11-23-2014, 05:50 AM | #45 | |
Rep 420
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
12-06-2014, 12:10 AM | #46 |
Rep 25
Any long term issues and longevity of chip
Hi - I'm wondering if there is any long term negative impact that occurs with the engine from using a chip? I plan on keeping the my X5d at least 5 or 6 years. Also, how long do chips typically last? I'm new to this stuff but am intrigued by what I've read so far. Thanks in advance!
12-06-2014, 10:53 AM | #47 | |
Rep 710
For your info, I installed the Dinan software in my 550i and drove it over a weekend. It was a tune to bring the engine up to M performance standards. That car would not have made it past 75,000 - 100,000 miles and I removed the software on Monday. I don't care what Dinan says. You can't have that power at your right foot and not nail it and nail it often, but the car was not designed to take it. I actually bent a suspension part on my 550 that weekend, which explains why Dinan sells that part as an upgrade. Anyway, to answer your question, I believe the chip brings the engine up to European standards, but you can also dial back if you're not comfortable with the power or where it's delivered. For example, I will dial mine back for snow (if it snows here in GA) because it will be a handful on slippery roads the way the power is applied to the road. In addition, the RC can be set to apply torque and HP at various points in the RPM range. I too paid for my car and plan on keeping it as long as you. I have an 05 Powerstroke diesel that's chipped and has been for 6 years. It's running just fine because I chose a tune that improved throttle response and very low-end torque to pull a 4-horse trailer. Also, I will never use the highest level tune for this engine since it came from the factory already tuned within its design limits, and I will monitor its parameters (oil temp, coolant temp, EGT, fuel pressure, tranny temp, air intake temp) each time I pull a heavy trailer (12,000 lbs and up) to make sure I am not abusing the motor. But again, it's running perfectly and I plan to keep it until the wheels fall off. The key with my Powerstroke, SL550 and the X5 is to keep it well maintained and use quality components in the process. With everything I own, I change the oil every 5,000 miles , the fuel filters every 50,000 miles (Powerstroke every 10,000), the air intake filters every 10,000 miles, the tranny fluid every 30,000 miles, differential fluid every 50,000 miles, coolant every 50,000 miles and you get the picture. By keeping my receipts, I also get above normal resale value. And chips don't go bad if they're mounted correctly, meaning away from moisture and heat, and the wire routing is away from heat, pinch-points and not stretched at the connectors. I think the RC is warranted if installed correctly. Install the chip, respect the car and the maintenance schedule, and I think you'll be happy...
12-06-2014, 02:49 PM | #48 |
Rep 25
That helps a lot!
Hey, thanks for the thoughtful and detailed response I really appreciate it!! I'll pick up the truck on Monday and probably run with it as is for a couple weeks before getting and installing the RC. I'll set it at the setting that many others have recommended (E2) if I'm recalling it correctly. Thanks again for the guidance with this.
12-06-2014, 03:00 PM | #49 | |
Rep 3,990
12-06-2014, 03:35 PM | #50 |
Rep 25
Thanks Opasha! It sounds very straight forward but I'll ask more questions if needed once I get to installing it. I continue to be amazed at the great information available on this site especially for those of us who need it to be communicated in layman's terms.
12-06-2014, 03:37 PM | #51 | |
Rep 3,990
12-08-2014, 12:56 PM | #52 |
Rep 4,114
42pilot, I am not surprised to your findings as Terry from BMS openly stated his diesel chip does NOT support F chassis cars.
I am looking into possibly adding a powerstroke to my stable. Any words of advice on what to look for and what years are more reliable than others?
Current: 21 M5 Comp, 23 M3 6spd, 23 i4, 20 Tundra TRD PRO
01-16-2015, 04:09 PM | #53 | ||
Rep 16
How often does RC release updates to the chips firmware? |
