05-28-2020, 11:52 AM | #1 |
Rep 184
Rear Differential leak
i was under my X5M today and noticed some oil residue on the rear diff. doesn't look to be more then a slow leak but wondering what kind of seals need to be replaced to fix this as i have never worked on this before. any help would be appreciated.
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners |
05-29-2020, 02:07 AM | #3 |
Rep 122
This looks pretty similar to a leak I had in my rear diff at 23,000 miles. There is an old bulletin from BMW regarding a fix for it (the dealer initially wanted to completely replace the diff). Because it was warranty work, the diff was rebuilt. It was about $650 in parts with a discounted price.
Travis1807107.50 |
05-31-2020, 04:27 AM | #4 |
Rep 3,151
Check if the servo motors are leaking. usually its the o rings on them. easy to replace:
https://www.realoem.com/bmw/enUS/sho...diagId=33_1853
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
Travis1807107.50 |
05-31-2020, 01:05 PM | #5 |
Rep 184
can't really tell just a thin layer over the entire read diff
2016 X5M
0-60Motorsports792.00 |
06-04-2020, 06:48 AM | #6 |
IG: @88jae88
1621
Rep 1,734
Crap then that could be something else.. I know when it comes to the seals it begins to leak from the sides and would gradually get worse. Do you work on it yourself or do you want a tech to take a look?
IM POOR..
06-04-2020, 04:45 PM | #7 | |
Rep 184
pic 1 is psg side pic 2 is driver side (you can def. see all the oil and the marks in it from me trying to run a rag through it) any ideas after seeing the new pics???
2016 X5M
06-05-2020, 12:16 AM | #8 | |
Rep 184
appreciate your help
2016 X5M
06-05-2020, 02:53 AM | #9 |
Rep 122
You really should thoroughly clean it, drive it for 50-100 miles and check. It will really help you locate the exact place. I know it sounds like common sense... My diff and surrounding area was much worse than your's. After cleaning, it looked perfect. 100 miles later, there was a clear small spot it was very slowly leaking from. I need to find a picture where you can see just the leak.
06-05-2020, 02:21 PM | #10 |
Rep 122
Here are a couple where the leak is easier to pinpoint post cleaning.
Travis1807107.50 |
06-05-2020, 09:43 PM | #11 | |
Rep 184
That def. sounds like the most educated way fwd. Appreciate the help!
2016 X5M
06-05-2020, 10:33 PM | #12 | |
Rep 122
Travis1807107.50 |
06-07-2020, 08:09 PM | #13 | |
Rep 184
So i got some better pics and its def coming from where the driver side axel connects to the diff. the first pic is the psg side and you can see it's clear of oil and doesn't have any rust. The 2nd and 3rd pic is the driver side and it looks like the axel is rusting into the differential. there isn't much oil on the diff b/c i cleaned it off but there is still a layer caked on the exhaust right there. i'm curious to know why its so badly rusted. seems awkward. think ill need to replace the axel as well as the seals?
2016 X5M
