      11-08-2016, 06:01 PM   #1
Never_Enough
Drives: Satan's Chariot 2.0
Angry Cannot get MS Office to work properly!!
Never had any problems like this before, but no matter what version (2010, 13 & 16) it will install fine & work fine at first, but then when I restart the computer, it will go through office setup every time no matter what.
I've tried several valid files from torrents as well as a legit Office '13 from work & it does the same bs every time.
Anyone have this issue before? How did you fix it?
      11-15-2016, 06:35 AM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Originally Posted by Railgun View Post
Yes, I used a non-pirated copy.
      11-15-2016, 06:46 AM   #3
Never_Enough
Pay attention now, not every copy I tried was pirated.
Also, never had problems with pirated copies before.
      11-15-2016, 09:41 AM   #4
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
Completely remove all versions of Office from your computer. Not just uninstall, but after uninstall remove all Office folders and registry settings. May have to download Microsoft's uninstall utility to completely remove. Do a fresh install.
Steve
      11-17-2016, 09:42 AM   #5
core22
core22's Avatar
140
Drives: X3 M40i / 911 C4S
I moved to Libre Office, a free open-source MS Office alternative. The files are 100% compatible as well. The only issue I have is that I cannot open my archived Outlook PST files within Libre Office, but I have a VM that has office installed for that if needed.
Current:
2019 911 targa 4 | GT Silver Metallic
2019 X3 M40i | Glacier Silver
Past:
2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi
      11-17-2016, 12:50 PM   #6
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12503
Drives: M4CPC // HP4 Comp.
Delete your whole office files, folders, settings and clean the registry.
After that make an offline installation of the desired office version, that worx although some ppl state it dont.
After that you have to replace one or two certain *.dll files and when you then after reboot connect the www you should encounter no failures with you hijacked version.
But as recommended previously, OEM is the best and to close my 50ct here: No, I wouldnt provide the necessary files.
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      12-01-2016, 05:56 PM   #7
Never_Enough
I didn't do anything on the net when I installed it the 99999 times it didn't work. Which .dll files? You are capt vague.
Also, once again, I have tried an OEM version & had same results!!!
      12-01-2016, 08:12 PM   #8
gtron
powerhouse
gtron's Avatar
Drives: 2014 Porsche 981 CS
Also, check the startup applications to see if there's something weird going on at boot.
If that doesn't work; mount and roger.
no signature. except for this one.
Search this Thread:
Advanced Search
