      01-09-2020, 11:04 AM   #23
yewlock
yewlock's Avatar
Drives: X5
Originally Posted by hufington View Post
Here you go. This is the only one so far I snapped since the car is dirty. Sorry for the weird vignette effect that the phone added automatically for some reason. I will take more close up pics after I wash the car.
I installed a separate switch for both pairs. I did not want them to turn on at the same time all the time as I am going to change the light covers and get yellow ones to cut thru rain and fog.
I manufactured a hard plastic plate to cover the ash tray and installed the switches on top of it.
I was actually going to replace the OEM fog light and install the BD lights into the 4-inch factory opening but then I decided that it was not worth going through all the possible error messages and additional coding to make them work like the factory ones.
Cool features. I think that if you add a auto eject button, the car will be perfect.
hufington3120.50
      01-09-2020, 11:33 AM   #24
hufington
hufington's Avatar
3121
Drives: 2022 X5 m50i
In fact, I had one eject button similar to the missile button that I'd put in the back but some valet stole it. lol
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
orkinos185.50
      01-10-2020, 10:17 AM   #25
hufington
hufington's Avatar
3121
Two quick pictures to show the setup and the lights when they are on:
2022 BMW X5 m50i
Russmov1328.00
orkinos185.50
      01-10-2020, 11:16 AM   #26
Rydogg21
Drives: BMW X5 35D
No Picts showing up for me?!
      01-10-2020, 11:19 AM   #27
hufington
hufington's Avatar
3121
What do you mean?
2022 BMW X5 m50i
orkinos185.50
      01-10-2020, 11:20 AM   #28
Rydogg21
Drives: BMW X5 35D
What do you mean?
The pictures you said you posted are not showing up? Not sure if its my PC or how you uploaded them.
      01-10-2020, 11:23 AM   #29
hufington
hufington's Avatar
3121
I guess it's you as I see them in my PC, iPad and Bimmerpost Android App on my phone.
2022 BMW X5 m50i
orkinos185.50
      01-10-2020, 11:30 AM   #30
Rydogg21
Drives: BMW X5 35D
Work firewall blocked them, sorry about that.
      01-10-2020, 12:01 PM   #31
hufington
hufington's Avatar
3121
No prob.
2022 BMW X5 m50i
orkinos185.50
      01-10-2020, 01:31 PM   #32
hufington
hufington's Avatar
3121
Now it is time for some rear fogs.
2022 BMW X5 m50i
orkinos185.50
      01-10-2020, 07:41 PM   #33
ixlr8
Drives: 2016 X5 35i
I find the LED fog/cornering lights on my 2016 X5 to be useless. They shine about 3 ft in front of the car and about 2ft off to the side of the car. I had the car over a year before I finally noticed them coming on in a turn. Is there any way to adjust/aim them?
      01-10-2020, 07:57 PM   #34
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Replace the bulbs with LED bulbs and you will see big difference
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      01-11-2020, 01:35 AM   #35
hufington
hufington's Avatar
3121
I did not know that there are brighter LED bulbs to replace the OEM LED bulbs.
2022 BMW X5 m50i
orkinos185.50
      01-11-2020, 06:42 AM   #36
delviacv2
delviacv2's Avatar
Drives: 2014 X5 50i & 2015 535d
You have the perfect Solution already Installed from factory!
Get Esys and Code your LED Headlight for GFHB, I had this in my previous 35d and is amazing how much more you can see, specially Deer, I miss it so much that my current 50i has xenon headlights and i'm in the process of retrofitting LED headlights that I found on Ebay from a 2018 X5, my car is a 2014.
below is a video of my previous 35d after the coding
Below is a video from BMW that explain the system
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1
-xHP Transmission Flash
2014 X5 50i Carbon Black/ M Sport
-BM3 Stage 1
hufington3120.50
      01-11-2020, 09:22 AM   #37
MK2018
MK2018's Avatar
231
I don't know how bright are OEM LED, I had regular bulbs and in this case it makes big difference
Current
Past
2016 GMC Yukon SLT
      01-11-2020, 09:24 AM   #38
hufington
hufington's Avatar
3121
I have had coded full adaptive headlights with night vision in my F10 550 as well and even with coding, I've preferred to use an extra pair of PIAA RF Cube spots in addition to aftermarket LED bulbs in OEM fog lamps to assist in dark wooded areas and especially in foggy conditions.
The headlights have their limits in terms of illumination and although coding makes them more efficient than the decoded state that BMW delivers them in the US, this does not get rid of the limitations. I have MULTIBEAM LEDs in my MB E63 and there is no comparison in terms of iillumination power and efficiency.
Also, the additional lights allow me to see better and more in rainy conditions where it is harder to see the road surface and potholes.
Another benefit of these Baja Design lights is that you can change the lenses to change the beam patterns and output color.
2022 BMW X5 m50i
orkinos185.50
      01-11-2020, 09:29 AM   #39
hufington
hufington's Avatar
3121
The OEM LEDs suck! As you did, I also replaced the OEM halogen ones in my previous car with aftermarket LEDs and it made a huge difference as you mentioned. But the factory LED foglight bulbs are slightly better in illuminating the road surface than a couple of candles and I could not find any replacement aftermarket bulbs.
2022 BMW X5 m50i
orkinos185.50
      08-05-2020, 05:09 PM   #40
hanggaw
hanggaw's Avatar
4
Drives: BMW X5 F15
Hi. The fog lights look good.
Did you have this installed professionally?
How are the fog lights secured to the bumper?
I'm thinking of doing this too.
Thanks.
      08-05-2020, 07:55 PM   #41
hufington
hufington's Avatar
3121
Thanks.
It is easy if you use the included mounting brackets. I just added some stainless washers to make them more stable. The plastic of the bumper is sturdy enough to carry them without issues.
2022 BMW X5 m50i
orkinos185.50
      08-06-2020, 06:43 AM   #42
ixlr8
Drives: 2016 X5 35i
Please keep us posted on what you do for rear fogs.
I find the reverse lights to be useless and was thinking of adding some rear fogs to come on with the reverse lights so I could actually see something when backing up at night.
      08-07-2020, 08:43 AM   #43
hanggaw
hanggaw's Avatar
4
Drives: BMW X5 F15
I hope you don't mind, I have a few more questions.
I just couldn't find any other guides for doing this out there.
Did you have to remove the bumper for the install? I'm wondering how you were able to access the nut on the other side.
Also, did you have to make a hole through the firewall for the switches?
Do you notice any vibrations/movement on the fog light beams when going through rough roads? The bumper itself seem to vibrate a little when the engine is running.
Thanks.
      08-07-2020, 11:19 AM   #44
hufington
hufington's Avatar
3121
Thanks.
No worries.
To install, you'll need to remove the bumper. I used this as a guide: https://www.newtis.info/tisv2/a/en/f...per/1VnXh8y6Xl
There is no vibration or movement when driving, which would have annoyed me immediately.
I used an existing grommet with a cable harness running through the firewall and used a screw driver to poke through one of the indentations to push the cable through.
2022 BMW X5 m50i
orkinos185.50
