      07-13-2019, 10:06 PM   #1
merkaba
Drives: 2016 BMW X5d
F15 with Harmon Kardon - Speaker Upgrade Worth It?
I have a 2016 F15 35d with harmon kardon and am wondering if anyone has done either the bimmer tech or bavsound sub upgrade. They seem to only recommend the sub upgrades and nothing else. If anyone has done it...is it worth it? Any other additions that you would recommend outside of the subs only. My current system is just OK in my opinion. I was expecting a bit better from a premium harmon kardon setup.
      07-13-2019, 10:38 PM   #2
yewlock
yewlock's Avatar
Drives: X5
I got Bavsound sub. Bavsound sub alone not going to make a big difference especially vol below 50%.
      07-13-2019, 10:47 PM   #3
turboawd
1642
Drives: 2015 X5 35i
HK just ok? Really?
Have you messed with the equalizer at all?
What are you looking for? More bass? Treble?
      07-13-2019, 11:17 PM   #4
merkaba
Originally Posted by turboawd View Post
HK just ok? Really?
I actually haven't messed with it too much at all. I was going to start looking for some settings to try out and see if i can improve it at all depending on how this post went. I am not necessarily looking for more of anything specific, but overall.
      07-13-2019, 11:26 PM   #5
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I find the HK system to be very good. Coming from HK in Mercedes, this is MUCH better.
      07-14-2019, 12:05 AM   #6
turboawd
1642
Drives: 2015 X5 35i
Do you have logic7 turned on?
There's been threads here in the past with people adjusting the equalizer and being happier with the sound.
      07-14-2019, 05:09 AM   #7
The Libertine
The Libertine's Avatar
Drives: 2021 Porsche Macan
Making adjustments to the equalizer will make a BIG difference. Give it a try, and let us know if you hear an improvement.
      07-14-2019, 11:41 AM   #8
I was skeptical on upgrading HK speakers to BavSound
But, 3 years ago, I decided to give it a shot on my 650GC and was surprised.
Since then, I upgraded my G30 540i with HK to BavSound on the first week of ownership.
It is such a good improvement.
AFAIK, BMW HK use the same speakers as BMW HIFI, just different Amp.
PM for Everyday DEALS!!
      07-14-2019, 01:06 PM   #9
merkaba
When you did the upgrade, did you also upgrade the amp in your car or did you just replace all speakers/subs?
      07-14-2019, 02:51 PM   #10
With HK, just the speakers are enough.
      07-14-2019, 07:41 PM   #11
Goodfella10
Goodfella10's Avatar
33
Drives: NA
I took the advice from above and played with my equalizer, a big improvement in sound quality!
      07-14-2019, 10:23 PM   #12
edsonreds
Drives: 2011 BMW E92 M3
Absolutely. I have a M3 with Hi End system and a F16 with a Harman Cardon, and it is a different experience. If you love music, I would say it is a must!
      07-14-2019, 11:59 PM   #13
bmwx1sq
bmwx1sq's Avatar
Drives: BMW X1 35i
The speaker upgrades without upgrading the amp is not worth the money. The oem amps for base, HK, and B&O are horrible for the price they cost.
      07-15-2019, 02:12 PM   #14
KCTiger
Drives: 2016 X5M
I am considering adding a sub (with dedicated amp) but am on the fence. I think the 8" subs in place now would serve as excellent mid-bass drivers but I am skeptical they can go low, especially with bmwx1sq's statement about the amp. I figured it was a bit under-powered for the whole system but didn't know if others felt that way.
      07-17-2019, 11:16 AM   #15
MizikeTSK
Drives: 2015 XDrive 50i MSport
I adjusted my equalizer using some options provided on the forums but turn logic7 off which to me sounded better. I have HK, is it better to have Logic7 on and adjust equalizer then?
2015 F15 XDrive 50i MSport
      07-17-2019, 12:19 PM   #16
sj22
Drives: 14 F15 50I
Logic7 on is better.
I had B&O previously and absolutely hate the HK system. Too much crackle at certain frequencies and very limited depth.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
      07-17-2019, 03:55 PM   #17
merkaba
ah good...i'm not the only one who thinks it's not that great. The equalizer changes did help, but i'm still not impressed.
      07-17-2019, 04:23 PM   #18
duercos
duercos's Avatar
201
Drives: F36>F16>G30
Your cheapest and probably the most efficient way is to add a separate sub 10-12" in the trunk. That's what I did and I love the sound now. I usually keep my equalizer flat and Logic 7 on.
      07-17-2019, 04:38 PM   #19
KCTiger
Drives: 2016 X5M
Thanks for this comment. I want to do the same and was hoping to hear from someone that actually did it. Now we will just have to see how long I can hold off before pulling the trigger.
      07-17-2019, 04:46 PM   #20
duercos
duercos's Avatar
201
Drives: F36>F16>G30
The biggest problem I ran into was finding a good fit for the spare tire well as I didn't want to sacrifice my trunk space. So eventually, after switching 2 different subwoofers and 3 enclosures, I found a good combination
I've got 2 shallow mount 10" JL audio subs and slim qbox enclosures.
      07-17-2019, 05:08 PM   #21
spike5150
Drives: 2020 X5 M50i
That's what I did - sounds waaaay better. But, I like rock music so that is what the system was lacking for me.
For classical, better speakers and amps might be the ticket.
      07-17-2019, 05:14 PM   #22
duercos
duercos's Avatar
201
Drives: F36>F16>G30
I like hip-hop/rap who listens to classical in a beamer anyway ?!
JWK170200.00
