      06-24-2023, 09:05 PM   #1
mr_coo168
Drives: X5
Valve Gasket Leak?
I have smoke coming out from the rear hood passenger side, burning oil rubber smell.
From what Im reading i have a Valve Gasket Leak? Can anyone confirm? Pictures are from left bottom side on the engine looks like a good amount of oil leaking.
Dealer told me to change the ofhg so i did few month ago but i guess they were wrong. Theirs so much oil near the valve i find it crazy they didn't know it was the valve gasket in the first place another way milking more $$ off you, when ofhg wasn't the problem
      06-24-2023, 10:02 PM   #2
stocktree
Drives: x5
Assuming you have the 35i. The valve cover gasket and oil filter housing gasket are very common leaks.
Are you a diyer? Gasket is pretty cheap.
      06-24-2023, 10:15 PM   #3
mr_coo168
Drives: X5
Too much bolts to diy, pretty piss off the dealer didn't know it was the valve cover gasket first place
Im pretty sure they knew, there's so much oil around that area but they told me it was the ofhg causing the leak which was bs milking $$ off you to fix part that don't need to replace yet
      06-24-2023, 10:20 PM   #4
stocktree
Drives: x5
Don't be mad. The oil filter housing definitely needed replacement too. And if you ignore that one, oil can push into your coolant.
      06-24-2023, 10:23 PM   #5
mr_coo168
Drives: X5
That looks pretty positive my Valve gasket cover is leaking correct?
      06-24-2023, 10:25 PM   #6
mr_coo168
Drives: X5
Yea i guess what can you do Part was like $50 Labor $1550
      06-24-2023, 11:53 PM   #7
stocktree
Drives: x5
Yeah
Are you serious? Holy hell.
If you are out of warranty, you have to avoid the dealer. Unless you like being bent over dry.
      06-25-2023, 10:57 AM   #8
tlow98
Drives: 2009 E91, 2014 F15 x35i
Yeah, ummm, the dealer is not your friend.
      06-25-2023, 11:09 AM   #9
Kkgy79
Drives: 2013 m5
Recently same issue was here. I replaced valve gasket at dealer. I paid $1200. I hope u make a good deal.
