08-10-2020, 05:10 AM | #1 |
Rep 5
30d diesel engine full carbon cleaning and timing chain replacement?
Hello everyone,
Thanks for adding. Greeting from Hong Kong. This is my first post. Mine is a 2014 F15 30D currently on 110k km (~70k miles). What is the recommendation to perfrom full carbon cleaning to engine? Is it a good idea to replace timing chain as a preventive maintainance? at what mileage? Thanks again. |
08-10-2020, 10:25 AM | #2 |
Rep 1,168
I wouldn't worry re chains till ~200k km, unless you can have them done for cheap, and/or excessive slack and wear have been detected.
Carbon clean up- again, based on inspection results. |
08-11-2020, 08:04 PM | #3 | |
Rep 5
Thanks. Do you know if there is a easy way for me to check for indication that it will need a carbon clean? |
08-12-2020, 07:49 AM | #4 |
Rep 1,168
The easiest would be to use an endoscope, I imagine. Your intake and EGR will be dirty in any case, so if you consider doing it, I'd remove (and clean) those regardless.
08-12-2020, 07:07 PM | #5 |
Rep 5
