02-03-2019, 11:09 AM | #287 |
Rep 602
I was wondering the same. Do you think the 4ohm load would cause a problem for the factory HK amp?
02-03-2019, 04:33 PM | #288 | |
Rep 277
04-18-2019, 10:42 AM | #289 | |
Rep 95
Drives: 2018 BMW X5 35i
Sub enclosure
What about a JL audio 10W3v3. Mounting depth is 5.93in/151mm |
04-19-2019, 10:30 AM | #290 | ||
Rep 277
06-05-2020, 09:39 AM | #291 |
Rep 62
Full Audio Upgrade
I did a full audio upgrade on my vehicle. Lots of changes throughout the process, but here are some shots of the final product:
Hertz Mille 10" Subwoofer (the sub box spans the width of the vehicle - but is dropped down on the right to accomadate the DSP) Helix DSP-Ultra Mosconi PRO 5/30 and Mosconi PRO 4/10 amplifiers. PRO 5/30: 90 watts @ 4 ohm - to each tweeter (Focal TBM) 185 watts @ 4 ohm - to each midbass (W800-NEO) 660 watts @ 4 ohm - to the sub (Mille 2500.3) PRO 4/10: 120 watts @ 4 ohm - to each front door midrange (Esotar 430) 120 watts @ 4 ohm - to the rear doors (Audiofrog GB) Focal Utopia TBM - Tweeter: Dynaudio Esotar 430 - Front Door Midrange: Audio-Development W800NEO - 8" Underseat Midbass: Helix SDMI25 (to tap into the BMW OEM fibre optic network): https://www.audiotec-fischer.de/en/h...ssories/sdmi25
Helix DSP-Ultra: You can use any brand of DSP with the above SDMI25 - but I have a preference for Helix products (best of the best). https://www.audiotec-fischer.de/en/h...sors/dsp-ultra Cabling goes as follows: Toslink Fibre Input at the back of the unit (single black/red plug from the SDMI25). Then on the front, the RCA outputs (from left to right) are:
As mentioned; I've made a number of changes along the way (including a complete rebuild of the trunk layout). Full build log can be found here: https://www.diymobileaudio.com/threa...7-2020.423805/ Last edited by JimmyDee; 06-05-2020 at 11:12 AM.. |
07-13-2021, 12:07 AM | #292 |
Rep 164
Some legit builds in here! Waiting for my sub to come (Thursday). Grabbed the basser box from the classifieds and a 8w3v3, built a bracket for the amp. Just needed something better than the stock sound. Should be done Thursday.
FCX52407.50 |
07-13-2021, 11:40 PM | #293 |
Rep 164
For the life of me, I can't find an accessory wire that only turns on with the ignition. What is everyone using for remote? Ive never had an issue finding a source but this is ridiculous
07-14-2021, 01:30 PM | #295 | |
151
Rep 302
Drives: 2017 BMW X5M
2 optima yellow tops/along with factory two batteries 6 PRV AUDIO 5MR450-NDY 4 225 Watt RMS EACH On a Taramp 2000x4 Amplifier 2 Massive Hippo XLR 15" For Bass on BASS 8K TARAMP AMP Remove the underneath seat subs for Massive Shallow Mount Midbass 8" 4 Tweeters are replaced with Skar Audio 1" Dome teeeters on 400x4 Taramp CHUCHERO- B&C 10" Mid bass 700 watt RMS each My truck is a party sound lol!! DSP I had was helix mini I then upgraded channels so I went with Audio Control DM-810 with Bluetooth adapter very good DSP Helix is better but the helix with 13 Channels was too expensive for me |
07-14-2021, 02:26 PM | #297 |
Rep 218
JimmyDee helped me a lot with an aftermarket sound system design. I didn’t have his skill or patience so used a professional shop for the install other than building the subwoofer enclosure myself.
https://f15.bimmerpost.com/forums/sh...17&postcount=8 Below is a link to the entire thread. https://f15.bimmerpost.com/forums/sh...php?p=25767313 |
07-18-2021, 06:23 PM | #299 |
Rep 18
07-18-2021, 08:40 PM | #300 |
Rep 164
07-31-2021, 04:00 PM | #301 |
Rep 23
I just completed the complete stage 1 and underseat ghost sub replacements of BAVsound. I still have the factory amps. I did however extensively use BlackHole Sound deadening on all 4 doors. That has been the most dramatic change to the vehicle. I would highly recommend to everyone. That being said, I am not that impressed with the BAVsound. It is a decent upgrade but not super impressive. They certainly don't sound like Focals, nor should they at the price point. My main complaint now is the lack of Bass. I have completed the 12 hour break in. I think my next step will be to add 2 of those shallow mount JL 10TW3-D4. Thinking some decent power to the subs and a bass control and the system will have a complete sound reproduction range. Then finally, the question remains. Spend $1500 for the BAVsound amp or get something better and customize my DSP.
07-31-2021, 06:09 PM | #302 | |
Rep 5,015
Good feedback here. Doesn’t Fischer Audio make a plug n play amp for these vehicles. Should be half the price of that Bavsound unit and accomplish the same thing. |
08-01-2021, 11:17 PM | #303 |
Rep 123
Drives: 2021 BMW M2 Competition
Garage List 2018 BMW X5 35d [0.00]
1970 BMW 2002 [0.00] 1991 BMW M5 [0.00] 2005 BMW 330 ZHP [0.00] 2021 BMW M2 Competi ... [0.00] |
Wiring Question
I have a self powered sub that I removed from my former e53 X5 and I want to install it into my new-to-me 2018 X5 35d with the Base 645 Radio Control US, 655 Satellite Radio and 676 HiFi Loudspeaker Sys. What I did on the former X5 was to tap/splice into the wires that ran to the factory sub and then thru a PAC LP7-2 to convert to Line Level input. Attached the power straight to the battery with an inline fuse and ran a ground to a ground stud. Has been Working great for many years. So, Curious if anyone know a good location to tap into the sub level wires? I can figure out the power.ground. I'm guessing I will hear at the speakers under the front seats, but I am hoping to find something in the rear side compartments, like my former X5, near the amp.
Thanks in advance should anyone have an answer. |
08-04-2021, 09:19 PM | #304 |
Rep 30
I want to upgrade the speakers and amp in my F16. Debating if I want to take it to a shop or replace everything myself. The step by step videos on youtube by Bavsound and Bimmertech make the process look easy. I do not want to make any modifications to the system, just simply want to replace the stock HiFi speakers and AMP with high quality stuff. Looking at Focal speakers and amp. Can anyone attest to the simplicity (or difficulty) in replacing everything yourself?
08-05-2021, 05:55 AM | #305 | |
Rep 2,652
The sound is better than the original in every way possible! |
F87 S55158.00 |
08-05-2021, 07:32 AM | #306 | |
Rep 403
F87 S55158.00 |
08-07-2021, 06:11 PM | #307 | |
Rep 123
I keep reminding myself that a Car/Truck is NOT ever the best environment to re-create sound and play music. But, the other side says, but why not try to make it a good place to listen!?!? Thanks for the feedback. Last edited by F87 S55; 08-07-2021 at 06:14 PM.. Reason: spelling error |
08-07-2021, 06:22 PM | #308 | ||||
Rep 23
