04-02-2023, 08:53 AM | #2 | |
203
Rep 302
04-04-2023, 10:00 AM | #5 | |
Rep 7,522
If you do disconnect the battery...only disconnect the negative battery terminal cable and wrap it so that if it does move...it won't come into direct contact with anything metal that could cause an issue. And if you simply disconnect the negative battery cable...you can reopen the tail gate by supplying power to the dedicated jump start terminals in the engine bay. And if you need to lock the vehicle...you can unlock it manually using the key embedded in the remote fob and there should be a door lock cylinder on your driver's door handle. It's behind a little cover that you pop open with the metal keyblade in the remote fob.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-04-2023 at 10:06 AM.. |
Variante Alta95.50 |
07-04-2023, 09:41 PM | #6 |
Aussie
Rep 19
