06-04-2019, 11:08 PM | #1 |
Rep 2,737
F15 B&O retrofit
Well it may have been asked before but not sure if any real answers surfaced so I thought I'd give it a try, I came across a B&O system of speakers and amp but it's incomplete and was wondering if anybody has any company contact or part numbers to obtain the proper wire harness or an aftermarket retrofit harness of some sort. Also I know I'll have to program it but need to somehow source the harness.
Many Thanks for any info anyone can give. |
06-05-2019, 10:04 AM | #2 | |
Rep 277
sbinshihon684.50 |
06-05-2019, 01:57 PM | #3 | ||
Rep 2,737
06-05-2019, 04:01 PM | #4 |
Rep 145
Here the wiring B&O: https://www.newtis.info/tisv2/a/en/f...audio-speaker/
Here the wiring HK: https://www.newtis.info/tisv2/a/en/f...p-hifi-system/ You can see the difference... |
06-05-2019, 04:13 PM | #5 | |
Rep 2,737
Yea I know it doesn't make any sense but I love to tinker, keeps me sharp! Thanks for the info !! |
06-05-2019, 06:56 PM | #6 |
tends to get irritable
202
Rep 798
It's more than just a single harness set that's needed. Depending on what you're starting out with then you would need new runs into the front doors, dash and power for the tweeter to raise. If coming from HiFi/676 then you also need additional runs into the rear doors as well as reroute/add to the MOST network.
If you want it as a project that's cool but it's a lot of work for a mediocre result.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
bmwx1sq145.00 |
06-05-2019, 06:58 PM | #7 | |
Rep 2,737
Yea I understand about the lot of work for little gain but if you knew the other bmw projects I've done this is a walk in the park. Not the best use of time I agree but I enjoy it |
06-05-2019, 08:40 PM | #8 |
1642
Rep 2,995
06-05-2019, 09:40 PM | #9 | |
202
Rep 798
Since you mentioned it though.. what else have you done ? lol
06-05-2019, 09:42 PM | #10 | |
202
Rep 798
FWIW though, the rust is pretty normal and X5s definitely do not have the prettiest brakes. If it's on the rotors themselves it'll go away after driving a block or so.
06-05-2019, 09:53 PM | #11 | ||
Rep 2,737
But my previous projects where a z4, mini, e70x5, 135is, i3, and a bunch of e30's and a few Audi's but basically I love to make them as close to how I would have specked them plus a little extra. This x5 came with close to everything I would have wanted but got some freebies and don't mind spending some time doing this stuff, I'm an automotive designer and doing stuff like this helps me be a better designer as when I work with engineers on a daily basis these special projects help me learn the vehicle and learn interesting ways to solve problems. I've seen some you tube videos where some people just install the center speaker and swap the speaker faces for the look, maybe that's an avenue but I'd like to investigate my options, that's why I asked about wire looms and such. Thanks to all that have helped. |
