08-09-2023, 12:03 PM | #23 | |
Rep 442
Do you have ista? It will show you the wiring diagram and you can check voltage. |
08-09-2023, 02:26 PM | #24 |
Rep 627
Drives: X5 F15 M package
Do you have an install behind your nbt ? Check the optical cord is plugged well.
08-10-2023, 06:14 AM | #25 |
Rep 1,760
I would walk through the whole MOST sequence again. If somehow your amplifier was blown when you reinstalled the BSD then maybe something else got impacted. Maybe your bluetooth module is bad? Sorry to hear though that you are suffering through this...it was painful to be without sound for over 7 months and wished I had just sucked it up and took it to the dealership sooner but the only good thing is that because I did my own troubleshooting, I knew what to remove in their "recommendations" which included replacing the amplifier because he "saw" it had water impact.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
10-14-2023, 06:49 PM | #26 |
Rep 94
So my 2015 was exposed to some heavy rains today. Long story short water got on the front right carpet and underneath. I lifted the carpet and dried it as soon as I could. But while I was driving with the water on the carpet the speakers we're making crazy sounds and eventually stopped. What do I look for now? Possible fuse blown? Can anyone assist me please. First bmw
10-15-2023, 01:43 PM | #27 | |
Rep 442
Plus you probably have more water under the carpet. And water probably got on wiring harness. Probably need to lift the carpet in more places. |
10-15-2023, 03:44 PM | #28 |
Rep 94
They were and I think I cleared them out. I ran water down the sunroof later and confirmed it was coming out the bottom. I did some testing and the 50 amp fuse above the battery is in fact bad. That whole assembly has to be replaced correct? It's what it looks like
10-16-2023, 08:12 AM | #30 |
Rep 94
