it.
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 10-08-2017 at 06:31 AM.. |
09-27-2017, 08:57 AM | #13 |
Rep 87
Yes Expedia I agree. I've just noticed being a lurker that climate control is a HUGE issue on this board and i think this bit of info would at least be enlightening to those that use AUTO all year round.
I mean year round with AC green light on. |
expidia164.00 |
09-27-2017, 09:13 AM | #14 |
Rep 33
Just FYI; in the 4.0e iPerformance model, the AC compressor runs from battery not engine; no parasitic loss or loss of efficiency at all as well as during start/stop (if you're running it with active) on the IC only powertrains.
As a side bar, it also allows you to fully run the AC while away from the car (activate when you turn ignition off, or from BMW remote) which is one of the best benefits in my humble opinion... |
09-27-2017, 09:53 AM | #15 | |
Rep 180
09-29-2017, 08:04 AM | #16 | ||
Rep 7,164
expidia164.00 |
09-29-2017, 09:38 AM | #17 |
Rep 1,011
And you want the real kicker... when you press the a/c button to off, it doesn't always turn the compressor off. Especially if you have rear air. I hate a/c if it's not super hot out. So I turn mine off all the time. I usually end up shutting the entire system off for a few minutes.
Then turn it back on in manual setting, with the temp all the way down and fan on 2nd speed. |
09-29-2017, 08:36 PM | #18 |
Rep 516
I still have never understood when its snowing outside, and I set my thermostat to 78, hit auto why on earth the AC light comes on. Dont give me any bullshit about humidity. haha.
I monitor the outside temp, inside temp feel and make changes as needed manually. Dont even get me started on the ventilated seat option. If i had to give up one of the biggest let down options, it would be that overpriced POS. My assistants 10 year old Lexus is350 has air conditioned seats which blow away my X5
Current Stable: 6 Drivers + 5 Projects
09-29-2017, 10:18 PM | #19 | |
Rep 155
Which is better for gas mileage, a flat road, or a road with hills? Same principal, really. You're assertion really has no factual basis. Last edited by boyce89976; 09-29-2017 at 10:23 PM.. |
09-30-2017, 08:56 AM | #20 | |
Rep 256
Drives: '17 F15 MSport
My wife’s Chevy Tahoe had air conditioned seats too, worked great for the 3 months of the year it’s hot where we live. Then the ac compressors went out so now they’re ventilated seats like BMW One benefit of ventilated in X5 though, you can use them in winter in conjunction with heated seats to blow warm air on your arse. Can’t do that with air conditioned seats... |
Chadmatic660.50 |
10-01-2017, 08:12 AM | #21 | |
Rep 209
Drives: 2018 640i GT/2017 X5 40e
10-01-2017, 09:21 PM | #22 | |
Rep 87
This thread has been loaded with people who think that the varying degrees of temperature of air that comes out of your vent is by the compressor changing? Oh my god it's the MIX of cold and hot air not the cold air "working to get colder". For the love of..... |
