06-25-2020, 12:07 PM | #24 |
Rep 2,518
OnlyGerman363.50 P111584.00 |
06-26-2020, 06:51 PM | #26 |
Rep 16
I had highly certified tech and diagnoser look at my car with ista we swapped injectors still no start he says CAS CLone or DME Clone nxt still no start no codes
06-26-2020, 09:06 PM | #27 |
Rep 2,518
You don't need to be "highly certified" to diagnose with ISTA since it gives you everything needed to troubleshoot the car. So if someone tested with ISTA, what are test results? I seriously doubt that there are no issues there. One way or another you need 3 things to get the engine running- fuel,air and ignition. No point mess with modules (if they are original according to you) unless you got 3 things above crossed off your list.
06-26-2020, 09:27 PM | #28 |
Rep 16
Yes all modules are oem that came with suv from factory he said no faults stored as well we did re coded everything fuel is present not sure if present past the injectors bc we don't see any fuel geting 2 spark plugs and spark plugs are in decent shape we replaced injectors back in from the oem engien 2 the swap not the issue air is fine and it starts up when we add starter fluid but dies off so we think its a fuel problem. Or ignition? I thought it was going 2 be a easy swap
06-26-2020, 09:53 PM | #30 | |
Rep 2,518
06-27-2020, 01:42 AM | #31 |
Rep 16
Yeah I totally understand what u guys are saying idk what my mechanic or what went wrong but my engine turned on b4 like nothing donor engein does have a youtube video of proof it was working and running b4 i bought it came with warranty like I said i did spray starter fluid and it starts then dies out idk y this engine swap does not start we have coded and swapped injectors reset values aligned everything i am aware of ue5 ue6 both are ue6 injectores everything is coded im not geting any codes so maybe if it started it would tell me more on codes but since it doesn't start no codes have popped besides a CAS termenal 30 terminal 30B max start limits reached with drive train maulfuction but i manged 2 get thoes codes 2 not come back and sensors are all from the donor and I still have my oem motor for extra sensors I will try n get ista screens screenshots
06-27-2020, 03:54 AM | #33 |
1642
Rep 2,995
Check your fuel injector harness for power while cranking. Use a test light or noid light. If no power, then you have a computer issue. Could be security system related. Or maybe you dont have your crankshaft sensors connected right. Computer may not know engine is spinning while cranking.
07-23-2020, 10:56 PM | #36 |
1642
Rep 2,995
07-24-2020, 10:25 AM | #37 |
Rep 2,518
No way you run ISTA and it did not show you a problem with the sensor, and just like I said earlier for gas engine its always on of the 3- fuel,air,ignition. Simple.
07-30-2020, 04:23 PM | #38 |
Rep 16
yeah ISTA did not show it as a error code. We even swapped DME then I went back a few steps and had the answer all along in a screen shot. When doing a hpfp they recommend getting a new sensor all I did was swap in from my the old oem engine sensor cuz like I said it did start with that engine so it started like New no problem has been running great ever since.
