04-08-2016, 08:13 PM | #1 |
Rep 609
Maintenance Question?
What are the intervals for oil changes for our vehicles? Now that I'm tuned I'm thinking of doing 5k oil changes? Thoughts?
Joe |
04-09-2016, 05:07 AM | #4 |
Rep 455
why would you do it less than the recommended interval? You think BMW skimped on the intervals since they pay for it?
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone |
04-09-2016, 10:35 AM | #5 |
Rep 710
04-09-2016, 11:17 AM | #6 |
Picture me rollin'
308
Rep 1,130
04-09-2016, 11:20 AM | #7 |
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
Just make sure they do not reset the oil service timer for the paid interval oil changes. Some BMW service shops are robots and purely work off the countdown onboard.
04-09-2016, 11:45 AM | #8 |
Rep 729
I've been doing 5k oil changes from the beginning, and plan to going forward. I, actually, did the middle oil change before 10k miles at around 4k miles after break-in service. I told them not to reset the oil change reminder, or to change anything in the BMW service system, so it wouldn't affect any of the prepaid services that come with the vehicle. The latter is important, because if they don't input it correctly, it will trigger a cascading event whereby you'll get screwed out of your free services, and intervals at which they should be performed will be pushed-up sooner than needed.
04-10-2016, 10:27 AM | #9 | |
Rep 2,353
04-10-2016, 11:56 AM | #10 |
Rep 455
why 5k? is BMW just being cheap with the prescribed intervals? will the internals take a bit with the recommended 10k?
04-10-2016, 12:06 PM | #11 | |
Rep 2,353
At this point, BMW thinks about maintenance the same way someone leasing (with no intention of buying) would- i.e the benefit of ensuring the long-term health of the motor is essentially zero. These motors generate a ton of heat under load, operate under incredible pressures and have (at least in earlier iterations) a propensity to consume oil. Maximizing the efficacy of your oil (which is key for proper cooling, cylinder wear, etc.) for an extra $100/year seems like a no-brainer (to me). |
04-10-2016, 12:23 PM | #12 |
Rep 442
Drives: 2023 BMW iX M60
I would change oil at 10k interval. Oil technology has advanced a long way since 2010.
When I was in Texas, I had a oil related project and in their lab, I saw the difference between"old fashion oil" vs modern oil. I can ensure you that 10K interval is the least thing you should worry about. Most of modern oil can go up to 20K and looks like new. So, I would recommend to just stick with your reminder in car. While I understand why people want to change their oil more frequently, I can only see a waste of money and time. Technology is far more advance than we can understand. PS. I have a master degree of Chemical Engineering. So trust me, please. |
04-10-2016, 01:02 PM | #13 | |
Rep 2,353
http://www.e90post.com/forums/showthread.php?t=868291 |
04-10-2016, 02:40 PM | #14 | |
Rep 710
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
04-10-2016, 02:53 PM | #15 | |
Rep 442
04-10-2016, 02:55 PM | #16 |
Rep 442
04-10-2016, 05:10 PM | #17 |
Rep 729
Just last year BMW had to do a "customer care package" for anyone that owns one of their vehicles that contains an N63 variant engine, partly because they pushed engine oil changes too far out. It was well documented that part of their engine failures were attributed to oil issues related to pushing oil changes to be too infrequent. Timing chains became fatigued and stretched, and, in some cases, the piston rods would sheer off and puncture the engines. At the time, BMW said 15k miles was perfectly safe, and worked well for their engines, and that oil technology was at the point it could substantiate these infrequent oil changes. They were wrong, horribly wrong. They have since downgraded maintenance for those engines to be 10k miles. Since the S63TU engines are based, in many ways, off of the N63 engines, but are pushed to even further limits in the call for more horsepower and torque, I am not willing to take the chance that BMW is again horrifically wrong in stating that 10k miles is perfectly safe and adequate for their engines. Oil is recycled now, as are most car fluids, so there's no harm to the environment to do more frequent oil changes. I'd rather pay $100-$150 per year extra in a possibly superfluous oil change, than shell out $40k+ on a new S63TU engine, if BMW is, once again, wrong in their estimations. What works on paper, or in a lab, oftentimes does not equate to how things work in the real world.
04-10-2016, 07:43 PM | #18 | |
Rep 442
But let's just say BMW fails again, you are not alone and will be protected by warranty. Again, I will find sources and documents once I get home this week. I used to have a 997 Turbo and even with that high pressure, high rev engine, 10K is perfectly fine. I love my car, but I am not gonna treat it like my father. |
04-10-2016, 08:08 PM | #19 | |
Rep 729
I've heard too many times in court, one expert say, I have this degree and that degree, so trust me, only to have another expert with the same set of degrees postulate, and put forth a counter argument. In the end, one has to make their own choices. There's nothing wrong with following BMW's maintenance plan, but there's also nothing wrong with being cautious after considering possible consequences, and a company's failed past history with maintenance interval decisions. |
04-10-2016, 11:59 PM | #20 | |
Rep 442
Again, I am not an BMW engine expert but I am kind of oil expert, (Been doing oil and LNG business for a long time. ) and I believe in science, not experience. But I agree with you on one thing, one has to make their own choices. I used to change oil in my SRT8 at around 3K interval LOL. Cheers. |
04-11-2016, 02:01 AM | #21 | |
Rep 442
04-11-2016, 11:53 AM | #22 |
Rep 729
I appreciate you posting these. I was involved with the oil and gas industry from 2004-2007. I understand that, in theory, and in some real world testing, synthetic oils can be pushed to a pretty decent limit. As I previously said, there is a high likelihood that BMW's 10k mile interval is acceptable. For me, however, I'd rather err on the side of caution, and do the extra oil changes at 5k miles, just to be extra sure the car stays "healthy" for a long time. My intention is to keep this vehicle around 7 years. I know I'm not the only one who chooses to be more cautious. The dealership I work with says that the vast majority of their M owners choose to do the 5k mile oil changes, as well.
