07-22-2022, 01:16 PM | #1 |
Rep 41
X5 35d HPFP failure expectations
I have a 2015 X5 35d just hitting 85K miles. I'm planning a long summer trip. I've heard I'm at the mileage where HPFP failure is possible. Are there any indications of impending failure? Is this a common problem or rare? Maybe I should take my GLE on the trip instead?
I would hate to ruin the trip with a disabled car on some back road in the mountains. |
07-22-2022, 02:29 PM | #2 |
Rep 2,514
Where did you get that information from? Yes, HPFP failure did happen but if I remember correctly it was defective pumps on the early production MY or low quality fuel. In most cases BMW would proceed with fuel test to verify fuel quality. In my opinion you will be perfectly fine as far as you change your fuel filter and use good quality diesel from high volume pump (big truck stops by the highways with branded stations are the best, try to avoid GAS&SHOP in the middle of nowhere).
07-22-2022, 08:52 PM | #3 |
Rep 546
I'm sitting at 117k right now, MY14… zero issues. Don't ride your SUV until empty or close too. 🤷🏽
07-23-2022, 01:14 PM | #6 | ||
Rep 629
As others mentioned OP, fill up at high-turnover stations and you should be fine. Others swear by fuel additives but I avoid them because it voids BMWs extended warranty on the pump. |
