09-25-2017, 09:56 AM | #24 |
Rep 180
Yes, I do to both. Overall, I love the vehicle ('14 50i). The seats I give a pass, but barely. They are very firm and I still haven't quite found the sweet spot. My seats are ventilated, which many comments state that they are less comfortable than their non-ventilated examples.
09-25-2017, 11:04 AM | #25 |
Rep 30
I have the M Sport and multi-contour seats (w/o ventilation). My seats are very comfortable, and multiple people have commented on how comfortable the front passenger seat is as well. For me, the M package was a must in terms of aesthetics.
09-25-2017, 01:29 PM | #26 | |
Rep 2,388
DHP is fantastic package - but extremely rare to find - it will basically convert your x5 to a Porsche Cayenne handling wise (or as close to it as possible) Go with LED headlights if you can - it's extremely expensive to retrofit IF you can find one with MPBK (M Perofrmance brake Kit) - go for it - but you can always add it later ($2.4k ouch) - but it makes x5 look how it should be really If you can find a LED dashboard - that's a plus too, but again they are rare on used market HUD is VERY nice to have Grab 7 seater - just in case - you never know, but if you don't need it nevermind Finding right color combo ext/interior is hard too Best advise is to test drive at least 2-3 different X5s and get the feel for what you like Also - do you want power (50i V8 twin-power) or you are ok with inline 6 cyl engines? IMHO best X5 is a 50i with DHP - everything else is secondary - again just my opinion, don't want to offend anyone P.S. Almost forgot: learn on my mistakes and don't go with 20 inch rims (or keep them for winter setup) - they are ok on X5 but not great. 22 inch is the way to go. Not kidding, it's just design of our x5 and it's wheel wells is such that sometimes even 22 inch rims look a bit small lol and you'll be able to go with 335mm rear tires on 22inch rims Last edited by DuSh; 09-25-2017 at 01:39 PM.. |
09-25-2017, 02:03 PM | #27 | |
Rep 106
Also, what do you mean by drive 2-3 different X5, like msport vs. non msport, with standard seats, with multi-contour setas etc.? There is only 1 local dealer so whatever they have is what I will be able to drive or if I locate one in the 50-100 mile radius it will be something that I will negotiate online and then go to buy. |
09-25-2017, 04:06 PM | #28 | |
Rep 2,388
You might check out diesel saves fuel man and torque is veeeeery good The more you test drive the better, but I can understand limitations of course considering you have only 1 local dealership. IMHO 2 or 3 test drives on different x5s is ideal About 22 rims: imagine softest riding car you've been in - that's what 20 inch rims (no run flats) feel like. IMHO 22 rims will just make it perfect ride - like stock civic/corolla in terms of jarring. My previous 328i on 18 inch rims had more jarring ride than my current x5 on 20 inch wheels |
09-25-2017, 04:09 PM | #29 |
Rep 181
Looks like I am late to the party but I also shopped X5 and MDX (along with ML350). The three are only somewhat comparable. The ML350 didn't have anything close to the ride I wanted, so for me it was X5 or MDX. I drive my wife's Odyssey a lot and I felt like the MDX was the same vehicle - this on top of the X5 being a blast to drive and a lot nicer looking cemented my decision to get the X5.
09-26-2017, 12:53 PM | #30 |
Rep 106
I have been reading some conflicting information from owners, some say that the ride is smooth and it soaks up bumps pretty well, other I hear say that no matter the wheel size it will be jarring and bumpy on rough roads, its more sports oriented than comfort.
09-26-2017, 02:06 PM | #32 |
Rep 826
Drives: 2017 C43 AMG
I think 46k is too much for one with 40-50k miles. Even with M Sport and xDrive50i
2014 X5 xDrive50i Mineral White | DinanTronics Stage 1 | Vossen HC3
09-27-2017, 09:27 AM | #33 |
Rep 106
Ok another question regarding the AC, is the AC an issue only if you have rear zone climate?
Just want to make sure that I don't get disappointed with the AC as I would not be paying attention to it during the test drive. Good to know that Msport 2o inch has a soft ride. |
09-27-2017, 10:09 AM | #34 | |
Rep 2,388
About AC - here's the deal: air volume pumped is same no matter which x5 you'll buy, BUT if you have rear AC option (4 climate zones) then air volume is split between front and rear and that's why people complain about front not pumping out enough air. In reality same amount of air is pumped out into the car cabin - it's just split like almost in half between rear and front. Hence front driver and passenger may feel like there'not enough air coming out. The thing is in many other cars I had previously that had rear air too - air for rear vents was almost like an afterthought - it was basically very weak and tunnels to the rear vents were tiny. BMW in x5 did a good job by really splitting the air and using huge ducts to the rear vents. That's why rear passengers are getting a very good amount of air. And on the same time that air is robbed from front vents. I think it's just a choice and preference for those who drive rear passengers a lot and need a real heat/cold in the back and not afterthought/gimmick like many other manufacturers. Rear air can be switched off in climate menu - and then you'll get all the amount of air to the front vents - problem solved, BUT it seems that after each restart car switches rear vents again and you have to manually disable them every time. This is easily coded out, but this is also why many complain Just my opinion How to check if you get a 4 zone climate control x5: just go to climate menu and take a checkmark off the rear vents - and you are done - all the air will go to front vents. Then put air to middle settings and you'l feel that it's already enough. Put it on max and you'll feel that it's pretty strong and IMHO there's no need for more at all. Also make sure you direct air to dashboard vents and not only to the windshield and legs |
09-27-2017, 12:26 PM | #35 |
Rep 12
I am currently shopping for a 2014 CPO X5 50i also. Test drove this one yesterday and it seems a sweet deal. Only the mileage is a bit high(44k). Now, the CPO programs only gives 5 year/unlimited warranty from the original service date??
Should I go for this? Thanks! http://cpo.bmwusa.com/certified/2014...3276?zip=30308 |
09-27-2017, 12:32 PM | #36 | |
Rep 2,388
09-27-2017, 01:00 PM | #37 | |
Rep 12
Here is another good deal(M sports, DHP, executive and etc.), but it has three owners and carfax shows battery problems already... http://cpo.bmwusa.com/certified/2014...2064?zip=30308 |
09-27-2017, 01:09 PM | #38 | |
Rep 2,388
You had me at DHP I would jump on that - but I'm biased and I'm all about speed and handling. DHP is a GOD sent option for x5 - it's a small price to pay to get Porsche Cayenne like handling. Simply put - x5 50i with DHP (and a benchflash) can outpace a stock M3 on the track - not bad for a 7 seater SUV lol As for reliability - this iteration of N63TU is more or less issue free (compared to previous generation). So far (knock on the wood) I haven't seen any problems with this engine. F15 X5 itself is more or less reliable too (again compared to previous gen). Battery is not an issue - i have 2014 50i too and all you need is to charge it in EcoPro mode from time to time - if you drive constantly in Sport+ it may drain after a year or two and may require replacement. For me it's not an issue - I always put it in Eco Pro mode when I'm coming home to recharge the battery |
09-27-2017, 01:36 PM | #39 | |
Rep 12
The dealer I went said they don't negotiate on price.. I think 1-2k should be fine. |
09-27-2017, 04:12 PM | #40 |
Rep 1,762
Drives: Porsche Panamera
Had been a fan of Acura when they were making Legend, but nowadays, they are standard of horrid design in my book. So no. No matter how reliable it is, look alone kills the deal.
09-29-2017, 03:48 PM | #41 |
Rep 19
my Vote goes to the X5 if you're getting the M-Sport and CPO. I'm an internet manager at the #4 dealer in the country which is in Pembroke Pines, FL and take my word for it the 2017 MDX is a hell of a vehicle. comfort, quiet, handles well (AWD) decent power and maintenance is dirt cheap....however there's something about the X5 M-Sport or M thats just amazing. I currently have a 15 CPO M-sport..with 22s" and lowered a little and it's an amazing feeling everyday driving that thing. If you're not getting an M-sport then my vote is the MDX.....
10-02-2017, 10:22 AM | #42 |
Rep 77
I was in the same situation and gave serious consideration to the MDX, XC90, and GLE.
The Volvo has great safety, good looks, and great interior appearance but I don't love the big screen. Reliability is a big question mark and tipped me away. The deal killer was Chinese ownership. The MDX has lots to like but the reliability is surprisingly poor according to US News web page. (https://cars.usnews.com/cars-trucks/acura/mdx) My wife did not like the exterior, "It looks cheap." Mercedes seems to be still suffering from their period of financial troubles. The interior has nice bits but then misses on so many other points. The exterior is bland to me. The massage seats are GREAT. Steering feel is way too light for me and according to the SA can not be altered via programming. The forums I searched did not seem to have the same level of enthusiast support for things like modding and coding. It was the only vehicle I tested that squeeled the tires on my on-ramp test. The GLE-43 was a hoot but exhaust note may get old. When I went back to the X5, it just felt right. My ONLY concern at this point is the lack of small-offset crash data. The X5 scores very well in the completed tests and the results are better than the Volvo or Mercedes. Lots of vehicles do well in the NHTSA tests and even the other IIHS tests. The question of the missing small offset data is a big one. Looking at the Dodge Durango as an example, there is very real possibility of serious injury from a small offset crash in a vehicle that otherwise tests the same as the X5: http://www.iihs.org/iihs/ratings/veh...ngo-4-door-suv http://www.iihs.org/iihs/ratings/veh.../x5-4-door-suv Because I have a fairly strong preference for the X5, I am going to take the chance on it in hopes that I never experience a small-offset type crash. I think that is a safe bet. Presumably the '19 X5 will be fully tested. |
10-02-2017, 03:23 PM | #43 |
Rep 106
I went to my local dealership to test drive the X5, went with an open mind. they had a 2014 cpo with 20,000 miles black for $39,000 (tempted). When I drove it, it felt great sport was better but the ride is harsh, going over imperfections, bumps you can feel it not able to soak it up, in comfort it is better though. It handled great and the Multi-contour seats were really good, first time experiencing them.
On our way back I told him, I was interested in white and Msport, he said they just have one that is going to go through CPO process but he could show it to me. This was beautiful, the person had a lot of stuff added, ceramic controls actually is nice in person, black headliners, 3rd row seat (barely useable though). it had 30,000 miles 2015 but they listed at $49,900...too high I think, I asked him to send me a copy of the build but still haven't received it. I think it did not have blindspot but did have surround view. if they price it right, I will jump on this one, I loved it, however he did say that msport in comfort is like non msport in comfort. So wanted to get your opinions again on ride quality, also blind spot monitoring option a must have or not? |
10-02-2017, 05:05 PM | #44 | |
Rep 2,388
