      03-11-2018, 11:41 AM   #1
alvav
Drives: 2015 X5 35d
Ambient lighting Issue
The LED strip on my driver's door is not lighting up. Everything else on door working fine (windows, mirrors, locks). Any ideas?
      03-11-2018, 01:13 PM   #2
turboawd
1636
Drives: 2015 X5 35i
May need to remove door panel and see if you're getting voltage to the bulb /led.
      03-11-2018, 03:58 PM   #3
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
How old is your car. They will fail over time
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      03-11-2018, 05:18 PM   #4
alvav
Drives: 2015 X5 35d
2015. I thought that the strength of led was that they last "forever"?
      03-11-2018, 05:18 PM   #5
alvav
Drives: 2015 X5 35d
I would assume that it can easily be replaced (relatively speaking) if it did, indeed, fail?
      03-11-2018, 06:04 PM   #6
Just have it fixed under warranty...
Maverik2594140.00
      03-11-2018, 10:28 PM   #7
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
LEDs don't last forever. They do last a long time. And they are on ever second your car is on. Plus LEDs never last the advertised lifespan because other components they're connected too will fail. Could be anything from bad solder, chipset, wiring, connectors etc. I mean you can even compare a 2014 to a 2017 and see a huge strength of color (brightness) difference.
'06 C55 AMG (sold)
      03-18-2018, 10:53 AM   #8
alvav
Drives: 2015 X5 35d
I'm going to try changing LED strip myself (out of warranty). I'm good with door panel removal but is there anything specific to know regarding the removal of the actual strip? Thanks
      03-18-2018, 01:14 PM   #9
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
This is a very very sensitive strip, my guess you will end up breaking it. I know that because I broke the one behind the seats. Just take your time and don't bend it in any shape or form.
      03-18-2018, 01:31 PM   #10
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Here's a i video on removing the door panel, but its for passenger side I assuming it might be the same on the driver side maybe a little more wiring due to the window switch.
      03-18-2018, 01:38 PM   #11
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
Are all of the other LED strips illuminating?
I had an issue where several of mine were not illuminating, but some were. It turned out to be an unplugged connector to the bulb under the steering column.
      03-18-2018, 02:24 PM   #12
alvav
Drives: 2015 X5 35d
Only driver door strip not lighting up. I don’t really care too much about breaking it as it’s inexpensive enough. I would assume that it just snaps into place? Thank you all for,the help.
      03-18-2018, 03:31 PM   #13
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Okay then. Please do let us know how you changed it. My 2014 strips are getting quite dim, so I might replace them if it's easy enough!
      03-18-2018, 05:13 PM   #14
turboawd
1636
Drives: 2015 X5 35i
The light is a bulb and it shines on the end of a plastic rod, which acts as a fiber optic.
      03-19-2018, 12:08 AM   #15
turboawd
1636
Drives: 2015 X5 35i
i would imagine the bulb has a part number and could be ordered.
      03-19-2018, 06:12 AM   #16
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
So how do you remove and replace the fiber optic strip?
      03-19-2018, 06:13 AM   #17
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Why would you replace anything else than the RGB LED?
      03-19-2018, 09:20 AM   #18
turboawd
1636
Drives: 2015 X5 35i
You don't replace the fiber optic. Just the black piece at the end which has Bulb inside and shines on the end of the fiber optic.
      03-19-2018, 09:41 AM   #19
qocerhuang
Drives: BMW X5 2019 50i
You sure you are out of the warranty, my 14 still have couple months left.
      03-19-2018, 10:26 AM   #20
Chigger
Drives: 2015 X5
Maybe by miles?
      03-19-2018, 10:32 AM   #21
alvav
Drives: 2015 X5 35d
It looks like the bulb needs to be changed, not the strip. I found these as part numbers, depending on the side:
63319346240 ; 63319321847
      03-22-2018, 09:52 AM   #22
perry8912
Drives: bmw x5
I do notice the brightness of mine is darker than the new one at dealers.....Damn!
