      09-11-2017, 10:33 AM   #1
critical_mass
93
Drives: Ps
Black trim discoloration
Hello fellas;
This is been happening for the past 2 years now and getting worse. It also happened on my previous BMW car that had black trim in about the same time frame. My suspicion is from snow/ice?
Was planning to get it replaced under warranty as I did before. Any other suggestions?
Thanks
      09-11-2017, 11:12 AM   #2
Alberta
Alberta's Avatar
2028
Drives: F90
Wrap it in black
      09-11-2017, 11:31 AM   #3
m34SPD
Picture me rollin'
m34SPD's Avatar
Drives: e36 m3, e39 m5, f80 m3 CS
It's from car wash chemicals. Did you run your car through a touch less car wash?
I noticed the same staining on mine a few weeks after I got it, wasn't able to get the stains polished out. I notice it only on the X5/X6 which is strange.
      09-11-2017, 11:39 AM   #4
critical_mass
93
Drives: Ps
no, i wash the car by hand. i use the same stuff on my other car (911) and an audi with no issue with their black trim
      09-11-2017, 11:48 AM   #5
m34SPD
Picture me rollin'
m34SPD's Avatar
It's a chemical reaction from the soap or something you're using. There is nothing you can do other than getting it replaced under warranty, but the staining will come back. The trim BMW used is bad/cheap quality. Like I said the X5/X6 are the only ones I notice with that staining. I saw an X5 with the chrome trim and the staining was so bad it was a rainbow effect.
I run my Range Rover through touch less washes even though I know they use strong chemicals but never had an issue. I used to run my 640GC through the same one no issues. I hand wash my E63 and no staining.
1230vani648.50
      09-11-2017, 11:50 AM   #6
m34SPD
Picture me rollin'
m34SPD's Avatar
http://f15.bimmerpost.com/forums/sho...d.php?t=988197
https://www.bimmerforums.com/forum/s...ck-Window-Trim
http://www.m3post.com/forums/showthread.php?t=292144
      09-11-2017, 12:45 PM   #7
Not uncommon. A light polish with a microfiber will do the trick.
      09-11-2017, 01:31 PM   #8
ctdw
ctdw's Avatar
Drives: M5C (F90)
My X5M is too new but I didn't notice this on my X4 M40i's black trim. I had it coated with Opti-Gloss coat and my X5M is coated with Crystal Serum Light. I wonder if coating the trim would eliminate this issue?
      09-11-2017, 06:05 PM   #9
critical_mass
93
Drives: Ps
thanks guys. ill try the suggestions and get back
      09-14-2017, 03:20 PM   #10
Djvolume
Djvolume's Avatar
215
Drives: 2016-X5M 2018-M4 Comp 2024-X5
Have the same issue took it to the dealer, warranty gave me yet again a big F you and said they won?t replace it
www.mgruppe.org
      09-15-2017, 03:13 PM   #11
X5M50D
United Kingdom
442
Drives: X7 M50d
I had this on my old X5, and a wax polish will do the trick.
Old Wheels - X5M50d in Carbon Black
New Wheels - X7M50d in Phytonic Blue
      10-11-2017, 12:42 PM   #12
critical_mass
93
Drives: Ps
mother plastic polish worked awesome! came out as new
      10-11-2017, 06:55 PM   #13
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7263
easiest way to resolve this is to not let this happen in the first place... as the old saying goes... "ounce of prevention is worth a pound of cure." that being said it appears it's a bit too late... depending on the severity of the speckling you can resolve it with any spray wax shortly after these imperfections surface however if they are baked on then a proper polish that is a minor abrasive will work wonders. afterward protect the paint with a proper wax and sealant.
Chadmatic660.50
