      08-01-2022, 04:29 AM   #1
tw1nny03
Drives: 2017 X5
AC issue
Anyone have an issue with their AC?
My AC blows and then it seems it wants to switch mode and stops airflow from the front ac vents.
Then it blows again in the front vents. This happens over and over.
I’ve changed out the resistor on the blower and the problem is still there.
      08-01-2022, 04:50 AM   #2
tw1nny03
Drives: 2017 X5
Here’s a video:
https://youtu.be/GujvYB-G-ng
      08-01-2022, 08:49 AM   #3
tw1nny03
Drives: 2017 X5
Could it be a faulty battery?
Voltage with everything off is 12.1 volts
Voltage on the battery when car is on (with engine off) is 11.2 volts.
      08-01-2022, 10:53 AM   #4
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Mine does the same thing when that low of voltage, believe it goes into Apollo 13 mode and shuts down all non critical systems to have enough juice to start the engine. Proper resting voltage with everything on but engine off is 12-12.5 volts and around 11-11.5+ momentarily when cranking. Recommend having battery checked and replaced before it completely dies.
      08-01-2022, 01:25 PM   #5
tw1nny03
Drives: 2017 X5
I thought I was going to have to replace the blower too!
Guess I’ll buy a new battery and see if it fixes this issue.
Is there a way to check the battery voltage through BimmerCode or bimmerLink?
      08-01-2022, 01:32 PM   #6
SpeedN8
Slower traffic keep right.
SpeedN8's Avatar
Drives: '14 X5 35d & '18 M4 Coupe ZCP
As a test, turn off Sync and rear AC. See if it can maintain. I know that's not a fix but when it's super hot outside and I don't have any rear passengers, I turn off rear AC and gives much more power to the front blowers.
Current: 2022 Tesla Model Y Performance (my daily driver) - 2014 X5 35d M-Sport in Carbon Black Metallic (for towing) - 2018 M4 ZCP (track fun) - 2006 Z4 M Roadster (topless fun)
Past: 2021 Tesla Model Y Long Range - 2011 X5 50i Sport - 2006 750Li Sport - 2003 M3 Convertible - 2001 X5 4.4i Sport - 1999 Z3 Roadster 2.8
      08-02-2022, 09:30 AM   #7
tw1nny03
Drives: 2017 X5
I replaced the car battery. Seems like a slight improvement. The blower turns off for a second after running for 20-40 seconds.
