03-30-2016, 02:38 PM | #1 |
Rep 134
Drives: 2016 X5 M Sport
Tow hitch msport
I know there a lot of posts out there... Now that its going to be nice outside, i started to chk out the hitch options... I thgt the invisihitch was cheaper than oem... But the invisihitch is 998+71(shipping) and bmw oem is 1164 plus free shipping... So is it worth getting the invisihitch? I will be using the hitch for both towing and bike hitch..... Install price is going to be the same... As i dnt have garage andcant do it myself... Are there any other good options?
Current : 2016 X5 M-sport
Retired: 2015 Audi Q5 2005 545i 2003 325i |
03-30-2016, 08:27 PM | #3 | |
Rep 134
03-30-2016, 09:03 PM | #4 |
Rep 710
I called Invisihitch and bought the hitch only (no wiring) for about $500 and installed it myself. Super quality.
03-31-2016, 01:46 AM | #5 |
1148
Rep 2,426
Don't get the BMW one. You have to pay like $300 for the ball and it's a proprietary attachment system.
BTW don't ever let a lack of garage be a deterrent. I serviced my car on the street or large parking lot all through college. For the hitch you will want help from a friend though. |
03-31-2016, 08:32 AM | #6 | ||
Rep 34
03-31-2016, 08:45 AM | #7 |
Rep 5,436
If you search around, there are several people that say the OEM one sucks and wish they didn't get it.
I had the OEM one on my X3 that I just traded for the X5 and it is a poorly designed thing the way it works, only thing that is good is the OEM wiring to deal with the sensors etc, hitch itself sucked and left marks on my bumper from taking the hitch part on and off even though I was careful - also takes a rocket science degree to figure it out the first time and ensure it is locked properly to the car. Doing it again I would do Invisihitch if you want to see nothing and OEM wiring to deal with sensors going off in reverse with the hitch on. I did the Curt as it is very little to see and was $150 for the hitch!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
jersey john22.00 |
03-31-2016, 09:07 AM | #8 | |
Rep 134
03-31-2016, 11:10 PM | #10 | |
1148
Rep 2,426
If you want to really tow, you need to get this attachment. This one is a Class III rated to 6000 lbs. This however I think is BMW being conservative. It's solid steel; should work fine to the 7700 lbs that the vehicle can tow. Notice the proprietary attachment to the car. Basically there are better options. And this contraption, even though I think they intended to be hidden when not in use, is definitely not hidden from view. Just curious, does yours have the foam pads at the edge of the receiver tube to prevent the scratching? |
04-01-2016, 05:56 AM | #11 | |
Rep 5,436
The drawtite 75600 will also fit without cutting and you can apparently also retain the bumper crash bar with it (the new curt model you cannot retain the bumper bar behind the bumper due to the location of the bracing on the hitch near the bolts. The other issue I had with the OEM one on my X3 which is the same design and same receiver attachments is that the 2" square tube is quite shallow and I had to cut my hitch shorter to get it to fit into the 2" receiver - whole thing is just a poor design at best - why they would not just OEM the hidden hitch like the rest of the world is beyond me. Rob
04-01-2016, 11:47 AM | #12 |
Rep 119
invisihitch! id highly recommend, and i installed it myself no garage, if you call them they actually quote you a cheaper price than the website, also whats better then the car not having a hitch sticking out when you don't need one
05-26-2016, 11:43 AM | #13 |
Rep 438
Drives: F10 535i MSport, F15 X5 MSport
Hey guys... can someone confirm that this is the invisihitch everyone is talking about?
https://www.etrailer.com/hitch-2014_BMW_X5.htm |
05-26-2016, 12:47 PM | #14 | |
Rep 34
This one: http://www.invisihitch.com/ |
04-01-2017, 12:16 PM | #15 | ||
52
Rep 301
I'd like to avoid buying an Invisihitch as I really just need a standard 2" receiver for my 2016 X5 35d M Sport. Can you guys share some pictures of your no-cut installs? |
04-04-2017, 07:36 PM | #17 |
Rep 30
Confirmed, Just had mine installed a few weeks ago and no cutting involved. Steve at invisihitch was great to work with. Their website sucks but just give them a call and they can explain the options. I went with the oem harness as I don't like risking anyone tapping/cutting bmw wiring harnesses.
04-04-2017, 08:16 PM | #18 | |
Rep 110
04-05-2017, 10:18 PM | #19 |
Rep 104
Got my MSport detachable tow bar from PFjones UK, Witter Brand, same as OE. Much cheaper than Aftermarket or OE at dealer price. $180 + $200 3day shipping to South America. No wiring harness since I use it only to carry a bike rack.
05-08-2017, 02:39 PM | #20 | |
Rep 11
Drives: 2018 X3 M40i
Curt for M-Sport? nope
So much for that |
05-09-2017, 12:16 AM | #21 |
Rep 538
75600 Class III Hitch - Bmw X5
This is a Draw-tite hitch I bought from etrailer for my F15 X5 35 Xdrive M-sport , I install it myself , it took about 6 hrs and it requires no cutting , the cutting has already been made from factory in anticipation of this install I guess. Its sticking out a bit but doesn't look bad at all, in fact it makes the X5 looks more like SAV Hope it helps |
04-29-2019, 03:35 PM | #22 | |
Rep 11
Curt fit fine
UPDATE - I did end up buying the Curt and it went on the X5 M-Sport perfectly. It was awesome and economical. |
