12-29-2022, 04:04 PM | #67 |
Cattlecar
42
Rep 141
I have an F15 with DHP and when I changed the rear center I drained it for an hour, maybe 90 minutes, and I put about 1.2L to fill it to spill out level. I used GM Carbon Mod 75/85 in the outer side gear/clutch compartments. I got it from a GM dealer that sells on Amazon. GM 92184900. GM uses a few diffs requiring the same spec fluid and a litre bottle is $30 or a little less. You need 3 of the BMW $68 1/2 litre to get the 1.1 L it takes to fill those two compartments. I know people have said they used 75w140 synthetic gear lube for that but using the wrong fluid may not be like the TC where wrong fluid gives symptoms. If the wrong fluid is used and the diff fails to lock you might not know it in many situations.
12-29-2022, 04:21 PM | #68 | |
Rep 1,019
https://f15.bimmerpost.com/forums/sh...1820554&page=8 Yes the official capacity is like 950ml. Maybe what we drained was what the dealerships put in on the first service post break in. Dono. |
01-09-2023, 01:18 PM | #69 |
Rep 1,179
OK, I’m an idiot! Long story short, I put the G3 in the front by mistake. The next day I transferred it back out to a clean bottle and put the G2 in.
Now I have a bottle of G3 that was sitting in the front diff for a day and I’m wondering if it would be OK to use it for the rear. I’d just buy a couple of new bottles but it’s $150 and 2-3 weeks out. Am I safe to use the stuff that I put in and took out of the front diff? |
01-09-2023, 04:43 PM | #70 | |
Rep 234
skoold2003791.00 |
01-09-2023, 09:29 PM | #71 | |
Rep 7,160
skoold2003791.00 |
01-09-2023, 09:32 PM | #72 | |
Rep 7,160
Couldn’t even get the full .9x into the front before it started spilling out. It was close though. It definitely all but stopped dripping before I closed up the drain. Oh well. Next guys problem. Haha jk
01-09-2023, 09:57 PM | #73 | |
Rep 1,179
Well it’s good to hear that the diffs aren’t too sensitive to what you put in. The part of my story that I was more concerned about was whether I can use the fluid that I put in and took back out. It got pretty dark after sitting in there for a day. I cleaned the water bottle out with alcohol and tried to make it as sterile as possible. |
01-10-2023, 12:05 AM | #74 |
Rep 5,002
01-10-2023, 10:12 AM | #75 | |
Rep 234
skoold2003791.00 shimmy232350.00 |
01-10-2023, 12:12 PM | #76 |
Rep 1,179
You see, this is why I love this forum.. brilliant idea! Also, this is why I love FCPeuro because they are sending me new oil under their policy. I wish I could buy all my car parts from them!
shimmy232350.00 |
01-11-2023, 09:31 PM | #77 | ||
Rep 7,160
Yes sorry I knew that. I meant like the weights. GL2 vs GL3 means little in the broad scheme. BMW used to recommend the same oil and then as if someone farted. They changed to a slightly different one.
01-12-2023, 12:27 AM | #78 |
Rep 1,179
I always thought their recommendation was to keep the filthy old oil from the factory in it..
01-15-2023, 11:08 PM | #79 |
Rep 7,160
They still have a recommended oil for it upon replacing. Some models they say Diff is lifetime. Others not. Either way they have oils listed and they differ from front to rear and if you have LSD.
skoold2003791.00 |
01-19-2023, 12:44 PM | #80 | |
Rep 1,179
My front diff had some tubing mounted below the fill plug which made it super awkward to get to. https://youtu.be/aG4bb6S6V2w |
01-24-2023, 10:07 AM | #81 | |
Rep 7,160
01-31-2023, 02:51 AM | #82 |
Rep 1
Hi All,
New to the group. I have a question (thanks to all for the advise) relating to a spring changes (rear wheels) I got some noise coming up, took it to dealer and they say it is differential needs replacing. Haven’t had this noise previously until the spring change. Any ideas!? Could it be that oil/fluid needs replacing!? Just over 100k F15 X5! Thanks 🙏🏼 |
02-01-2023, 10:53 AM | #83 | |
Rep 112
06-07-2023, 04:52 PM | #84 |
Rep 68
Hi all, I wonder if anyone used RedLine 75W85 on F15 front and rear differentials and how's experience so far? Also, did you guys filled the front and rear diff up to a fill plug? I ran into some posts where people are saying that the front diff needs 600 ml which is about 200 ml less if filled up to a full plug.
06-07-2023, 05:35 PM | #85 | |
Rep 270
An easy service with reasonable tools (I have an Quick Jack which is great), front is harder due to the undercarriage stuff you have to remove and the fill plug is a little bit challenging. I used a hex driver with a narrow wrench to loosen and tighten it. I tried just about every combination of extended ratchet drives with no luck due to the awkward angle of attack and narrow space. Wrench and hex drive bit made it quite easy. |
06-07-2023, 06:34 PM | #86 |
Rep 68
Thank you, I was under impression that GL5 is required for the rear diff but looks like the RedLine GL4 works as well.
07-23-2023, 08:44 AM | #87 |
Rep 18
Valvoline 75W-90 in both front and rear diff;
This is one idea that I did adopt from that one guy on UToooob. He clearly stated that he’s tested it true over 50,000 miles. Transfer Case oil for sure is BMW, but other good, less costly alternatives probably exist My 2014 X5 35d is riding smooth as silk now, and I’m gaining confidence in the Valvolne solution ( engine oil Penzoil PPE 5W-40 ). |
07-23-2023, 09:13 AM | #88 |
Rep 1,340
Are you using the right oil for your 35d? AFAIK, Pennzoil PPE 5w40 only has LL01 certification and not LL04 that’s used in diesel engines. Did you mean 5w30, which meets LL04?
