08-11-2018, 10:45 AM | #221 | |
Rep 2,388
Well, I'll try to at least reach maybe 115-116mph - maybe that will be enough to get to 11.99s lol? I hope it's doable if stars align perfectly and if I hit perfect shifting points. I wish I could have time to sit down and calculate exact shift points to maximize acceleration based on gear ratios and torque curve (like that dude in video), but I'm not that hardcore lol. Just doing this for fun. P.S. I did it in Comfort mode with DSC off and gear shifter in S mode (to the left) with manual shifting. So I'm thinking to try Sport mode next time - but in that mode DSC gets activated again - so I'm not sure how it will play out. We'll see. |
Russmov1328.00 |
08-11-2018, 10:52 AM | #222 | |
Rep 2,388
I don't know why manual shifting was a bit faster? I mean does ZF8 transmission really changes gears faster in manual mode or it's just that maybe it just has one less algorithm - like one less thing to compute and worry about (since driver decides when to shift) and maybe that's why it shifts a tiny bit faster? Not really sure. |
08-11-2018, 10:56 AM | #223 |
Rep 648
Drives: 2016 F15, 2015 F83
It definitely shifts faster on Sport mode (shifter to the left). So, even if your manually shifting, I would make sure the transmission is in Sport mode.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
08-11-2018, 11:53 AM | #224 | |
Rep 43
So at this point I almost always drive with DSC off and shifter to the left. Often manually shifting as well. Sport+ was fun when it was stock, but tuned there's too much power and the traction control tries to intervene too much if you're trying to have any fun.
2014 X5 xDrive50i M-Sport ///
bootmod3 Stage II Tuned ARM Catless Downpipes |
DuSh2113.50 |
08-11-2018, 06:45 PM | #225 |
Rep 2,590
Shift points are a tricky thing, it's not solely when boost and power falls off. But there's the aspect of torque multiplier in a lower gear vs.short shifting to the next gear because it keeps you in a better boost range. To be honest, in a 1/4 mile shift points aren't going to get you more than 1 mph. The biggest factor in quarter mile is if you can finish it at a high rpm lower gear or if you're forced to shift to the next gear close to the finish line.
I haven't looked at the gear ratios to know what gear the car is in and what rpm at 110 to 117mph |
DuSh2113.50 |
08-11-2018, 07:42 PM | #226 | |
Rep 2,388
So it turns out starting from 2015 x5 BMW changed gear ratios on ZF8 transmission. 2015+ has 4.7sec 0-60mph vs 2014 4.9s 0-60mph (BMW numbers that are known to be underestimated historically). But we can see that 2015+ has shorter gears, especially first and second and maybe that accounts for 0.2s faster reported 0-60mph time? 2015 and up now has: 5.00 (can't find max theoretical speed in each gear) 3.20 2.14 1.72 1.31 1.00 0.82 0.64 3.47 (Rear) 3.15 (Final drive ratio) While 2014 has: 4.70 - 40mph (max theoretical speed in each gear) 3.14 - 61mph 2.11 - 91mph 1.67 - 115mph 1.29 - 149mph 1.00 - 192mph 0.84 - 229mph 0.67 - 288mph 3.32 (Rear) 3.15 (Final drive ratio) So gear IV ends at 115mph (top theoretical speed for that gear) and may become issue when trying to finish 1/4 mile strong without shifting. Especially since practical top speed in each gear may be a bit lower due to different losses. Just thinking aloud. |
08-11-2018, 08:16 PM | #227 |
Rep 648
Changes in bold:
Also, I believe all F15 X5 50i’s have the ZF 8HP75 transmission with the above mentioned gear ratios, according to realoem.com.
2015 F83 M4 |
DuSh2113.50 |
08-11-2018, 08:46 PM | #228 | |
78
Rep 360
Im actually going to see which software version I have and call my dealer on Monday to see if it's the most up to date version
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets 2014 X5 50i BMS stage 1, Dinan intake, F85 Knee Bolsters |
DuSh2113.50 |
08-11-2018, 09:52 PM | #229 |
Rep 2,388
Thanks guys! Yes, it would be interesting to know if it was not gear ratios that changed, but software update.
frenchie101378.00 |
08-21-2018, 09:15 AM | #230 |
Rep 43
Wow this thread got pushed back to page 3! Does anyone know how to get threads stickied? We have multiple really good DIYs as well as this thread that deserve a sticky at this point. I've tried messaging admins with no reply.
09-22-2018, 11:33 PM | #231 |
Rep 43
I made it out to the track one last time for the summer. The track was really busy and I only got 2 runs in. This was my first run. I don't have slip for the second, I waited in line 2+ hours to run and just wanted to gtfo after
I am running a splash of E85. About 1gal added to 1/2 tank of 93. Weather was also a factor since the temp was about 58F. Especially when compared to previous runs of 80+ weather. Either way, I couldn't be happier with these numbers! 11.87 @ 116mph!!! Apparently I've been to this track enough times that the guy standing to the right knew I would win. Notice him pointing at my lane View post on imgur.com
4
09-23-2018, 07:04 AM | #232 | |
Rep 1,434
2022 x5 m50i - Dravit grey
09-23-2018, 01:02 PM | #233 | |
Rep 299
09-23-2018, 10:36 PM | #234 | |
Rep 239
09-24-2018, 07:53 AM | #235 | |
Rep 43
The only hardware modification is the X5M Air Filters. This thing's a beast!!
frenchie101378.00 bm3nyc56.00 |
10-01-2018, 02:59 PM | #236 |
56
Rep 55
Drives: F90 M5,F85 X5M, F15 X5, F80 M3
bootmod3 FTW !!!
Contact US @bootmod3nyc on IG
CTS Turbo Intakes/Downpipes/Chargepipes N55/B58/S55 | Lusso F90 M5 Downpipes/Intakes/Midpipes| Bootmod3 N55/S55/N63TU/S63TU Dealer ! |
Doberman1659.50 |
10-01-2018, 03:12 PM | #237 |
IG @bmwF9xG80
3816
Rep 7,594
Drives: G80 M3, X4M, G07 X7m50
Have IG? if so tag @Protuningfreaks they'll repost you this is great numbers
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
10-01-2018, 08:51 PM | #238 | |
Rep 47
Doberman1659.50 perry8912101.00 |
10-03-2018, 10:56 AM | #239 |
[Oo=||=oO]
1105
Rep 2,470
Silly question...
It seems like some people go with Alpina turbos for N63TU with their f10 5er. Would those turbos work on X5? Isn't the engine the same across all platforms? 5, 6, 7, X5, x6? Would alpina be better than doing hybrid? |
10-09-2018, 08:57 PM | #240 |
Rep 1,975
Most of the talk here is around BM3. Does anyone have experience with JB4 performance vs BM3? I like the idea of being able to take the JB4 off so the dealer can't tell.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
10-09-2018, 09:09 PM | #241 | ||
IG @bmwF9xG80
3816
Rep 7,594
In my opinion you will be happier, save money, have resale value or can transfer to your next car, have the best customer service, FREE updates, free datalogging, able to switch maps via Android, iPhone or MacBook/Windows no wires in engine bay no splicing or hard to reach areas for extra power etc. PS. Just look at Doberman16 1/4 mile video and slip on a STG1 Save the hassle, I've had both been there done that! Quote:
60-130 6.5s X4M
10-10-2018, 01:20 PM | #242 | |
Rep 1,975
I have JB4 on my F30 and have never had an issue at any dealership and I don't even take it off.
