      03-23-2019, 03:28 PM   #1189
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
Originally Posted by MK2018 View Post
VLD Variable Light Distribution on my Xenon lights works excellent
Still can't get ambient lights to work
Got this info from another post. After coding, does your VLD have these features?
Nop, you can code it w/o front camera.
Here is a more detailed explanation about VLD found in Coding Threat thanks to opasha
Variable Light Distribution has several different modes of operation (for Low Beam):
1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12 horizontal from center and 0.7 lowered vertically)
2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH)
3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8 horizontal from center and lowered 0.7 vertically)
4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5 outwards Horizontal from center and lowered 0.25 vertically, while the passenger side headlamp is raised 0.2 vertical) (thank you @shawnsheridan)
Clarification of VLD, HBA, and Anti-Glare/Anti-Dazzle (thank you @skalberti):
VLD is Variable Light Distribution - It only works on your low beams to move your headlights and position the beams on the road depending on steering angle and vehicle speed.
HBA is High Beam Assistant - USA spec high beams that turn off in the presence of headlights or taillights of other cars and automatically turns the high beams on if no other cars are present.
Anti-Glare, Anti-Dazzle - European spec high beams that enable your car to keep the high beams on without blinding other cars.
      03-24-2019, 12:39 PM   #1190
DonJuan
DonJuan's Avatar
538
Drives: G82 M4, F15 X5, F30 328d, E30
What exactly is VLD?
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black
MSport Pro and Prof.
      03-24-2019, 12:50 PM   #1191
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
In simple words your lights are following your turns on the road according to your speed, more you turn more they follow,
It's pretty cool, I love it
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      03-24-2019, 08:37 PM   #1192
DonJuan
DonJuan's Avatar
538
Don't the Xenon lights do that from factory? Mine came that way, I think some people call it Dynamic Lighting Or something like that.
      03-24-2019, 09:40 PM   #1193
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
2018 BMW M550i  [0.00]
From factory, if you have adaptive headlights they will pan however as daytonaviolet mentioned above - depending on vehicle speed the beam will adjust and spread individually with VLD. So a wider beam spread during lower speeds vs highway speeds.
You can see beams widening with VLD enabled on the left in this video...
DonJuan537.50
      03-27-2019, 04:16 PM   #1194
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by maDjzo View Post
I can confirm this worked flawlessly for me, now I'm not sure if it depends on software version as previously mentioned I will post up my version when I get home to confirm. This however took me 30 seconds to code within BimmerCode:
- BDC > Expert Mode > search for line 3070
- Within 3070 > scroll down to the desired Ensamble which will have up to 10 layers below it, F15 utilizes only the first 3
- Example I changed my last 3 Ensembles as I was not using those color patterns, Layer 1 will be top led bar, 2 door handle, 3 lower area AND when I get home I'll also look into the top 2 LEDs in the ceiling panel that fire down that have the ability to change color as well, depending on color pattern, which could be coded as a higher Layer.
- After you select the color desired just code and that's it
Update: Currently on Software 002.255.073, Just checked BMW.com and 003.255.081 is available, contemplating upgrading not sure if I some codes will get relegated..
Update2: Nothing changed after update, all coding as is.
I can confirm this steering wheel heater code works as well.
so how about that screen shot would appreciate a pic of once you're inside 3070 LciMaster and then inside each ensemble layer.
For those of us with older coding but yet newer than original, we only go down to "GROUP_0_FARBE_ENSEMBLE_6"
Ensemble 1-5 each of 8 layers while "6" only has 2 layers.
Also when you go into one of these layers within each ensemble the only options are "UNK_PARAM_0", "UNK_PARAM_1", AND "Unassigned value" which is the one default selected, and "Custom value..."
when you go into the layers are you seeing actual german words representing colors?
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      03-27-2019, 04:30 PM   #1195
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
Yes exactly, colors written in German.
Edit: I apologize but the BimmerPost did not upload them in the correct order.
Edit 2: I'm wondering if you manually adjust the value that's under each color, will that do anything.
Maverik2594140.00
      03-27-2019, 04:41 PM   #1196
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
I for sure changed the colour of the first orange one. It's like a yellow colour but I don't know what I changed or where I did it.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
Maverik2594140.00
      03-28-2019, 06:45 AM   #1197
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ya definitely don't have those colors show up once inside the layers. Maybe I can use those color codes to change it. I'll give it a try tonight.
'06 C55 AMG (sold)
      03-28-2019, 07:20 PM   #1198
MK2018
MK2018's Avatar
231
Let me know if that works, have the same issue
Current
Past
2016 GMC Yukon SLT
      03-29-2019, 10:14 AM   #1199
Jbonly21
Jbonly21's Avatar
Drives: Bmw 15 F80, 2011 X5 35i, E46 M
Hi guys, new guy here. Just wondering if this coding app works on 2011 e70 X5? Thanks
https://youtube.com/user/Jbonly21
      03-29-2019, 12:42 PM   #1200
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
Not this app
http://bimmercodeapp.com/cars/
Carly potentially could be worth looking into, never personally used it.
http://support.mycarly.com/knowledge...t-is-possible/
      03-29-2019, 01:54 PM   #1201
Jbonly21
Jbonly21's Avatar
Not this app
Ok, thanks.
      03-29-2019, 04:32 PM   #1202
artem123
artem123's Avatar
250
Drives: G30
You need Carly.
      04-01-2019, 08:47 PM   #1203
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Probably a good question for the E70 forum.
'06 C55 AMG (sold)
      04-04-2019, 06:23 AM   #1204
jaydubbs1
Drives: 650I
Here is the splash (taken from X5 daily shot thread)
http://f15.bimmerpost.com/forums/sho...ghlight=Splash
Looks Amazing
      04-04-2019, 09:31 PM   #1205
MK2018
MK2018's Avatar
231
[IMG]http://i67.tinypic.com/2jceaee.jpg[/IMG]
Looks Amazing
I have the same one, I like it too
Current
Past
2016 GMC Yukon SLT
      04-06-2019, 09:34 PM   #1206
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Looks Amazing
Since day one. Unless it's Christmas then I change it.
'06 C55 AMG (sold)
      04-07-2019, 09:51 AM   #1207
jo2134
jo2134
jo2134's Avatar
Drives: 2021 X5 M Competition
Originally Posted by mrfochon View Post
Originally Posted by lshiroda1 View Post
I can't find the line in expert mode to change color for ambient light. Can anyone give more detailed info ? thx
In BDC - 3070.
Search for ensemble_layer...
if your software is compatible you can change 8 ensemble, 3 layers. Lots of Video online on the topic as well.
Originally Posted by mpowered5 View Post
Just wanted to confirm it does work. Press the Button and on the bottom of the dash "steering wheel heater activated" and deactivated. Just like every other car does..
Just got mine coded on latest version by adjusting the RGB values after running into some DIY trouble.
Your ambient lighting looks WAY brighter than mine though! Did you do any coding to adjust the brightness?
2021 X5 M Competition Tanzanite Blue II/Black Full Merino with Midrand Beige
Past: 2019 M5 Competition Alpine White/Aragon Brown Full Merino Leather
2018 X5 35i M-Sport Space Gray / Mocha Nappa 20" 469M Wheels
2015 528xi Dark Graphite / Cinnamon Brown
2013 X5 50i Platinum Gray / Cinnamon Brown 20" Y-Spoke Wheels
      04-07-2019, 10:11 AM   #1208
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
Other than selecting the brighter version of the color, I didn't do anything additional. hellgruen, hellblau and hellrot are the 3 brighter versions of set colors it allowed me to code. In that picture the Lila and Gruen (Green) are normal, and the Red is bright red. I'm sure you checked the iDrive Ambient brightness, not sure if ESYS would allow adjustable LED brightness.
      04-09-2019, 01:54 PM   #1209
ed116
hey guys what obd2 are you using `vgate pro ble or wifi? which one is better?
      04-09-2019, 02:04 PM   #1210
maDjzo
maDjzo's Avatar
Poland
862
Drives: G30
I haven't had any issues with my BT, I have a 15' F15 running ID4 and I was able to code everything possible using BimmerCode. Never dropped or failed a coding session.
