11-18-2021, 07:37 PM | #1 |
Rep 74
Windshield washer fluid leak, anyone experience this?
My X5 is throwing up windshield washer fluid, anyone experience this?
Not sure how this happened. I will have the shop take a look at the next oil change. |
11-18-2021, 08:36 PM | #2 |
Rep 91
yes I have the same issue.
'13 Toyota 4Runner(sold)
'16 Suzuki GSX-R750 motorcycle(sold) '18 X5 F15 sdrive stg 1 (sold Aug 23) '23 Tesla Model Y Perf |
11-19-2021, 08:00 AM | #3 |
Rep 1,222
Could be a crack in the reservoir. If you try to refill, does it immediately leak? If so, it is likely a crack.
11-19-2021, 09:29 AM | #5 |
Rep 1,222
11-20-2021, 07:59 AM | #6 | |
Rep 74
I recently had work done to fix the "infamous" sun roof drain block. I suspect they must have somehow punctured the reservoir or a plastic pipe. I will update later when I get this resolved, the bluish residue on drive way is triggering ocd |
11-20-2021, 09:45 PM | #7 |
Rep 1,703
Drives: 2014 428i and 2018 X5
I have the same issue. Took everything apart last week to see what was leaking, and it appeared to be the pump. So I ordered a new pump.
Installed the new pump yesterday and it still leaks…but not until the car has been driven. If I fill it up and not go anywhere, it's fine. The vibration of driving must make it leak. So next week I'll be taking it apart for a third time, to replace the pump grommet / filter and a section of the hose.
11-21-2021, 12:01 AM | #8 |
14
Rep 97
Most likely the pump. The ends where the hoses connect to it can crack. It's not too hard to open the fender and get to it.
11-27-2021, 10:08 AM | #9 |
873
Rep 345
I had issue as well. Had dealership replace under warranty
12-01-2021, 04:17 PM | #10 |
Rep 34
I had the same problem before, pump was the culprit, changed the pump and every thing is good again
