12-06-2021, 07:45 AM | #1 |
Rep 12
Issue with floor mat fasteners
On my drivers side, one of the velcro twist lock floor mat clips for the floor mats won't screw into place and is constantly loose - has anyone else had this problem and is there a simple solution?
I don't really want to pull the carpet up to have a look unless I have to, so was hoping this was a common fault with an easy fix. Thanks! |
12-06-2021, 09:04 AM | #3 |
Rep 1,248
THIS - I know it sounds like a simple thing, but I had one fight me years ago and it turn out to be this. If you don't get them set just right before you twist - the push up between the other layers and just hang there. I did it a few times then accidently did it right and I felt it immediately.
04-14-2023, 11:15 AM | #5 |
Rep 11,147
04-14-2023, 06:19 PM | #6 |
Rep 7,588
Ditto^^^
Are you using the flat head screw driver that’s in the tool bag? If not, use that to press downward on the Velcro lock in the little slot designed for it. I think the bayonet (on the bottom) should be pointing side-to side (aka driver side to passenger side) as you press the bayonet down through the carpet into the floor pan. Once pressed down through carpet into floor…then twist 90° clockwise to lock the piece into the floor pan. In case I’m wrong…turn the bayonet front to back prior to pushing down through carpet, then turn 90° clockwise to lock it into place. It’s NOT the carpet that is securing the Velcro pad…the bayonet must fit down into the floor pan…so you need to put a little bit of downward pressure to get it to lock into place when you give it a twist.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-14-2023 at 06:28 PM.. |
04-17-2023, 10:19 PM | #7 |
Rep 7,588
Hmmm…I wonder if either forum member that had issues locking the Velcro anchors into the floor ever resolved the issue…neither reported back with success or failure.
04-18-2023, 10:24 AM | #8 |
Rep 1,497
My issue is the film on the back of the drivers side mat that the velcro adheres to has ripped apart. Yielding the velcro pretty much useless. My mat slides up and down. Drives me crazy. I guess my fat foot twists on it as i'm getting out of the vehicle causing the film to tear.
04-18-2023, 10:36 AM | #9 | |
Rep 7,588
If the material on the underside of your mat is falling apart and is unstable, then nothing is going to hold the matching Velcro patch unless you can remove all the unstable backing that you could adhere the patch to. {floor anchor attached to a replacment Velcro patch}
04-20-2023, 07:12 PM | #10 | |
Rep 1,497
