01-29-2021, 06:04 AM | #23 | |
Rep 30
Code I am getting is FF480A |
01-30-2021, 07:17 PM | #24 |
Rep 6
Got mine fixed on Friday. Took it to the Indy shop that changed the auxiliary battery out last week, TMJ Bimmer in Northwest Houston, and they scanned it, and determined the culprit to be the right rear wheel speed sensor. Every time the Chassis Stabilization Error and Parking Brake Reduced Error were triggered, it was after the wheel speed sensor caused a fault. So, $379.00 later for diagnostic, parts and labor and a couple hours waiting to get the part from BMW, no more issues so far.
Vivek.1367.50 |
02-06-2021, 12:30 PM | #25 |
Rep 30
I fixed this issue !!
I fixed this issue YEAY!!!
The problem was ABS speed sensor. I change both from the rear. Reset by disconnecting the battery. Issue resolved. No more messages or warning lights.
2014 X5 35D
Diesel Power! |
Vivek.1367.50 |
12-19-2022, 01:55 AM | #26 |
Rep 6
12-19-2022, 02:05 AM | #27 |
Rep 1,532
Take off the wheel, locate the ABS speed sensor:
Remove and replace; one end is held on with a ~5mm allen and the other end unplugs from the connector.
04-15-2023, 08:20 AM | #28 | |
Rep 6
06-01-2023, 10:17 AM | #29 |
Rep 28
I apologize for bringing up this old thread. I had a similar issue with my 2015 BMW 320, it turns out that I had a ball joint issue, I heard a rattling noise while I’m driving the other day then the error code popped up. I took it to the shop so I can replace it immediately because it affects my driving and control of the car. I did a lot of searches on this issue and came on in depth article which may be worth reading, search for " BMW chassis stabilization malfunction drive moderately on YOUCANIC" and you will see an article that goes over common causes and possible fixes, you can read about it yourself. I hope this information can assist someone else with a similar issue.
