02-21-2017, 06:10 AM | #1 |
Rep 61
Easy Exit Driver Seat coding
Soooo, after owning several cars (as old as 2002) that had an Easy Exit Driver Seat option, I kind of gotten used to it.
When I turn off my 2014 35i the seat does move back a couple mm and so does the steering wheel. I would like it to go back all the way and down... and have the steering wheel go forwards and up all the way either at engine off or at door opening... Does anyone know if this can be done? I'm sure that it can being that the seat and steering wheel do move a little bit.
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package |
02-21-2017, 08:41 AM | #2 | |
Rep 18,686
02-21-2017, 10:35 AM | #4 |
Rep 5,066
Lets just hope there isn't anyone sitting behind you when the seats squash them
02-21-2017, 10:42 AM | #5 |
Rep 8,364
02-21-2017, 10:52 AM | #7 |
Rep 8,364
02-21-2017, 02:54 PM | #8 |
Rep 98
We went the simple "low-tech" route for my wife (she's 5'1" and likes the seat down low and back a bit for easier entry/exit).
Memory 1: Her normal setting Memory 2: Her ingress/egress setting. She just pushes memory button 2 when she shuts off the car, and memory button 1 when she gets back in. I didn't realize it could be coded. I need to add that to the list of things I need to do.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic 2014 Porsche 991- Sapphire Blue Metallic |
Dataready15.00 |
02-21-2017, 09:37 PM | #9 | |
Rep 8,364
What is nice about coding is that you can set move back distance and restriction zone; but key is to do measurements and realize that any initial adjustments will cease movement. I forget whether last seat position should be selected or not but key profiles allow for different drivers. |
Class5Kayaker52.00 Jingming880.00 |
02-22-2017, 04:27 PM | #10 | |
Rep 51
Jingming880.00 |
02-22-2017, 06:39 PM | #11 |
1150
Rep 2,426
Am I the only one that actually doesn't like easy entry exit functionality? As far as I'm concerned one day I'm going to be somewhere my seat will be back all the way the steering wheel is stuck in the dash… and it stays that way.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
02-22-2017, 07:56 PM | #12 |
Rep 18,686
Do it while you still have warranty, haha.
02-23-2017, 06:05 PM | #14 |
Rep 1,352
Drives: 2018 M3 CS
NVM. Figured it out. Seems to be reliant only on ...
3000 EINAUSSTIEGSHILFE = Modus_FA_SLV
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG Last edited by TN_3; 02-23-2017 at 10:34 PM.. |
02-24-2017, 09:46 AM | #16 |
Rep 48
Does this coding also release the back bolsters as well? I could swore I've felt it with sport seats but I can't figure it out with my multi-contour ones.
02-24-2017, 09:53 AM | #17 |
Rep 8,364
If you are referring to the side bolsters, that is one aspect of the seats that I have not experienced any profile connection.
02-24-2017, 08:14 PM | #18 | |
Self-Deprecating Narcissist
7263
Rep 6,561
i have multicontour seats and the bolsters open to widest point upon exit and then go back to your settings when starting the vehicle.
02-25-2017, 09:58 AM | #19 |
Rep 48
02-25-2017, 12:31 PM | #20 |
7263
Rep 6,561
I don't know, it did it from day one for me. I never had to code this.
02-25-2017, 06:17 PM | #22 |
7263
Rep 6,561
the seats and steering wheel adjust faster than the cold start idle hunt/cat pre-heat stag is over. before the motor is even ready to be put in drive your seat adjustment is completed. if you drive off before the memory sequence is completed the system will stop and it will not go to your stored position. at that point you would have to get the adjustments done by holding down the 1 or 2 button.
