01-14-2015, 11:44 PM | #992 |
Rep 37
Question Omar,
When you mention that I will lose the turn signal in the HUD after the retrofit, is that the turn direction arrow i will lose or the whole direction navigation indication i will lose, can you point out on my photo. Thanks! in other words, you mean i will only get speed on HUD? |
01-14-2015, 11:49 PM | #993 | |
Rep 3,990
01-15-2015, 06:48 AM | #994 |
Rep 198
Just wanted to say a big 'Thank you!' to opasha for the help with coding. It took literally no time and I am very happy with the results!
Thanks again, man, I highly appreciate your help! Keep up the good work! |
01-15-2015, 07:43 AM | #995 | |
Rep 37
I have successfully got everything coded and installed. please see the photos. I am so exciting now. Just want to say a big THANK YOU to you, everything was followed with your clear instruction, and ends up with this excellent result. One question I still have not worked out is I still cannot get the navigation director on the cluster panel, but it does shows on my HUD. Any advice? |
01-15-2015, 09:05 AM | #996 |
Rep 40,774
Try FDL Coding HU_NBT => KOMBI_AUFLOESUNG = aktiv.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-16-2015 at 05:56 AM.. |
01-15-2015, 11:04 AM | #997 | |
Rep 3,990
For anyone that wants to find the 6WB for cheaper, here is the part number: 62109363265.
01-15-2015, 01:30 PM | #998 |
Rep 2
Cameras while driving
Hi,
I just coded my F11 to leave all cameras activated at any speed. Now after activating the reverse gear the rear camera is activated also. When I'm driving away the rear camera stays activated until I deactivate it manually. Now to my question: Is there a way that the rear camera deactivates automatically after driving away and so switches back to the navigation system, but is able to activate it again manually by pressing the button while driving? I used the following values for the rear camera: V_SCHWELLE_2=FF D_SCHWELLE_2=FF But there are some predefined values I can't understand right now: Abschaltschwelle_bis_09-09 Abschaltschwelle_0Kanal_vorn Abschaltschwelle_ab_09-09 What are they exactly for? Thanks a lot in advance! Chris |
01-15-2015, 03:32 PM | #999 | |
Rep 3,990
Regarding what the codes mean: D_SCHWELLE_1 refers to top view camera distance at which it is disabled D_SCHWELLE_2 refers to rear view camera distance at which it is disabled V_SCHWELLE_1 refers to top view camera speed at which it is disabled V_SCHWELLE_2 refers to rear view camera speed at which it is disabled Regarding the second values: Abschaltschwelle_ab_09-09/ Werte = 0F (default) - change Werte to whatever - FF is the max Abschaltschwelle_bis_09-09/ Werte = 14 (new value choice) Abschaltschwelle_0-Kanal_vorn / Werte = 00 (new value choice) **All you have to do is change the WERTE (value) number of the default first one above, and it will use that. People change it to FF (255 km/h) and this enables you to use the cameras at any speed and any distance.
01-15-2015, 03:52 PM | #1000 | |
Rep 578
01-15-2015, 03:59 PM | #1001 |
Rep 3,990
I personally don't. You'll just have to look up the part number and call around to see who will give you the best deal.
01-16-2015, 03:55 PM | #1002 | |
Rep 8
Does that also mean that LDW and turn signals showing in HUD can't be coded on cars that already have 6WB from the factory? Thanks! |
01-16-2015, 04:04 PM | #1003 |
Rep 3,990
01-16-2015, 04:25 PM | #1005 |
Rep 3,990
If 6WB is still not an option in US dealers, ISTA/P will not read the car if the retrofitted 6WB is present. It still must be removed prior to getting serviced where ISTA/P will be used.
01-16-2015, 08:26 PM | #1006 |
Four stripes vehicle commander
159
Rep 206
Coding...
Soo...waiting for my ENET cable to arrive
I am not too serious about this, but thinking about coding the following - IF possible: 1. Auto start/stop to "active". Very annoying to press the button EVERY TIME. This function got NO value in my personal world. 2. Set tire sensors/TPMS to the "01" state - showing the actual pressure. My BIG guess, even before looking at it - they have automatically been reset to code "00" because driving with wrong (winter) tire sensors for a while in the past. 3. I hate the sharp, white roof interior lighting to shine up when pressing the stop button. I would prefer to "stay in the dark" until I press the roof switch myself. Not sure how (of IF) it is possible to code/fix this although... I am a simple guy and will be happy with this.......... until we order the 258ps/30D with the 7SZ Active Suspension pack...:-))) Happy weekend all, Bent |
01-16-2015, 09:52 PM | #1007 | |
Rep 3,990
01-17-2015, 09:02 AM | #1008 | |
Rep 34
01-17-2015, 11:09 AM | #1009 |
Rep 3,990
You need to use a different image source because your dropbox image links are corrupted or forbidden. No images were posted.
01-17-2015, 12:04 PM | #1010 | |
Rep 545
I've been wanting to make my WLs fade on slowly and have been unsuccessful. |
01-17-2015, 12:58 PM | #1011 |
Rep 34
01-17-2015, 01:35 PM | #1012 | |
Rep 3,990
Yes. I'm just not sure about your specific hardware. Ask your dealer if you can retrofit them.
