04-06-2021, 06:58 AM | #91 |
Rep 627
Drives: X5 F15 M package
I was considering it granted wanted to know the quality of sound but now I sont hesitate anymore lol
This is too much work for just a speaker. |
04-06-2021, 07:19 AM | #92 | |
Rep 2,737
Again you just need to fish it down and attach to the accessory fuse with a "add a fuse" This should not have taken that long and you did not need to remove your trim. Man I wish I could just come over and help you out! I feel terrible to see you go through that! |
04-06-2021, 07:41 AM | #93 |
Rep 166
My install was also easy. Speaker connection is simple plug and play. Power needs to be routed down to fuse box. Note that I am RHD, with fuse box under steering wheel. I removed the instrument binnacle, but that was all: wires were routed through to fuse box without removing trim. As already mentioned, wires are too short, so we're extended (joint in binnacle recess).
04-06-2021, 07:43 AM | #94 | |
Rep 96
04-06-2021, 09:42 AM | #95 |
Rep 299
At this point I think I would just wire the speaker motor to accessory 12v and be satisfied with the speaker rising and lowering with the ignition rather than the radio.
I can't think of any time I have had car on and not the radio. |
04-06-2021, 10:21 AM | #96 | |
Rep 2,737
Yea I can get deep into it but that's for another time. . It makes it 98% easy! Lol. |
04-06-2021, 10:40 AM | #97 |
Rep 96
04-06-2021, 11:43 AM | #99 |
Rep 299
Cigarette lighter would be the best bet. Just need to be sure it switches off with ignition.
04-06-2021, 01:05 PM | #101 |
Rep 1,270
04-06-2021, 01:23 PM | #102 | |
Rep 2,737
It turns off and on with the key. Not when it goes to sleep. As soon as I get the car back I will take a pic. But it may be a week or so. |
04-06-2021, 03:46 PM | #103 |
Rep 1,665
I had Best Buy do my install. I paid the $200 fee for a year of Total Tech and it was covered under this plan. I got few other things installed like a subwoof, radar, this speaker... all for $200 and keep doing more for the rest of the year
04-06-2021, 04:07 PM | #104 |
Rep 96
Wooow looks like a really good deal! Will take a look on it
04-06-2021, 11:03 PM | #105 | |
Rep 1,665
04-12-2021, 08:37 PM | #106 |
Rep 218
Does the pop up center have a tweeter that points out into the cabin vs. the stock tweeter that bounces off the windshield?
If that is the case, how do you adjust for the DSP tuning and potential changes in phase if you aren't also adding an aftermarket DSP? Even though the center shouldn't impact sound as much as the front R/L speaker I would expect it could still introduce issues. |
04-12-2021, 11:37 PM | #107 | |
Rep 2,737
At least from my perspective and ears. Others I can't speak for. |
04-13-2021, 07:31 AM | #108 |
Rep 299
Is there a noticeable increase in sound?. I wouldn't mind brighter highs from the front and this would be cheaper and easier than changing out the door speakers... assuming it made a difference.
The other option would be just replacing the stock center speaker with something that offered more highs. |
04-13-2021, 09:36 AM | #109 |
Rep 166
My knock-off B&O centre speaker replaced the HK that was installed. Personally, I noticed no real difference in sound quality: neither better nor worse. I kidded myself it was better at first, but that would be placebo
04-13-2021, 09:55 AM | #110 | |
Rep 2,737
However as many have said some have a tough time hearing a clear difference between the HK and the B&O, based on design alone their may be a difference as the sound reflectors are different so they may throw the sound differently than the stock location. Some ears can tell. Some can't. If your looking for a chance get the non branded version so you can keep the HK grills and it looks like it's part of the package. If you want to do a full looksy then buy the branded and replace all the speaker covers and get a OEM fit for the speaker upgrade like Focal and or Bavsound. That way at least you would have the nice shiny covers to compliment the center cover. The price is cheap enough for a give it a try and not cry if you feel it's not better, it's definitely not any worse. Now I have heard that some have coded the idrive unit to allow B&O expanded to be chosen on their HK system and noted a clear difference. So it's possible that option makes use of the center channel more. I have no idea as I haven't done it. |
