08-04-2018, 11:06 PM | #199 |
Rep 239
So can I have traffic jam function without installing any chips?
08-05-2018, 01:35 AM | #201 |
Rep 535
You will either need a module + new steering with touch sensor, or need a chip.
Present: 2014 X5 50i
08-05-2018, 07:44 PM | #202 |
Rep 982
Hope you have success. Mine is still working great.
08-06-2018, 03:11 PM | #203 | |
Rep 7,160
08-07-2018, 06:40 PM | #204 |
Rep 535
I am getting the same issue others. VO coded everything, then verified FDL coding and now lane departure vibration and TJA both don't work. Tried removing and reinserting the chip a few times as directed.
Maverik259 Do you have the m-sport steering wheel, or regular?
08-07-2018, 11:12 PM | #205 | |
Rep 7,160
08-09-2018, 10:08 PM | #207 |
Rep 844
08-12-2018, 09:00 PM | #208 |
Rep 535
A loose cable essentially. Probably I was too aggressive when installing it but noticed after removing quidzel that one cable was loose and the errors with and without Quidzel were the same. Just resoldered and everything solved. Their customer service is quite nice I must say as they had shipped a replacement just in case already.
Also adding TJA will reset KAFAS2 to Euro specs that means lane departure warnings will only get enabled at higher speeds. I had to manually set THRV_AVAI_TLC_HIGH: USA_and_UK = 28 THRV_AVAI_TLC_LOW: USA_and_UK = 25 |
VP50023.00 |
09-05-2018, 09:09 AM | #209 | |
Rep 1
09-05-2018, 12:19 PM | #210 |
Rep 982
09-06-2018, 10:16 PM | #211 | |
Rep 7,160
09-10-2018, 10:19 PM | #212 | |||
Rep 570
When you take the car into the dealer and they need to do something that requires a reset of you FDL files which happens more than you think and for smaller reason you would believe... you will get a nice surprise to put it nice. When you add something VO it's permanent so to speak and everything that is done at the FDL Level can be reprogrammed, but it's nothing that will throw any codes as it just returns it back to what it would have been factory if it would have come with the function... only allowed on freeways, speed cut of at XYZ Speed etc. - but fully functional. BTW cool that they have a "easy fix" nowadays, on the other hand I'm kind of glad to have the wheel with the touch sensor, as it sure adds an extra safety layer... |
Maverik2594140.00 |
09-29-2018, 07:07 PM | #213 |
Rep 48
I installed Quidzel and did all the coding but the steering wheel icon doesn't appear. I didn't notice any errors. I emailed Quidzel about the situation but was wondering if any of you ran into this..
09-29-2018, 08:19 PM | #214 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Do you have a car in front of you?
Freude am Fahren.
09-29-2018, 08:49 PM | #215 | ||
Rep 48
Nope - I guess that may be the reason why it didn't show up lol |
Twin Peaks94.00 |
09-30-2018, 12:13 AM | #216 |
Rep 118
I bought the Quidzel sensor and installed it (super easy 10 min job). I still have to do the coding. I see the instructions earlier in the thread, but they all say to "activate 5AR", then do the coding. So my request is, can someone post a step by step on how to turn on the 5AR, then what order to do the coding? I really appreciate it...I suppose the VO method would be best?
09-30-2018, 08:49 AM | #217 | |
Freude am Fahren.
835
Rep 1,287
09-30-2018, 08:50 AM | #218 |
Freude am Fahren.
835
Rep 1,287
09-30-2018, 02:37 PM | #219 | |
Rep 7,160
09-30-2018, 07:29 PM | #220 |
Freude am Fahren.
835
Rep 1,287
I've done FDL
Freude am Fahren.
Tags |
driving assistant, traffic assistant |
