02-11-2015, 12:53 PM | #1 |
Rep 258
Few questions
1. What is the buzzing noise when you unlock the car. You can notice the sounds when standing outside the car for a few seconds.
2. So I bought my car from a dealer via email (not local dealer). Who is going to contact me regarding car service? Is it the car telling me that it needs service? Or do I have to tell me local dealer to add my car to their system so then can contact me when it's time for service? 3. First service is at 10,000 miles correct? |
02-11-2015, 01:17 PM | #2 |
Rep 1,181
1. Fuel pump getting primed for action.
2. Your dash tells you how many miles it is until service. Schedule on your own. No one is going to call you. 3. Yes, although some people will do an interval oil change (self-funded) at 5K.
02-11-2015, 02:31 PM | #3 | |
Rep 258
02-11-2015, 02:42 PM | #4 | |
Rep 3,990
Yes, Haren, that's correct. You can also check it via your cluster menu. All you have to do is turn on AC POWER (one button push) and then hold the cluster button in the left corner. It will show you the next service due in miles as you tap the button to scroll through. Turn off the car and it will go away.
02-11-2015, 03:29 PM | #5 |
Rep 3,307
Just talked about this on another thread.. some dealers (though not mine ) do still notify you when service is coming due. But you would presumably have to get one service there first, or stop in even outside of service maybe, to get in their system and do whatever they need to do to get the car to "talk to them." I'm guessing that may involve as little as them plugging in the fob to their computer and taking some basic contact info from you.
02-11-2015, 04:04 PM | #6 | |
117
Rep 324
Meanwhile, I'm leasing the car and leaving/selecting my sale/service info via BMW website. Not sure if that service dealer will reach out to me by that info... |
02-11-2015, 09:48 PM | #8 |
Rep 258
02-11-2015, 09:52 PM | #9 | |
Rep 3,990
If it still doesn't work, then maybe someone who has played with it can help chime in .
02-11-2015, 09:59 PM | #10 | |
Rep 258
02-11-2015, 11:26 PM | #11 |
Rep 1,181
There is a known issue where the ONLY the HUD height is not retained even though all other settings (seat position, light color scheme, etc.) are properly remembered. There's a TSB/software update for it, but of course, that'll erase all the coding you may have done to date. This seems to happen much more between the two profiles/keyfobs, i.e. when I get in the car in the evening after my wife's been driving it all day, the height is back to the center setting.
Good news is that I can just push the seat memory button for my settings and the HUD will raise up to my preference. So, I probably won't mention this whenever I go in for the first service. Not annoying enough to fix vs having to re-code everything. |
02-11-2015, 11:30 PM | #12 | |
Rep 1,181
02-12-2015, 12:08 AM | #13 |
Rep 3,990
Just figured out how to keep the codes so they don't get erased. I know Shawn explained that when they update software, it reverts back settings, but it's a good way to test. I just tested and VO Coded ddavtian's HU_NBT folder after I fdl coded everything. This erased all his settings. Then, from the new CODED CAF FOLDER I backed up (the same way I backed up the original CAF folder when I read coding data of his factory CAFD files), I restored the HU_NBT coded files. Simply right click the HU_NBT folder (or any other ECU folder you need to restore), selected NEW, then the long line (must not be greyed out- if greyed out, simply READ ECU again), which gave me access to to any CAFD module location. I selected the backed up CAFD HU_NBT file and simply hit CODE FDL - voila....everything he lost returned coded without me having to individually go in and recode every single thing by editing fdl.
02-12-2015, 12:33 AM | #14 | |
Rep 124
02-12-2015, 12:35 AM | #15 |
Rep 1,181
Makes perfect sense. Basically just need to backup the files before going in then read them back in once you return from service.
I wasn't sure if the fixes applied by the dealer are guaranteed to be VO-only? That is, would any FDL settings that we don't know about get reset as well when we restore the backups, thereby undoing the fix that was just applied by the dealer? |
02-12-2015, 12:39 AM | #16 | |
Rep 3,990
