10-01-2017, 09:24 PM | #23 | |
Rep 87
10-01-2017, 09:28 PM | #24 |
Rep 87
I'll buy into that if it is 40 degrees outside and the green light is on that that the AC pump will not come on. That's obvious. My OP was meant for people that will keep it on auto but run a range of thermostat settings from 62 to 75 and still keep the green light on. They toggle the thermostat setting instead off switching the AC off ever
If people wanna run that way fine. But if it's 95 degrees out and the stat is set to 62 the AF will be on and let's call it 100% cold 0% warm air mix out of the vents. When it's 80 out and the stat is set to 70 let's call it 70% cold air 30% warm in the mix. Then we get to 77 degrees out and the stat is set to 70 maybe it's 50/50 mix or less now. But if guys really think the compressor is doing less drag on the performance as the temp is toggled from 71 to 75 cmon. I'd rrathwr just turn the green light off for that next 5 degrees (notwithstanding all the prior posts about not caring about fuel and HP etc) Last edited by BimmerX5kid; 10-01-2017 at 09:38 PM.. |
10-01-2017, 10:04 PM | #25 |
Rep 7,160
Well...Sorry so many people upset you on their AC usage. But I think when you post 3x in a row with no one else posting in between then the point is moot and has lost interest.
MysticBlue368.50 deutsch1003946.50 |
10-02-2017, 04:14 PM | #26 |
Rep 155
I think you should read up on how HVAC systems work. The compressor is only one part of it.
10-04-2017, 04:41 PM | #27 | ||||
Rep 208
Drives: 2018 640i GT/2017 X5 40e
deutsch1003946.50 |
10-10-2017, 07:25 AM | #28 | |||||
Rep 208
