06-26-2023, 04:23 PM | #266 |
Rep 814
Drives: BMW X5 XDrive35i
Purchased from an acquaintance through Instagram. Contacted RVG via email because the seller had used them previously and was able to move forward with the service.
06-27-2023, 08:23 AM | #267 | |
Rep 814
If I had to do things differently, I would’ve gone straight to the Stage 2 HPFP to prevent any fueling limitations. You can certainly do the turbo first, but the reason I tackled things like the oil cooler and such first was to test out thermal management and ensure it was functioning before diving in further. I’d recommend a focus on heat management because these engines like to run hot. You can certainly do this build without ethanol, which would save you the need for a LPFP upgrade unless you go with a massive turbo.
06-30-2023, 01:23 PM | #268 |
Rep 814
6/30/23
Today was dyno day for the new setup on E70+ fuel which was max boost/load targets. Ambient temp in the dyno room ended up being 90+ degrees so we’ll go back for power runs in the late fall but we made good power and more importantly it was consistent and smooth. Car made 477WHP/502WTQ on a 4WD DynoJet. We purposely limited torque to 500ft lbs to keep the motor happy and for longevity and reliability. This is a dog car after all. Overall I’m very happy, it’s an AWD N55 with a hybrid so I can’t really ask for more from the hardware. I’ll share more boost and log data in the turbo thread to keep it on topic.
07-02-2023, 07:16 PM | #270 |
Rep 814
Thank you! It’s not massive numbers but with all the driver mod we’ve gained through testing I feel confident in setting solid times come fall.
07-12-2023, 07:41 PM | #271 |
Rep 814
7/12/23
Wheels have arrived as well as the catted downpipe and are ready for install this Friday. Took the time to do some recording for the YouTube video I’ll make so took some photos too. Enjoy Oliver being sick of my ish.
4
07-14-2023, 09:30 PM | #272 |
Rep 814
7/14/23
Welp, it seems as though the universe is testing my patience. Figured we’d do an oil change during the wheel and downpipe install today since we’re going to MPact next month and found the oil pan drain plug socket to be stripped. Heli-coil kit on order but the wheels are ET perfect. More to come after the cars back in my possession.
jmack1231302.00 Chriscrosstnt10.50 |
07-16-2023, 06:45 PM | #273 | |
Rep 546
Drives: 2018 YMB M3 Comp
How's the intake regarding performance? And I forgot if I asked, are you on Springs? |
07-16-2023, 06:47 PM | #274 |
Rep 546
I heard that the paddles + tcu tune doesn't help much on this platform bc we don't have the msport suspension kit to tie it all together ? 🤔 input bro!! Have you done side by side comparison??
07-16-2023, 07:03 PM | #275 | |
Rep 814
BC Coilovers on Swift Springs w/ custom spring rates. I’m on ethanol now and my mpg is NOT good lol.
07-16-2023, 08:24 PM | #276 | |
Rep 546
And xhp huh. Well I guess I'd need to figure out getting a wheel with the paddle shifters first, and code the hell out of the car for all of its features |
07-16-2023, 09:12 PM | #277 |
Rep 814
Yes for sure! Code all the things. I had XHP even when I was just on a piggyback, made a big difference even then. Can’t recommend it enough. Do a trans service to be safe though lol.
07-16-2023, 09:23 PM | #278 |
Rep 546
Hahah most definitely! And good thing, even tho my 2016 x35 is 115k miles, the trans was done 10k miles ago thanks to the previous owner ! How was coding paddle shifters ? Did you bimmercode yourself
07-17-2023, 07:40 AM | #279 |
Rep 814
Yep, BimmerCode is super simple to use and coding the paddles was easy once I knew where to look. One thing to keep an eye out for , is that not all cars are pre wired for paddles. I’m not sure what to look for to be honest but I knew that going in and go lucky I didn’t have to add any additional wiring.
07-18-2023, 08:27 PM | #280 |
Rep 814
7/18/23
We’re back and better than ever Variant Wheels Argon in Machined Silver 20x10 et15 on a 275/40 20x11 et10 on a 315/35 I’m a happy man.
7
07-20-2023, 07:20 AM | #282 |
Rep 814
Go for it! Happy to help in any way I can.
07-21-2023, 01:12 PM | #283 |
Rep 546
07-26-2023, 08:35 AM | #285 |
Rep 814
Hey man, tried to reply to you but your inbox is full.
Hotflare188.50 |
07-26-2023, 08:37 AM | #286 |
Rep 546
