10-11-2015, 12:33 PM | #1 |
Rep 18
Towing with the 50i....
Hey guys,
I am looking to order a trailer and would like some input. I am installing an invisihitch and need a trailer to haul my r/c planes around in. I am torn between a 6x12 or a 7x12 single axle trailer enclosed. Trailer is bulky but not heavy, gross weight of the trailer will probably be 2000 - 2500 lbs. My main questions are: 1. Does anyone have any experience towing with the 50i? General impressions? 2. What MPG did you get? 3. How's the visibility with a 6' trailer? How about 7'? 4. If I end up with a tandem axle is the F15 wired for a trailer brake? 5. Are the interior lights hot wired or does the vehicle have to be on for them to work? Thanks in advance! Here are a couple pics of an example of what I want to pull. |
10-11-2015, 02:32 PM | #2 | |
Rep 118
My main questions are: 1. Does anyone have any experience towing with the 50i? General impressions? Cant comment on the 50i but 35i will tow that and more like there is nothing behind it. I tow my boat my trailers with 4Wheelers and a small camper. No issues what so ever. 2. What MPG did you get? 35i Gets 12-15 MPG towing depending on what i am towing 3. How's the visibility with a 6' trailer? How about 7'? I have seen no issues with visibility using my X6 and you will have more visibility than i do in a X5. 4. If I end up with a tandem axle is the F15 wired for a trailer brake? I had the dealer wire up a break controller. This is not default and is a separate item just like most vehicles. 5. Are the interior lights hot wired or does the vehicle have to be on for them to work? Vehicle Lights ? Are you talking about running lights ? They are on if your cars lights are on. Are you talking about interior lights in the trailer ? All depends on how thats wired.
2015 BMW X6 //M-Sport //M-Performance Power Kit, Black Sapphire Metallic, Terra Dakota Leather, Night Vision W/Pedestrian Detection, Adaptive Lighting, Ambiance Lighting, Led Fog Lights, Harmon Kardon Surround Sound, Heads Up Display. Rear Seat Entertainment, Premium Package, Lighting Package, Driver Assistance Package, Cold Weather Package.
10-11-2015, 08:32 PM | #3 |
Rep 576
I tow a 24ft featherlite (a serious trailer) with a 99 M3 track car + track stuff. Max rated weight on the tongue and total weight.
I use an electronic brake controller. https://www.etrailer.com/bc-2012_BMW_X5.htm The car struggles (shifts a lot) above 60mph but manages for the short time I'm on the freeway. I get 12-13mpg, visibility sucks without extended mirrors. Dealer installed the BMW approved hitch. 6-7 wide should not be a problem, don't buy a steel trailer. Last edited by bjcarls; 10-11-2015 at 08:41 PM.. |
10-13-2015, 10:28 PM | #4 |
Rep 982
I tow a 6x12 single axle for exact same reason as you. The 50i tows it like not even there. Gas mileage - 10 mpg maybe (haven't calculated it, but that's what dash says while towing at highway speed). Visibility is fine with 6'. Previously towed same trailer with 2012 35i and there is a huge difference in power.
10-14-2015, 03:41 PM | #5 |
Rep 493
I towed a lot with a E70 50i, now towing the same trailer with a F85, both outstanding tow cars. More info here:
http://f15.bimmerpost.com/forums/sho....php?t=1167155 Happy flying! |
11-08-2015, 05:26 PM | #6 | |
Rep 18
This is what I am hauling around: Last edited by IFlyEm; 11-08-2015 at 05:43 PM.. |
11-08-2015, 05:27 PM | #7 |
Rep 18
Towing Mirrors
Ok I am about to order a trailer. I decided on a 7x12 enclosed. I really need the 7x12 for what I am carrying. I am pretty sure Iam going to need some towing mirriors to see. I see there where OEM mirrors or the E70 but can't find anything for the F15. What are you guys using? I don't mind universal but I don't want anything thats going to markup or damage the current mirrors.
Any input would be greatly appreciated! |
12-22-2016, 06:16 PM | #8 |
Rep 30
2011 X5 xdrive50i (N63) 10.5 mpg average from FL to PA.
8.5x16 enclosed trailer. Packed to the brim inside. Three big tool boxes, cherry picker, hydraulic press, jacks, entire 4 bed 3 bath home. I have no idea how much the trailer weighs, I didn't want to know. Chris |
M3 Adjuster7905.50 |
