      02-08-2018, 10:24 AM   #595
artem123
artem123's Avatar
250
Drives: G30
Originally Posted by sbinshihon View Post
Well, I don't have an alarm
Anyway, it scary that someone can hack into my car while stopping or moving.
Adapter has on/off button. Adapter also turns off by itself after car stopped and locked ( i think not right away, but rather after some time). Anyhow, i live it plugged in.
      02-08-2018, 01:29 PM   #596
Ljn21
Drives: 2017 X5 x35i
Originally Posted by CeeTeeX5 View Post
You need bimmerLINK not bimmerCODE.
ios only? I dont see Link in the play store, only Code on my Samsung S8.
      02-08-2018, 03:09 PM   #597
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Originally Posted by ABZ101 View Post
what does keeping flaps open do? sorry for the noob question
Louder exhaust sound, those flaps control the exhaust sound.
      02-08-2018, 03:27 PM   #598
CeeTeeX5
Is that the only thing that they control? Wouldn't the flap also determine level of backpressure from the exhaust with possible impact to performance?
      02-08-2018, 03:30 PM   #599
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Yes, but that was a quick answer for a nob question. People try to open it for sound as far as I know.
      02-08-2018, 05:07 PM   #600
wjdunn3
Drives: 2014 X5 xDrive35i
Bimmerlink is iPhone/ipad only. Not available for Android.
      02-08-2018, 06:23 PM   #601
Ljn21
Thanks!
      02-13-2018, 08:28 AM   #602
penet05
Drives: 2014 X5 Sdrive35i, 2013 328i
Is Vgate OBD adapter is a must? Can I use other ELM327 adapters? Anyone tried about it?
      02-13-2018, 08:40 PM   #603
Killacam13
Drives: 2018 X5 sdrive 35i
Got my adapter in for the bimmercode app and everything is done easily and most of the stuff in somewhat self explanatory, but could I get some help on the circled items in terms of what changes these make? Most of them our related to trunk closing and opening but don't exactly understand how they relate, esp when it says "footwell" please help!
      02-15-2018, 01:58 PM   #604
Socc1718
Drives: 2015 BMW X5 50i
Im a new member here! 2015 X5 xdrive50i. I did the coding with bimmercode but cant figure out how to add turn signals to the HUD. Can anyone guide me how to do it?
Thank you in advance!
      02-15-2018, 03:21 PM   #605
Mgm 05
Drives: ‘15 X5 35d; '24 i4 M50
To be clear I believe the Android app contains both BimmerCode and bimmerlink where as it’s 2 distinct apps for iOS
      02-16-2018, 08:53 PM   #606
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
Anyone knows how to unable opening the rear tailgate from keyfob via BimmerCode?
      02-17-2018, 03:36 PM   #607
Ljn21
Ok, what am I doing wrong...I can connect to the v-link via wifi, it reads the ecu and shows the menus, I find the option I want to code, change the value and hit code at the top of the screen and it gives an error that I am not connected to the internet....which makes sense becuase I am connected to the vlinks wifi....
      02-17-2018, 05:14 PM   #608
motex
motex's Avatar
Costa Rica
524
Do you have it set to “slow communication”?
Check it out on settings page on BimmerCode
      02-18-2018, 12:51 PM   #609
euro-r
euro-r's Avatar
34
Drives: 17' BMW X5 | MSport | MPPK
Tailgate button in footwell ooperation mode
- the tailgate button that's locate on the driver door's window switches panel (whether you want it to be able to open/close/open & close)
Tailgate remote operation mode
- with the bmw remote, do you it to be able to open/close/open&close
Tailgate button in footwell close with long press
- when it's closing, do you want it to be close with one touch or you have to keep on holding onto the button
Tailgate with remote close with long press
- same with the previous one, but now it's with the remote, do you want it to be close with one touch or you have to keep on holding onto the button
Start Stop function off by default
- the engine start/stop function, whether you want to keep this function off or not
      02-18-2018, 02:44 PM   #610
Mgm 05
Got my iCar Pro Wifi on Saturday and had a chance to play around with the basic settings, planning to dive into expert mode stuff today or tomorrow. Super easy to get started with iOS apps and reading most of this thread in advance was key so i knew about some of the basic stuff like throwing codes and starting w Slow Connection.
Done the following so far:
One Touch Trunk Open/Close w. Fob & Door Button
Mirror Open/Close w. Comfort Access
/M Splash Screen at Start-up
Radio/Nav off on door open
Digital Speed in Board Computer
Disabled Disclaimers at Start-Up
Disabled 2 Horns when Locking while Running
6 Click Indicator - WORKING!
Door Handle LEDs on Reverse
FWIW, i've found i have to clear errors 2-3 times from both the INFO and ERROR Memory sections of BimmerLink to get it to stick. Also think you need to explicitly DISCONNECT in the BimmerCode app to get it to connect in the Bimmerlink app
      02-20-2018, 12:20 PM   #611
RichM50d
Drives: ‘22 8 Series Gran Coupe
Does anyone know if the flashing red LED on the rear view mirror can be disabled using BimmerCode? It’s activating my dashcam motion sensor, so the thing is recording all night!
      02-20-2018, 12:57 PM   #612
CeeTeeX5
We need video proof of the 6 click indicator working
You may be the first to get this to work or bimmercode finally found a way to get this to work.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      02-20-2018, 01:22 PM   #613
sigx5
Drives: X6
really??? 6 click indicator???
      02-20-2018, 04:34 PM   #614
Mgm 05
6 is too many as it turns out so I plan to change to 4 but will get video before in case that ends up backfiring and never working again.
CeeTeeX5936.00
      02-20-2018, 04:36 PM   #615
CeeTeeX5
thanks man!
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
2018 X1 28i M-Sport
      02-20-2018, 06:39 PM   #616
Mgm 05
https://photos.app.goo.gl/PmcMSyKhdcLPP7OQ2
CeeTeeX5 Here you go, don't know how to embed the video, let me know if the link doesn't work. I'll do screenshots of Bimmercode (i'm only touching easy mode) if switch to 4 is a success.
CeeTeeX5936.00
